Question about Delta Home
Water flow restricted on delta t17 series shower head
  • 1044 Answers
SOURCE: low water pressure in grohe hand held. Is there a
1 Check if the holes in the hand held shower are not clogged with scum which generally happens over prolonged use. Clean them with a pin. 2 If this does not help, then check the the pipe connecting the shower to the water outlet. It should be clean and not clogged with foreign material which restricts the flow of water. 3 It still it does not help then you may have to fix a booster pump or raise the level of the water reservoir.
Posted on Dec 20, 2009
  • 102 Answers
SOURCE: Water leaks from the shower head. I have a delta
You may want to replace the ball or cartridge whichever the case may be. Also be sure to use Genuine Delta parts as they will hold up much better than the aftermarket parts. I hope this helps.
Posted on May 27, 2010
  • 81 Answers
SOURCE: Low shower head flow from Delta R1824 shower
Try exchanging the Delta head with one of the other shower heads you are happy with if you haven't already done so. No change in the flow means it's not in the head, and change means it is.
If it is in the head, since you are on a well and not a municiple water supply, you might consider removing the factory install flow controll device located just below the threaded area that mounts to the shower arm. These inserts can be a real bugger on some heads and each one is a little different than the last. The trusty nail often works well.
Your body sprays, I believe, are factory fixed at something like 2.2 gpm and non adjustable.
Also consider for a moment a garden hose with trigger spray head on it. When you squeeze the trigger the water will shoot out a certain maximum distance. If you were to take an ice pick and poke a hole in the hose, that maximum distance will be slightly reduced. The more holes in the hose the less the maximim distance. Correspondingly, the more holes you poke the less distance each hole will squirt because you have the same pressure and volume of water but more exit points.
A monitor has a flow rate of about 6 gpm at 85 psi which is pretty average for shower valves. If your other showers have only one exit point(i.e. one head) and the R1824 has 3 with the same pressure and volume, the garden hose illustration can also explain the volume change as well.
Posted on Jun 01, 2010
  • 81 Answers
SOURCE: The water comes out of both the shower head and
I will have to assume this issue developed and was not present at first use after the initial installation.
There are generally only two reasons for your problem. The first is that the diverter mechanism is simply wearing out and/or broken. The second it that there is a foreign object preventing it from doing its job correctly. Either way the diverter must come out. I have provided a couple of links below that should help get it out.
Once out, put a wadded up towel over the end of the tub spout opening so as to prevent any water from coming out of it. Then, for just a moment, turn your shower on full and adjust your temperature from full cold to full hot. This process should dislodge any foreign matter and send it out the opening the diverter came out of and also will probably get you wet. I usually plug the tub so I can catch what, if anything, comes out. Having a second person holding a bowl over the diverter opening helps reduce the water splash.
Rinse off the diverter and reinstall it. Turn the shower on and see if there is any difference in how much water comes out the spout while in the shower mode. If nothing has changed then the next step is to replace the diverter.
The diverter assembly part number is A603819
http://www.danze.com/products/pdfs/D113000_ip.pdf
http://www.danze.com/products/pdfs/D500058T_ip.pdf
Posted on Jun 02, 2010
  • 61 Answers
SOURCE: I just installed my Delta Multichoice Valve Trim
If you look inside the shower head from the back where the threads are you can see a flow restrictor, if you take it out you get a lot better flow.
Posted on Jul 01, 2010
Where can I get a shower head that doesn't restrict water flow?
If your problem is low pressure, your best bet is a pump. not sure if you can get them where you are. Are you in the USA?
Try Canadian shower heads.
Shower Pumps High Quality and Performance bathstore
Dec 06, 2015 | Home
I just installed a new shower with no tub. I have water to my delta fixture but no water out the head. I used shark bite connectors and did not solder the fittings
Are your walls still open? I assume they are as you'd be unlikely to close them up without having had tested your water flow. Here is what I would do.
1.) use the orange plastic C shaped release tool to depress the white plastic ring on the shark bite fitting that you have on the delta side of the Delta-ShowerHead connection.
2.) Carefully and slowly turn water on and see if water is exiting the fixture where you expect it to.
IF yes, water is coming out of the delta fixture then you know the flow problem is somewhere between the delta fixture and your shower head.
IF no, water is not coming out the delta fixture then you need to re-access how you connected the supply lines to the delta fixture.
Oct 24, 2014 | Delta & Single Handle Shower Faucet
Hansgrohe shower head water leaking out of connector
Is it a Grohe or Hansgrohe shower head? If it is a Hansgrohe shower head the first thing to check is if the self sealing filter gasket is installed at the connection to the shower arm. Hansgrohe shower heads have a black self sealing filter gasket in the head that some people remove assuming it is a flow restriction device. It is only a filter and does not restrict flow unless clogged with debris. Next make sure the flow restriction device below the filter gasket is still installed. On some models removing the flow restrictor will cause water to be expressed from the air injection ports near the pivot ball. Feel free to contact me at Hansgrohe. 1-800-334-0455. Press 2 for Technical and ask for David Scarborough
Aug 20, 2012 | Grohe Home
Flow rate on delta thermostatic valve
the two screws are service stops open them all the way
Jun 09, 2012 | Delta & Single Handle Shower Faucet
Shower water pressure is dismal at best, girls cannot get soap out of hair, is there a way to adjust amount of water coming out of shower head, we have a delta monitor single valve assembly.
Yes, try changing the shower head and do not get one of those water saver heads...and even if you get a regular one take out the flow restrictor before installing it if it has one....it will be just inside the thread part and wil be a plastic or rubber piece with a small hole in it to slow down the water flow...
heatman101
Sep 08, 2010 | Delta & Single Handle Shower Faucet
May 30, 2010 | Delta Home
Is there installation instructions available
The obvious next step is to remove the head and turn the water back on. If you get a good flow then the problem is in the head so sheck for particulate in the area where the threads are. With all the flow restrictions already built in it wouldn't take much to shut down the head.
May 29, 2010 | Delta & Single Handle Shower Faucet
Home Logo
35 people viewed this question
Top Delta Home Experts
Mike
john h
Tim Whalen
Are you a Delta Home Expert? Answer questions, earn points and help others
