Question about Home
Kohler reve toilet seat installation - Home
phmaddnes
  • 24 Answers
SOURCE: can't change the toilet seat that broke
Kohler Rialto Toilet seat replacement.
Use dremel to cut off old bolt and allow it to fall into the black abyss that is the genius of Kohler engineering. Enlarge the hole to 3/8. I worked up to that size slowly increasing bit size so as not to crack porcelin. At Home Depot I bought a 1/4 x 20 x20mm "Insert Nut" and a good 2 part epoxy meant for metal and ceramic. Gently tap the Insert nut about 1/2 way into the hole and apply epoxy all the way around. Continue tapping the insert nut until it is flush. Clean off excess epoxy and allow to set. Now attach any standard round toilet seat using the standard 1/4 nut that comes with it. I used a Kohler "Cachet" round toilet seat to replace the Kohler "French Curve" that comes standard with the Rialto. All in all it should take you about 1/2 hour.
Happy Fixing!
Posted on Jul 03, 2009
SOURCE: kohler lowboy toilet seat does not have bolts underneath
I have the same low boy where the bolts are inside the hollow body of the toilet. I called Kohler customer service and was told to use brute force to yank the toilet seat out. My husband suggested using a saw to cut the bolt but he hasn't done it yet. He wants to replace all our Kohler low boys which constantly leak becos of poor design of handle and flapper. The handle pulls the flapper slightly to the side when you flush. And the flapper lip being a tiny bit too small, if it doesn't sit just right, the toilet leaks. We've replaced one already with a Toto and love it. Too bad that Kohler isn't trying to fix the problem as I see many many online posts with the same problem and recommendation to replace the Kohler with Toto or somethng else.
Posted on Aug 09, 2009
If your problem is like mine your toilet seat is loose and swivels when you sit on it. If you try to tighten down the screw it won't tighten. Use instructions above to remove old hardware.
To fix with new hardware
Purchase Hilti brand 3/16" x 2-1/2" Toggler Brand Toggle Bolt (Home Depot sells the kit). Kit comes with 10. You will only need 2. My last repair lasted about 8 years (with new kit = 40 years left or the purchase of a new toilet - whichever comes first). Set comes with 3/16 flat head screws. I recommend purchasing 3/16" 2" round head screws with matching flat washers. Sink Metal Toggler into hole with toggler pointing straight up (it's attached by long plastic legs). As it goes in the hole it opens up. Pull up on the plastic pull rings as tight as you can until the toggler is tight up against the inner porcelain of the bowl (similar to tightening cable ties). Line the seat up with the holes and it's new plastic adapter (that won't slip into the hole courtesy of Hilti). Slide washer underneath round head screw but on top of toilet seat assembly and screw directly into the newly installed toggler which is sunk in bowl/abyss receptacle. Repair should take around 5 minutes.
  • 3 Answers
SOURCE: What is the best way to remove stuck toilet anchors
try rotating the entire toilet counter clockwise so the bolts are in the insert slot of the toilet flange and rotate the nut and the bolt head should line up and pop free of flange.
Posted on Oct 31, 2009
co7196
  • 3433 Answers
SOURCE: I cannot tighten the toilet seat on my kohler 3386
Give Kohler a call AFTER you read the instructions thoroughly. Good Luck, seriously.
Posted on Nov 09, 2009
I have a Koehler model 703 84679aa. The seat bolt is loose and you cannot get to the but without pulling the toilet. Does anyone know how to tighten the seat without removing the whole toilet?
Kohler Rialto / San Raphael toilet problems # 84499 ...
? 13:04
www.youtube.com/watch?v=Hmhb4H4HYMY
Mar 31, 2012 - Uploaded by Dino Pinch best kohler rialto / san raphael toilet repair video on youtube. ...the kohler brand rialto model wisks away the offending lumps of ur behind product, never to be seen again. .... 'can't screw a lightbulb in'. .... How to Install Toilet Seat on Kohler One-piece ModelK3434 - Duration: 7:10. by emf4kv 20,891 views.
Jul 26, 2015 | Home
Why is tank wobbly upon install on kohler archer toilet?
The tank mounting bolts could be loose or the tank could be incorrectly seated. Be careful not to tighten the bolts too much and crack the tank.
Jul 20, 2014 | KOHLER Archer Toilet Tank, White
Where can I purchase a new Kohler 85330-cp-17 Teal replacement molded wood elongated toilet seat for our existing toilet?
You cannot. As you state, it is discontinued, confirmed on Kohler site.
If color is really important, consider painting it or a new replacement using an appliance epoxy spray paint such as Rust-Oleum after careful preparation of the surfaces.
Jun 13, 2014 | 85330-BR-17 Part - Teal Assembly Seat-...
Kohler Toilet seat bolts stuck
If the bolts are plastic or metal you will need to cut them off and install new ones from new seat or bolt kit there is no easy trick its just an easy cut them off or you could try some wd-40 or nutbuster.
Apr 12, 2014 | Kohler K-3384-2 San Raphael Elongated...
I just installed a kohler toilet fresh from the crate. The fill valve runs every few seconds for just a few seconds. I suspect a leak but can't find any water drops in or around the toilet. Can you...
possibly the flapper valve not seating properly..
open lid of tank, check if chain to flapper is too tight, then check if something blocking flapper from seating properly
Jun 13, 2010 | Kohler Home
How do I replace the toilet seat on a Kohler
I repaied one of these laast week and it had the Plastic nuts in between the webbing on the seat where the lid connects I believe You remove the plastic cap with a knife and use a flat tip screw driver to remove the screws and replace the seat.
Jun 01, 2010 | Kohler 3386-6 Rialto Skylight Round Front...
Home Logo
190 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
