Tally Genicom Don't stop printing
I have one Tally Genicom 6615Q connected at AS/400 through TCP/IP, my tally is printing with IBMproprinter emulation and is working fine, the problem is that is not responding to hold job commands from the AS/400, i don't know what is causing that, the users send one order of cancel printing and the printer don't stop, did you know what is causing that problem? Thanks
4 Suggested Answers
SOURCE: paper width error on tally genicom 2280+ printer
Power ON printer holding down ONLINE button, release it after TESTMENU is on display. Press NEXT few times, enter APM or somthing like that (or APW? cant remember), switch it to OFF. Press ONLINE. Thats it! Greetings.
ps. this is procedure direct from polish division of tallygenicom servicedesk. it works for me perfectly!!
Posted on Jan 28, 2009
SOURCE: "check ribbon " error is comming on my tally 2280+ serialprinter
The ribbon I had installed (code 061627) which says it is the correct one is in fact not. the drive pin on the printer slips while feeding the ribbon.
I have fitted a (code 062471) and now it is printing fine again.
a google search reports both these codes as compatible but they are quite clearly, not.
Posted on Mar 11, 2009
LineMatrix
  • 34 Answers
SOURCE: how to configur tally tcp/ip address
take printer offline
press mode button
scroll up or down until you see TCP/IP displayed, then press the # 1 button
TCP/IP address is displayed, then press # 2 button
IP address class A is displayed, then press # 3 button
scroll up or down until you see 192 press enter for *
next press # 2 button again scroll until IP address class B is displayed, then press # 3 button again
scroll up or down until you see 168 press enter for *
next press # 2 button again scroll until IP address class C is displayed, then press # 3 button again
scroll up or down until you see 145 press enter for *
next press # 2 button again scroll until IP address class node is displayed, then press # 3 button again
scroll up or down until you see 69 press enter for *
You need to repeat this procedure for the Subnet mask and Gateway...
I'm sure you have fixed your problem by now, considering your request was Mar 19, 2009
Have any questions
Call x311
Posted on May 11, 2009
Why can't I print through a Tally T5040 printer?
Tally genicom 5040 passbook printerre download the drivers and make sure you have a good connection (USB )
Mar 21, 2012 | Office Equipment & Supplies
How do i find the IP of 9022 Monochrome Laser
First, are you sure you have network capability. This is an option. Since there is no control panel display on this printer, you'll have to use the configuration software provided by Tally Genicom.
Jul 20, 2011 | TallyGenicom 9022 Laser Printer
Tally 2265 is showing AGA error.
Has something to do with the Automatic Gap Adjustment. Owner's manual says:
For more detailed information, refer to the Reference Manual on the Online CD-ROM, which I do not have (I only have the owner's manual).
You may have to talk with tech support at 800-774-2248. This will be Printronix (bought Genicom and Tally).
Jul 18, 2011 | Tally Dot Matrix T2265C Printer
T6312
The problem coming from your logic card hammer bank cable . Need to be replace logic card and hammer bank cable.
May 19, 2010 | TallyGenicom 6312 Matrix Printer
Problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
Apr 20, 2010 | Tally T6218 Matrix Printer
How to configur tally tcp/ip address
press mode button
Have any questions
Call x311
Mar 19, 2009 | Tally Line Matrix T6100 Printer
Tally T8106
The T816 can be used with Vista and XP over a Ethernet connection....You will not however be able to 'discover' the printer on the network.You need to set an IP Address in the printer or if the printer has been allocated a DHCP address you would need to find out what address has been allocated.
Once you know the IP Address you would need to install the printer on a PC/Server then share it to other users to be able to 'see the pritner on the network'
Once the pritner driver has been installed you can create a network port in the pritner driver to print to the IP Address of the pritner in the follwing way (on XP, Vista will be simmilar)
· Open PRINTERS folder
· Right Click on the printer driver for the T8106
· Select PROPERTIES from pop up menu
· Click on the PORTS tab
· Click on the ADD PORT button
· Highlight STANDARD TCP/IP PORT
· Click on NEW PORT
· This should open the TCP/IP Printer Port Wizard, work through this entering the IP Address and Port Name. Windows may try to detect the port configuration required.
· If the type of port is not automatically detected click on the CUSTOM radio button.
· Click on the SETTINGS button
· Change the PROTOCOL to LPR
· Under LRP SETTINGS enter the Queue Name as PASS
· Click OK.
· Click NEXT and then FINISH to finish the TCP/IP ports wizard.
Oct 27, 2008 | Tally T8106 Laser Printer
Paper width error on tally genicom 2280+ printer
Mar 12, 2008 | TallyGenicom 2280 Matrix Printer
67 people viewed this question
k24674
jasbo
jasbo
