Question about Oakley Thump 2 MP3 Player
Connection not recognized
I connected my thump pro to the computer so that it would charge but it does not seem to recognize that a connection has occured. There is not light - red or otherwise - nothing seems to be happening.
  • tweiding Apr 12, 2009
    Like miata148, I often have difficulty getting my Thump Pros to connect with my computer. Usually, this occurs when the battery is very low (to the point of turning itself off). I've left them connected overnight, but no light, no connection, etc. The only way I've been able to recover is to allow the battery time to recover enough to turn on, then quickly connect to the PC. Any thoughts?
    New Friend:
  • 9 Answers
The led should come on even without a battery installed, its either sweat damage to the USB connector, micro fuse, corrupt firmware or logig/flash ic sweat damage. Try using a standard mains USB charger and see if the led comes on, The glasses have two charging circuits, not sure if it was design flaw but when connected to a computer USB it will charge using the + & - data lines instead of the + & - power line.
Posted on Apr 27, 2014
I have often had the same problem. Resetting the software enabled me to recover. Press and Hold the Play/Pause (center) button and the Previous Song/Rewind (rear) button•at the same time. I held it for about 5 seconds. Then I released both buttons, then pressed the Play/Pause for about 1-2 seconds, the unit powered up and I was able to connect and charge the unit.
• If the reset procedure does not work, you may need to restore the internal software.See your .pdf users guide, this will erase your song list.
Good luck.
Posted on Apr 12, 2009
It wont connect with my computer
Search Results
    My laptop does not recognize my mp3 player [Solved] - CCM
    ccm.net > Forum > Hardware > Laptop
    Jan 18, 2013 - Connect the player, open device manager, right-click on WALKMAN under .... my sony mp3 walkman,my computer dont recognize it,i cant upload my .....Does not charge. is not recognized by windows media or My Computer. My computer does not recognize my mp3 player.
    Nov 16, 2014
    I cant get my songs to my mp3 player
    Oct 11, 2013
    Sony Mp3 Walkman is not getting Detected !
    Oct 31, 2012
    More results from ccm.net
    My PC does not recognize my MP3 player - CCM
Jan 06, 2016 | Audio Players & Recorders
Coby mp3 player
Try to reset it if possible.
If the computer charges it then the computer recognizes it as a connected device. That's how usb works. It could be you need a new USB cable. Many devices that use USB for charging do not have the data leads connected in their cables. This is called a "vampire" connection as it only sucks 5 volts DC from the computer/charger .
Apr 03, 2014 | Coby MP-705 Digital Media Player
HS-M701-4GB not recognized when connected to USB port.
try loading the drivers for it before hooking it in
Sep 17, 2017 | Computers & Internet
My ipod not recognized by itunes in order to reinstall the software
Connections b> The USB cable must be securely connected both to the iPod and to the selected USB port on the computer. Reattach the cable at both ends, and click "Computer" in the start menu to see if the iPod is shown connected to the drive for that USB port. b> Drivers b> If the drivers of the computer responsible for the USB interface are out of date, malfunctioning or incorrectly installed, that may also cause the iPod to not be recognized by the computer. If this is the case, the device may not appear in iTunes and there may be an exclamation point next to the device in Device Manager. b> Software b> The latest version of iTunes is recommended to best communicate with the various models of iPod. Go to the iTunes website or click "Help" and "Check for Updates" in iTunes to install the most recent update. Further, the computer must be running Windows XP, Vista or Windows 7 for PCs, or OS X v.10.4.11 or later for Macs. b> Battery b> The iPod's battery must have sufficient charge to be recognized in iTunes; charge it either via USB connection or another power source if the indicator shows a low battery. Once the battery has charged, try to connect the iPod to the computer via USB cable again.
http://support.apple.com/kb/TS1538 Ipod not recognized http://support.apple.com/kb/TS1495 Device not recognized
Jan 24, 2013 | Apple iPod classic MP3 Player
My sony nwz-s638f is not charging if i put it in the plug how can i make it work?
Please make sure that the Computer is recognizing the Walkman when connected to the USB port.
Make sure that you're using the supplied USB cable for connecting to the Computer.
If you use the portable player for the first time, if you have not used it for a long time, or the battery is depleted, it may take up to 5 minutes for it to be recognized or start charging. On models with a display, the display will remain blank. If it the portable player is not recognized or does not begin to charge after waiting 5 minutes, reset the player by pressing the reset button.
Disconnect the USB cable from the portable player and then reconnect.
Check the connection status again.
Disconnect the USB cable from the computer and then reconnect.
Check for available space on the player using Windows Media Player or My Computer.
Restart the computer.
Check that the USB cable is firmly connected to both the computer and the player.
If the player is connected to a USB hub, disconnect it and connect it directly to the computer with a dedicated USB cable.
If the player is still not recognized by the computer, disconnect all devices connected to the computer with a USB connection and restart the computer.
After the computer restarts, connect only the Walkman player and test the connection again.
If the player is still not charged by the computer, try a different USB port.
Thanks for using FixYa.
May 05, 2011 | Sony NWZS638F Digital Media Player
Seagate free agent pro 500 gig external hard drive NOT RECOGNIZED
You better check with the Seagate people. This seems to be a problem with the casing. And since you're under warranty, you can get a replacement.
Aug 28, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My Computer and iTunes does not recognize my iPod
put your ipod in disk mode by following these steps.
press and hold the Menu and Center buttons on the clickwheel. when you see the apple appear, switch your fingers to the center and play/pause buttons.
whena check mark appears plug it into you computer and it should detect and mount.
add music and have fun.
May 24, 2009 | Apple Ipod Nano Second Gen. Green (4 GB)...
Try the link below that applies to your computer OS:
http://support.apple.com/downloads/iPod_Reset_Utility_1_0_3_for_Mac
http://support.apple.com/downloads/iPod_Reset_Utility_1_0_4_for_Windows
Useful troubleshooting-video:
http://www.apple.com/support/ipod/tutorials/troubleshooting.html
Feb 27, 2009 | Apple iPod nano
Driving Force? Pro pedal set problem PS2
my ps2 games dose'tn recognize driving force pro any more.so do need to replace my broad on the in side of my driving force pro.because all testing that dun piont to the broad.
Dec 22, 2007 | Logitech Driving Force Pro (963293) Wheel...
Oakley Thump 2 MP3 Player Logo
348 people viewed this question
Top Oakley Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Oakley Audio Player and Recorder Expert? Answer questions, earn points and help others
