Question about Lakewood (5500) Oil Filled Radiator Heater
Heat wave oil filled heater tipped over, shut off and will not come back on
2 Suggested Answers
SOURCE: Lakewood oil filled heater model 5500
Follow up to my post of 13 January. Out of desperation, I took the heater apart and determined that an electrical fuse-like thermal overload device had opened on the neutral side of the feed to the heating element thus rendering the unit non-working. This device is wrapped in a sheath around the underside of the heating element's electrical connections where the element enters the radiator's core. If the element exceeds the rated temperature it apparently "blows" or electrically opens much like a fuse. The lights still come on but no electricity is getting to the element. When I removed this from the circuit, the the unit began making heat. Apparently, when the heater is on full (both switches on for the full 1,500 watts) the core temperature gets too high. So, I now use my heater on only the 900 watt setting and it's putting out plenty of heat. Today's high is 2F and the room is comfortable. I've no doubt the manufacturer would not condone this modification and I have no intention of turning my modified heater back on "HIGH." Therefore I do not recommend doing this yourself unless you are competent in electrical and soldering work and are sure you won't overheat the unit. Having said that Lakewood clearly has either a design flaw or a bad batch of heater elements or overload protectors out there. When I have time, I'm planning to send my defective protector back to them with a letter. But given that they never responded to my e-mail to their customer service don't expect much in the way of a reply. As they say on TV, don't try this at home.
Posted on Jan 31, 2008
I need a thermostat control for a Lakewood oil filled heater model 5101
Check out this tip that I wrote about space heater problems..
DeLonghi Space Heater does not Heat
heatman101
Feb 13, 2011 | Lakewood 5101 Oil Filled Radiator Heater
Need a switch for a honeywell HZ680 oil filled heater
heatman101
Feb 10, 2011 | Honeywell HZ-680 Oil Filled Radiator...
My Lakewood heater turns on but will not produce heat. Any ideas as to what is wrong????
Same symptom on my oil-filled Lakewood model 5500. Used an ohmmeter to check it out and found that 1) the thermostat is defective and potentially a fire hazard due to intermittent operation. 2) Then I learned of reports about some Lakewood oil-filled heaters squirting hot oil and injuring people, and 3) the manufacturer subsequently going out of business. Three strikes and you're out.
I cut off my heater's power cord and threw the whole thing away, and recommend others to do the same.
Feb 07, 2011 | Lakewood Oil-Filled Electric Radiator...
Can I replace the element in a Lakewood Oil-Filled Electric Radiator Heater?
Sorry... but they are not replaceable....
heatman101
Feb 02, 2011 | Lakewood Oil-Filled Electric Radiator...
Lakewood oil filled radiator heater repacement switch
Here is a tip about space heaters that will also help you...
heatman101
Jan 26, 2011 | Lakewood Oil-Filled Electric Radiator...
Stopped heating
heatman101
Dec 31, 2010 | Lakewood Oil-Filled Electric Radiator...
Reddy Heater Pro 100: plug in, fan turns on, blows out small amounts of unburned fuel and then fan shut off. What could be the problem?
jeffsampson,
This is a classic reddy heat problem. I have a tip at http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters which explains the problem and where to go to get the parts you need to fix it.
Thanks for using FixYa and for the great rating.
hardrocko
Dec 29, 2010 | Reddy R115DT Oil Filled Utility Heater
I have a oil filled rad style electric heat ,which is leaking oil can it be fixed? If so how.
Here is a tip that I wrote that will help you to understand about oil filled radiator heaters....
Oil Filled Radiator Heater Leaking
heatman10
Dec 19, 2010 | Honeywell HZ-709 Oil Filled Radiator...
Lakewood (5500) Oil Filled Radiator Heater Logo
106 people viewed this question
Top Lakewood Heating & Cooling Experts
jay kaye
jay kaye
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
Are you a Lakewood Heating and Cooling Expert? Answer questions, earn points and help others
