Question about Coffee Makers & Espresso Machines
Syntia Saeco....changed water filter,,but, I cannot get in to Programming Mode...always forces me to do the Descaling process , first......Michael, from Montreal.
  • montreal_mike Feb 10, 2012
    Syntia Saeco..model: ,,found solution to get to see "MENU"....step 1 = plug-in-machine,,to socket in the wall;,,step 2- do a "Power-ON",,in Back-switch....only,,not front....at the front-panel.."right"--coffee-bean = "MENU"...so faded,,you need sunlight to see,,the word at bottom-left-right( coffee-bean)....once pressed,,all the answers-to my questions,,,,I went and selected-next,next,next,,,until I reached Water-Filter screen,,then,,down-down,,to.."RESET"...then ESC....all went GREEN after that,,,been great ever-since--yesterday...first day,,after-2-weeks,,in red-light mode.
    Thank you,,
    Michael
SOURCE: Saeco incanto classic
Fille the water tank and let it continue. It will stop before the next tank runs out
Posted on Apr 04, 2008
  • 74 Answers
SOURCE: Saeco Odea Giro descaling problem
Ok first check if the machine is in greenlight state when you press and hold the water button, as it will not work when the red exclamation mark blinking.
also check if the button work at all flipping back and forth to hot water and steam.
I have never had this problem that it dident work.
But remember this, you dont have to do the descaling again as that has nothing to do with the reset.
You can even reset the descaling alarm with out having done the descaling.
If that for some reason wouldent work I would think its the CPU card is not working.
Posted on Jul 14, 2008
SOURCE: saeco wont stop descaling
In service menu there are 2 parameters you should look. First one - descaling - should be on 'done'. The second one is a counter - water used since last descaling - should be on 0.
Posted on Mar 23, 2009
SOURCE: My Saeco Italia is stuck in the descaling mode.
I had this problem too. I was beside myself wondering what to do. I took the machine apart but there was nothing wrong. It was stuck in an infinite descale cycle. The 5 green buttons never blinked to say it was done. What finally fixed it was to close the steamer valve to where water was being being restricted from the steamer wand but still a little water was spurting out. It finally quit emitting water and the 5 lights blinked and the infinite descale cycle completed. This model espresso maker was a lemon and been nothing but problems.
jeff
Posted on Jun 05, 2010
SOURCE: saeco syntia - error message 'problems with the
I read your post. Could you explain me this problem?
Me too have a syntia, but I never saw this error message.
What kind of symbol do you see?
bye
F
Posted on Jul 12, 2010
Saeco Syntia dumping dry ground coffee into dreg drawer without making espresso. **SOLVED** Follow up below.
First, I'm NOT a Saeco technician, But I have worked on similar machines. (I still have one in my garage along with other 'graveyard' coffee machines.) Check your warranty and call for service as there are no customer serviceable parts in this equipment.
*** the following is for information only ***
* I've taken these machines apart many times and found there are a lot of sensors in this unit. Many are very delicate and fault out easily. If you do locate the right sensor, you will still need to locate a replacement. Ordering parts can be a challenge as it must be the correct model (and serial number series). I found out the hard way that not all PC boards are the same as the change functions even in the same model.
* Okay looking around I came across a vid (link below) that shows in detail how to check all the functions of the model he has. You probably don't need to go through the descaling and other checks. The Bean grinder portion is very detailed and not for the faint of heart. But his instructions are clear and should be able to solve your problem. His "No Bean" error was caused by prolonged use without proper cleaning and someone spilt water into the bean cup long ago. I hope to try out his method soon as I never took apart the grinder section completely like he did. I only vacuumed the beans out.
Good luck (to all of us!)
Aloha, ukeboy57
https://www.bing.com/videos/search?q=Seaco+Syntia+no+beans&&view=detail&mid=7D35DEE54A6DBDC3688B7D35DEE54A6DBDC3688B&&FORM=VRDGAR
Feb 08, 2018 | Saeco Coffee Makers & Espresso Machines
Why after descaling my new Seaco Syntia coffee machine, it stops while brewing and it requires being primed over and over.
Syntia and Brera machines are made by Saeco. Brera is marketed under the brand name Gaggia (owned by Saeco).
The causes for this malfunction can be due to following in order as stated:
1- The machine was not descaled or it was descaled using products. that are labeled as descaler but they are not. After extended period of not descaling, one may have to use more than one cycle of descaling to remove accumulated depsits of Calcium in the water system.
2- The grind setting of coffee is too fine. Make it coarser by one notch toward coarser setting at a time.
3- The pump is losing its pumping pressure and not pudhing water through the coffee. Replace ULKA pump with an Invensys pump model CP3.
All fully automatic machines are convenient and make classic shots of espresso from bean to the cup at the push of a button. With this simplicity, owners forget its maintenance until machine stops working. Please pay attention to descaling every three months. No excuse is good enough.
Services Unlimited Inc Parts Guru
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
Oct 18, 2014 | Coffee Makers & Espresso Machines
I am looking for a manual to de-calc and clean in Saeco Vienna superautomatica sup 018
Descaling Saeco Automatic espresso machines SAECO VIENNA SUPERAUTOMATIC MACHINES:
SAECO VIENNA DIGITAL - MANUAL DESCALE PROGRAM
1. Fill the water tank with the Saeco descaling solution. (1 bottle of Saeco descaling solution to one full tank of water.)
2. Turn on the machine. Run approximately 1 cup through the steam wand by turning open the hot water steam valve). Turn machine off and let sit for 5 minutes.
4. Repeat this procedure until the water tank is empty. Then rinse water tank thoroughly and flush the machine by running two tanks of clear water through the steam wand.
5. To clear the "Decalcify" message on the Digital model, press the MENU/OK key to go into programming mode. Scroll up or down to select the "Signal.Descal" function. Press MENU/OK. Next, the messages " Quantity Water Not Reached" and "Left Quantity" will flash. Press MENU/OK again - the message "Reset Descaling Program - Yes" will appear. Press MENU/OK again. The Descale meter is now cleared.
SAECO VIENNA DIGITAL - AUTOMATIC DESCALE PROGRAM
1. Press the MENU/OK key to go into programming mode. Scroll up or down to select the "Descaling" function . Press MENU/OK key. Place a large container under the hot water/steam nozzle. Fill the water tank with Saeco descaling solution. (1 bottle of Saeco descaling solution to one full tank of water. Refer to the instructions on the bottle).
2. Then completely open the hot water/steam rotary valve/knob. The pump starts and the descaling program begins. During this phase the pump runs at intervals and the message "Machine is Descaling" is displayed. The complete program takes about 40 minutes. Do not add any water to the tank during this phase. When the message "Descaling Finished" appears, close the hot water/steam valve. The message "Rinse Machine" will appear.
4. Remove and rinse water tank thoroughly, fill with fresh water and replace on machine. Empty the container under the hot water/steam nozzle and replace. Flush the machine by running the tank of clear water through the hot water/steam wand until the message "Rinsing Finished" appears. Exit the Programming mode by pressing "MENU/OK" Refill the water tank with fresh water.
Descaling Single Boiler Home espresso machines (HOME SINGLE BOILER ESPRESSO MACHINES)
Approximately every 3 months (depending on your use and the water hardness), clean the machine with natural citric acid based decalcifying agent.
1. Add a descaling solution into the water reservoir. Mix thoroughly to dissolve (use warm water for better results).
2. Remove the filter holder and place a cup under the group head and another cup, or other container, under the steam wand to catch cleaning solution.
3. Turn espresso machine on, turn coffee pump on and run approximately 8 oz. of solution through the brew head. Turn machine off and let the machine sit for 15 minutes.
4.Run approximately 8 oz. through the steam wand, and again, turn machine off and let sit for 15 minutes.
Repeat by allowing solution to run alternately through the steam wand and brew head. Turn espresso machine off after each cycle. Repeat process until solution has been run through.
5. Do not leave espresso machine on. Do not wait for the ready light to come on. Do not use the steam switch during this process. Do not allow reservoir to run empty!
6. Rinse reservoir thoroughly with fresh water. Refill reservoir with fresh water. Run half a tank of fresh water through group head, alternating between group head and steam wand.
Feb 28, 2011 | Saeco Vienna SuperAutomatica Coffee...
Hello , I got a present of a Saeco Royal Professional without an instruction booklet . The machine tells me it needs a descale . Can you please advise as to how . Many thanks , Sean Kavanagh
Hi
Auto descale: To automatically descale your machine, press the scoop button and hold it down until you enter the menu. Use the arrows on the left to scroll down until you come to "Descale". Press enter and the machine will enter the mode to descale your machine. The process takes about 45 minutes. You don't have to do a thing except mix a full water tank with descaling solution and have a container under the steam wand when your start. If you have a cappuccinonatori on your machine you will need two containers. To start the descaling process simply turn the steam knob. When the process is over your machine will say "descale finished". Remove your water tank and rinse it out. Refill it with fresh water. Replace on the machine and close the steam knob then open it again to rinse your machine. When its done exit the descale mode and go to the "Reset descale" just under it and enter. Choose "Yes" and push the enter button to accept. It will tell you when it needs to be descaled again.
If you want to make your machine last a long time, go to the water hardness in the menu and change your water hardness to the #4 and always push the enter button if you want to make your changes permanent. If you don't, no changes will be made and it will still be the same when you exit.
Jan 06, 2011 | Saeco Royal Professional Espresso Machine
Saeco syntia - error message 'problems with the water circuit'
bye
F
Jul 11, 2010 | Saeco Coffee Makers & Espresso Machines
How to decalcify saeco royal exclusive coffee machine
Hi
Auto descale: To automatically descale your machine, press the scoop button or menu button if you have one, and hold it down until you enter the menu. Use the arrows on the left to scroll down until you come to Descale. Press enter and the machine will enter the mode to descale your machine. The process takes about 45 minutes. You don’t have to do a thing except mix a full water tank with descaling solution and have a container under the steam wand when your start. To start the descaling process, simply turn the steam knob. When the process is over your machine will say "Descale finished". Remove your water tank and rinse it out. Refill it with fresh water. Replace on the machine and start the descaling process over again to rinse your machine. Go back into your menu and scroll up or down 1 to signal descale and enter. Choose "Yes" and push enter so the machine will tell you when you need to descale again.
Jun 13, 2010 | Saeco Royal Digital Plus Coffee...
Looking for instructions on cleaning and servicing the Saeco Royal
When you clean the brewing unit wash it with hot water, do not
use any solvent.
Make sure there are no coffee residues on the two steel filters: the upper filter can be removed by unloosening and turning the plastic pin anticlockwise using the tool supplied.
Dry thoroughly each central unit component, fit the filter again and tighten it properly with the screw .
To do a descaling:
Saeco descaler is recommended; however, you can use any non-toxic and/or non-harmful descaling product for coffee machines, commonly available in retail stores. The used solution is to be disposed of according to the manufacturer’s
instructions and/or regulations in force in the country of use.
Never use vinegar!
Best regards
/Mirran
Nov 26, 2008 | Saeco Royal Digital Plus Coffee...
Machine won't stop descaling cycle
MAKE SURE YOU DO NOT SHUT DOWN YOUR ESPRESSO MACHINE WHILE IN THIS MODE OR IT WILL INTERRUPT THE CYCLE. BE SURE TO CAREFULLY UNDERSTAND WHAT THE MACHINE IS ASKING FOR AND USING THE MANUAL MAY HELP YOU WITH THIS PROBLEM. WE HAVE NOT SEEN ANY OF THE PROBLEM YOU ARE SUGGESTING, BUT THERE IS ALWAYS A FIRST. IF YOU NEED SUPPORT AND YOUR MACHINE IS LESS THAN 1 YEAR OLD CONTACT SAECO AT 800-933-7876.
IF YOUR PRIMEA IS OLDER THAN ONE YEAR YOU CAN CONTACT CERINI COFFEE @ 718-584-6120 OR VISIT OUR WEBSITE AT WWW.CERINICOFFEE.COM
Oct 30, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
How do I descale the saeco magic deluxe coffee machine?
Try this:
Standard descaling
Switch off the machine.
Pour a descaling product into the water tank.
Switch the machine on to the programming mode(see below). Place a large container under the steam/hot water dispensing tube and open the steam/hot water knob slowly, turning it counterclockwise.
Turn on the machine by pressing the main switch and let the descaling product flow out of the dispensing tube for approx. 1 min.
Close the knob again.
Turn off the machine with the main switch and let the solution take effect for approx. 5 minutes.
Repeat this procedure two or three times, to allow all of the descaling product in the water tank to flow out of the dispensing tube.
As soon as descaling has been carried out, rinse the tank thoroughly and fill it with fresh water.
Switch on the machine and let fresh water (approx. 2 l) flow out of the steam/hot water dispensing tube in order to rinse away residue.
The machine is now ready for operation.
When the machine is on, the warning light switches off automatically, by pressing the steam selection button for at least 5 seconds.
To enter the programming mode, turn the machine
off with the main switch.
Press steam , espresso coffee and the
main switch at the same time.
Release the buttons.
Hope this will help you.
/Mirran
Aug 16, 2008 | Saeco Magic De Luxe Espresso Machine
I want descalcificacian saeco easy sup 021ye what butons y press?
Warning! Never use vinegar as a descaling agent. You can use any commercially available non-toxic, non-harmful descaling product for coffee machines.
Descaling is necessary every 2 months; should water be very hard, descale the machine more frequently. The machine must be on; it automatically controls the distribution of the descaling solution.
  1. Switch off the machine.
  2. Fill the water tank with the descaling solution.
  3. Place a large receptacle beneath the steam tube.
  4. Switch on the machine.
  5. Open the knob.
    The descaling process starts.
  6. Dispense the descaling solution into the receptacle.
  7. After about 30 seconds close the knob.
  8. Switch off the machine and remove the receptacle.
  9. After 10 minutes, follow instructions 1 to 8 to the water tank is empty.
  10. Rinse out the tank and fill it with fresh drinking water.
  11. Place a large receptacle beneath the steam tube.
  12. Switch on the machine.
  13. Open the knob to rinse.
  14. If the receptacle fi lls, empty it.
  15. When no water is left, turn the knob to close the valve.
    Remove the container.
After descaling the machine, reload the machine circuit. Install the cartridge filter again in the water tank.
Jul 23, 2008 | Saeco Easy Espresso Machine
Coffee Makers & Espresso Machines Logo
126 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
