Question about ViewSonic PJD5111 Projector
Viewsonic pjd5111 projector has temp and lamp light on. not turning on
The projector is not coming on at all. You cannot see any image at all. When you hit the power button, the orange light turns on on the lamp and temp. We have tried unplugging everything. There is no image whatsoever.
    Top Expert:
  • ViewSonic Master
  • 74,617 Answers
Hello
Check whether its cooling fan works or not. If there is any fault to the cooling fan, these symptoms you describes here can occur.
Posted on Feb 07, 2012
  • 473 Answers
SOURCE: VIEWSONIC PJD5111 SHOWS VERTICAL LINES
Hi... Projector show vertical lines... Issue in your logic board filter's missing on logic input board check for fail signal on video input logic board,,, check input connector for broken pin inside connector... also check capacitor & resistance arround video logic processor, possibility of over heat conponent
Posted on Oct 25, 2010
techman
  • 3130 Answers
SOURCE: Convergence error on viewsonic projector PJ820
your gonna need to get a service manual from the manufacturer and do a convergence alighnment with the on board generator. Unless some unknowing hands have been inside the unit.?? Contact them here at this link Good Luck service.us@viewsonic.com
Posted on May 10, 2006
Gurudristi
  • 98 Answers
SOURCE: dvd player to projector
Yes please.
You can connect it either thru the RCA Composite output(yellow) of your DVD or thru the S-Video or even thru the component out(YPbPR) connections. In the component out you would require three RCA cables and would give you the best possible picture.
Find a link below , which gives a review of the Viewsonic PJ 501.
http://reviews.cnet.com/home-theater-projectors/viewsonic-pj501/4505-7858_7-20722971.html
Hope this clarfies.
Please do rate this solution and thanks for using FixYa!
Posted on Mar 05, 2009
SOURCE: VIEW SONIC PROJECTOR IS NOT STARTING UP
Sounds like it needs a new bulb
Posted on May 05, 2009
  • 125 Answers
SOURCE: lamp and temp lights come on after power up and stay on. Lamp only has 330 hours on it.
OK, that explains it. The bulb you have installed in the projector might be the original bulb that came with the projecoter when it was new. Just becuase it states 334 hours does not mean it is new. In fact, you could have a original bulb with 3000 hrs and reset the hour timer on the projector, which means your 3000 hour bulb might have 3334 hours on it because the person who owned it before you, reset the hour timer.. Best bet, buy a new bulb and reset the hour meter and see what happens. If you have the same problem, then your ballest might needs to be replace which is rare...
Posted on May 30, 2009
I got a viewsonic pjd5111 projector used . it power on for aleaast 30 sec and shut down immediately temp light red and lamp light green . i hv tried everything .help
Check if there is a cooling fan. Is it rotating?
It is also possible that the filter is dusty and needs to be cleaned/replaced.
(all projectors have a cooling fan and a filter to prevent dust from reaching the lamp. A faulty fan or a reduced air flow may cause an overheat problem)
Aug 16, 2016 | ViewSonic Office Equipment & Supplies
What is the proper way to shut it off?
You need to let the projector cool down after turning it off before you turn it back on again. Wait 10 minutes, then it should turn on ok.
Jun 18, 2015 | ViewSonic PJD5111 Projector
When the projector not coming on the lights only blink what happen to it
check the lamp
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
Mar 02, 2014 | ViewSonic PJD5111 Projector
Wont turn on just flashing blue light
there are 2 reasons for it
1, defective lamp
2,the fans is defective
Feb 09, 2014 | ViewSonic PJD5111 Projector
The temp/lamp light flash and the fan turns on for about a second then the unit shuts off.
i have the same problem, been workign on it for a week now... someone says the color wheel might be off thus, noit detecting the correct RPM of the color wheel, and you will have to open the machine up and re adjust by hand. im about to take it apart now... wish me luck
Apr 01, 2011 | ViewSonic PJD5111 Projector
ViewSonic PJD5111 Projector Logo
917 people viewed this question
Top ViewSonic Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
