Error code E1 28031100 Posted by Guest on 2/7/2012 Details I keep getting error code E1 28031100 when I try to play back a dvd I recorded. I have the recorder in the VR mode and when I stop the recording I get a message that says "cannot record on this dvd, after the recorder writes to the disc after recording. I am currently using Memorex dvd-rw discs. At times I have recorded on this same brand of discs. I, at times, can'r finalize either. Also I used dvd_rw from two different dvd plastic cases. My dvr manual says I cant use dvd + r or rw
SOURCE: dvd recorder won't record on DVD-RW disc.
CLEANING THE DISC LENS ? If this unit still does not perform properly although you refer to the relevant sections and to ?TROUBLESHOOTING GUIDE? in this Owner?s Manual, the laser optical pickup unit may be dirty. Consult your dealer or an Authorized Service Center for inspection and cleaning of the laser optical pickup unit. FROM EWR20V5 OWNERS MANUAL FUNAI-CORP.COM
SOURCE: Panasonic DMR-ES30v Combo- Message of "Check disc for error"
Pay TV in Australia will record "no problem" BUT BUT when it is a pay per view or Box Office etc it will be blocked in a similar way as Macrovisin that is recognized in the encoding of the recording device that the signal is passing through. The result point blank displayed you are not allowed to record this program or it is blocked or distorted part of the way through the recording etc...
SOURCE: During a move, my owners
you can find the manuel here http://www.retrevo.com/support/CyberHome-DVR-1600ZU-DVD-Players-manual/id/534ci860/t/2/
SOURCE: my VCR-DVD magnavox ZV427MG9 A i get recording error, can't record +VR mode E 45
this is a similar problem with the same code http://www.epinions.com/review/Philips_DVDR3545V_37/content_464296251012?sb=1 The person in this says that the plastic "tab" on the back of the tape was broken off to keep from recording over it, but was unable to use it in a combo like you have. he put tape over the hole and it worked...Is this similar to what you are trying to do? let me know
