Washing machine its not working ,,,paused the timer
    Top Expert:
  • Washing Mach... Master
  • 76,682 Answers
Try unplugging the washer for 5 minutes to reset the timer.
Posted on Feb 07, 2012
How to reset or unlocked the beko washing machine timer
My washing machine time delay switch is flashing and I can't turn the machine on what do I need to do?
Feb 07, 2012 | Beko Washing Machines
Bosch WFT 5010 washing machine will not fill. The timer seems to work correctly - the washer goes to the set program and pauses - at this point the fill valve opens normally. But it is not happening. ...
Possible that the inlet valve is faulty but you will need to check the voltage at the time of the cycle. Even if this valve is clogged at the inlet filter it will not fill. so check from the front end, remove the water line and check.
Please find some tips from the link below;
http://www.washingmachineadvisor.com/how-do-washing-machines-work-.html
http://www.repairclinic.com/Washing-Machine-Repair-Help
Feb 19, 2011 | Washing Machines
My topload Roper washer cycles fine but stucks in rinse stage. It makes a noise on that stage. I manualy put it in spin mode (skipped the rinse) and it works from there. Please help.
Your timer is bad. There must be a pause in the timer for the neutral drain transmission to lock in.
No Pause.
No Spin.
To double check this,when the timer gets to the Spin cycle, open then close the lid.
If it starts to spin at that point the timer is bad.
Jan 09, 2011 | Roper Washing Machines
My Kenmore, 80 Series, washer stops at the spin cycle; I open the lid push the knob in and then close the lid and it restarts, but this happens everytime I wash clothes. What is wrong with the machine? Is...
Most likely a bad timer.
Set the machine to wash.
When it gets to the spin cycle it should pump out the water.
Then there will be a PAUSE(silence) from the machine for several seconds. During this time the transmission will engage the spin gears(audible sound).
If there is NO PAUSE the timer is bad.
When you open and close the lid you are artificially creating the pause.
Mar 18, 2010 | Washing Machines
The washing machine at my church stops in the middle of a cycle. When I "jiggle" the timer it starts again and works for a while and then stops again.
The timer probably has dirty/corroded/loose contacts or it has loose wire connections to it. Needs to be removed to assess.
More info, let me know.
Charlie
Oct 01, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer will not spin
Your neutral drain is not locking in.
Let the timer advance to the final spin cycle. Once there it should have about a 5 second pause and the transmission spin gears will lock in. If no pause replace the timer. If you have the pause and still no spin replace the transmission.
My bet is on the timer.
Apr 01, 2009 | Whirlpool WTW5200S Top Load Washer
The washing wont spin or drain i replaced the lid swicth didnt work
Set the washer for spin and turn it on.
If it does not spin, open then close the lid and see if it spins.
If so set the timer for regular wash. When the timer gets to the final spin it should PAUSE a few seconds. The transmission will lock in, then it should spin.
If you do not get the PAUSE in the timer at the beginning of the spin cycle the timer is bad.
If you do get the Pause and it does not spin the transmission is bad.
Mar 18, 2009 | Whirlpool Washing Machines
Kenmore washing machine will not drain
Replace the timer.
This is a neutral drain machine. If there is no natural pause in the timer at the end of the rinse cycle the timer is bad.
Mar 13, 2009 | Kenmore Washing Machines
Kenmore model #11092581200 doesn't always spin
The timer needs to pause the motor after the water is drained from the tub to lock the spin cam in the transmission. The timer may be bad and not pausing the motor but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance.
Go here for Kenmore Washing Machine Parts: http://www.repairclinic.com/Kenmore-Washing-Machine-Parts?z=100
Feb 07, 2009 | Kenmore 22422 Top Load Washer
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
