Question about Thermador Ovens
Thermador CM302 shuts off intermittently. No error code, timer remains working.
Our Thermador CM302 will be cooking along just fine in normal oven mode (not sure about other modes) and will simply shut down. No lights, no error codes. The bell goes off and the timer keeps working, but the oven(s) simply shut down. Any ideas?
  • Craig Buck Feb 07, 2012
    The timer is not doing anything but timing. We are not using it to control the oven so I can't see how that would be involved. And if it was the thermostat, why would the oven icon go off on the control panel? I can see the heating element going off, but not the whole oven.
  • Craig Buck Dec 21, 2012
    f1mb. isn't the magnetron for the microwave? This happens when we are using the regular oven.
    Champion:
  • Thermador Expert
  • 323 Answers
Most likely a bad relay board. Really just a couple of soldered pin points on the back of it are bad. If you are able to remove it (from the top) inspect each solder point and look very closely with a good magnifier for fractures around the protruding pins. Some are very difficult to see while others are plain as day. Clean gently with a pin or knife and resolder. Relay boards range from $200 to $400 in price.
Posted on Jan 07, 2015
    Scholar:
  • 78 Answers
Dear Craig Buck,
This is either a fault with the timer, or you have a fault with the thermostat. Get a multimeter onto that thermostat and test it, after removing the heating element of course. Then get back in touch with me and I will give you the fix.
Yours sincerely
Ouszen
Posted on Feb 07, 2012
amgm
  • 32 Answers
SOURCE: trying to set oven timer
Hi, switch off the mains for the cooker, wait for about 15 seconds then press the 2 buttons on the left and hold them, and then press the - or + button to set the time.
Cheers
Posted on Feb 19, 2009
SOURCE: I have a Thermador model CM302 with a built in
I have the same oven and the same exact problem. The problem is with the magnetron. It needs to be replaced.
Posted on Nov 25, 2009
  • 72 Answers
SOURCE: Neff U1524 Double oven
Your oven should be connecting individually to its own fuse in the fuse board.
Posted on Jan 04, 2010
heatman101
  • 43501 Answers
SOURCE: oven door remains locked after self-cleaning
Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
Also check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Posted on Apr 28, 2010
SOURCE: Belling built in fan oven (XOU60FP)is overheating
Have same problem, I am repairing our 648HM double oven. Top oven overheats. I am an electronics engineer. I found that top oven fan has failed, this is the first thing to replace. The grill element also failed which maybe due to the overheating oven. NIGEL
Posted on May 10, 2010
Thermador cm302 f34 error
upper oven fan airflow switch not activated. It may be stuck or the fan isn't running at all.
Mar 07, 2013 | Thermador CM302U Electric Double Oven
Thermador CM302 f63 error code
overheat situation. check oven sensor and soldered pin points for sensor wires at relay board. Resolder if needed.
Feb 10, 2013 | Thermador C301U Electric Single Oven
F5 error code
F5 = EOC electronic control failure replace electronic control is stated in the service manual. If you have any further questions message me them back. Thank you
Rick
Nov 28, 2011 | Thermador SC302T Electric Double Oven
Thermador CM301U Microwave cook smart, self clean and proof buttons all make the display light up as normal, but probe, convection, bake, broil and roast do not. I can hear the beep but nothing on the...
there are two boards in the oven and i would think that it is the one on the left called the secondary . if you remove the display panel you will find the tech sheet and this should help diag the problem . thermador does use fault code's and if any have displayed / in the tech sheet you will be able to tell whats going on or in this case what isn't .. mm hope this helps .. feed back pls .
Nov 29, 2010 | Thermador CM301U Electric Single Oven
We had a power outage and when the electricity was restored the oven is displaying an F1 and F7 code and is beeping the alarm, how do i stop this?
Hello, the F1 error code means internal logic failure (monitoring function) it sounds alarm and inhibit cook mode You can fix it by replacing the electronic range control (ERC)
F7 error code means the function key shorted for over 16 seconds, check for something pressing a key or preventing normal release of the key. You can fix it by replacing the electronic range control (ERC) if other component check normal.
Thanks
Jul 14, 2010 | Thermador CM302U Electric Double Oven
I have a Thermador model CM302 with a built in microwave. The microwave makes all the right noises ... but does not heat the food. What's the problem?
Nov 20, 2009 | Thermador Ovens
The upper oven door dosen't shut tight.
Door not closing properly is normally due to weak door hinges.
Normal procedure is to replace both the hinges.
Plz rate my solution.
Thanks.
Jan 07, 2009 | Thermador SC302T Electric Double Oven
F24 Error code and incessant beeping
Being a software developer I guessed that the keyboard (the touch pad) was bad, because in my case one of the keys (the Top Oven OFF key) did not beep or work. So I went on the Thermador website and found the touchpad on the schematic. I ordered one yesterday from a firm called Mar-Cone in St. Louis, and it arrived today. It is a very easy replacement, and takes about 10 minutes. Happily it was a good guess, and it works fine. For the 27" SEC272BS/01 (stainless) the part # is 474083, and cost $189.20. They will express ship for $25.
Phew, we have 20 people coming for dinner on Thursday.
I'll be happy to let anyone know how to change the panel.
Nov 09, 2008 | Thermador SC272T Electric Double Oven
Thermador Built-in oven model cm301
Same issue w/our Thermador CM301. F23 and F24 codes - BSH acts like they have never heard of the problem! Awful service. This should be reported to the Consumer Board.
Feb 19, 2008 | Thermador SC302T Electric Double Oven
Ovens Logo
605 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
goober123
Level 1 Expert
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
