Question about Hotpoint HSS25GFP Side by Side Refrigerator
HSS25GFPA WW HOTPOINT REFRIG.
I have a hotpoint refrig. side by side and the dc evaporater motor went out so I thought so I changed it and now it still will not work. What else could be wrong with the fan or motor. The top of my freezer does not get cold, and the fan will not run.
  • 1,543 Answers
Please don't rate this solution because people generally don't rate well when it's bad news, even though the response is correct. When the DC evap. motor goes out, it can take out the motherboard. (located behind the small panel on back of the refrig.)
Posted on Oct 22, 2008
  • Carl Schulzetenberg
    Carl Schulzetenberg Oct 22, 2008
    Thanks for the FixYa rating. Hope you got your refrig. going.
Hotpoint HSS25GFPA WW Freezer not cooling
check for ice build up on evap coils ,,, bad efrost cycle
Oct 05, 2014 | GE Refrigerators
How much to repair motor on Hotpoint refrigerator?
You possibly have a failed condenser fan motor. If this is the case, you shouldn't have to buy a new refrigerator, as the repair should be under $150.00
Jul 24, 2014 | Refrigerators
After a moving to a new city, we had our Hotpoint model HSS251FMD WW refrig in storage for 4 months. When I installed it in our new house it will not cool. Is there a reset button?
flush the refrigerant by nitrogen & refile new refrigerant.every work doing by qualified technician.my be some compressor oil over com in freezer
Jan 03, 2011 | Hotpoint Refrigerators
Refrigerator makes ice and dispenses ice, but does
could be valve, it is located underneath on back. it also could be the mother board. Check valve with ohms metter. Also make sure water resevior or water lines are not frozen inside refrig section. Also water feed line going up through door bottom hinge on freezer is not frozen. Disconnect at couplin at left bottom front and blow through line
Mar 04, 2010 | Hotpoint HSS25GFP Side by Side...
Hotpoint hss25gfph ww evaporater fan is not running. something was clicking yesterday. fan spins freely when you turn it by hand. just replaced the condensor fan yesterday. it was locked up. fridge and...
You need to replace the main control board . One of the resistors , are burnt , keeping the DC voltage , from reaching the fan . Check to see if the fan will run off a little 9 volt battery . If so , replace the board . Pt # WR55X10656 . The board cannot be repaired ( with this problem ) and has to be replaced .
Nov 12, 2009 | Hotpoint HSS25GFP Side by Side...
Hotpoint HSS221FPA WW Side by side refrigerator runs continuously. coils are clean/replaced defrost heater. Even with refrig side turned off...keeps running
Howdy....Try changing the sensor to the themostat,or something is covering it so its not getting the cut off temp.
Jul 29, 2009 | Refrigerators
Fridge not colling-hotpoint HSS25GFPAWW SIDE BY SIDE
It could be one of many problems but will most likely be a refrigerant leak in the refrig evaporater
Dec 05, 2008 | Sub-Zero 650 / O Bottom Freezer...
My firdge is operating, but not cool nor freezing
Did he check it out and make sure its bad... these ge models are tricky... sometimes they take out the mother board with a bad evap fan motor.. seems like it should still be his problem to help fix, if his repair didnt solve the problem
Aug 28, 2007 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
387 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
