Lcd monitor clicking
Monitor about 6 years old. Has PC-in and DVI-in sockets. After several years working fine using the PC-in connection, the monitor started making a clicking sound upon start-up and took a while to finally display anything on the screen. This persisted for a couple of months, gradually getting worse (i think) - the time between the computer starting and the monitor display actually showing anything became longer - until finally it never got to the point of displaying anything - it just stayed at the clicking stage with a blank screen. I switched from using the PC-in to using the DVI-in and everything was fine for a few more months before the exact same thing happened again, except this time with the DV-in rather than the PC-in. Would like to avoid putting the monitor in landfill if at all possible, and kinda suspect this would be fixable by someone who knew what they were doing... Any advice. Can take monitor apart and provide pics if necessary. Thanks!!! George
  • 1 more comment
  • george_d_dan
    george_d_dan Feb 07, 2012
    Monitor is a DIGIMATE L-1918 19" TFT LCDmonitor
    PCM-LCD-191883EUKD
  • george_d_dan
    I've read blogs describing fixes for similar problems, but the solution(s) seem to be product-specific. Anyone able to help - as i said, i can dismantle the monitor and upload photos if necessary.
  • The Knight
    The Knight Feb 08, 2012
    Hello
    You should have its full service manual to proceed. Try to get it from anywhare. But, If you haven't any idea about the wrking of its internal circuit, you never suceeed. All tools to open it are needed.
    Top Expert:
  • Computers & ... Master
  • 75,462 Answers
Hello
According to your detailed description, there are two chanses for this fault. Either its LCD panel of backlight inverter baord has some kind of short circuit. Detailed troubleshooting should be done. It is a highly skilled work. OK.
Posted on Feb 07, 2012
Have A Samsung 940Bw connected via DVI connection and has worked fine for last 3 years. Monitor was on and working fine went out of room and came back to black screen and the blue light flashing on the...
First thing I would try will beusing this monitor with another PC using the same the same setup to see if it works OK. We need to narrow down the cause of the problem first since you have three parts that can be bad; Monitor, DVI cable, PC Video card/PC. It is just a process of elimination to locate the problem.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Apr 14, 2011 | Samsung Syncmaster 940BW LCD Monitor
Acer AL2216W 22" LCD monitor. DVI input apparently
Not Good..
After you've checked that the video cable is connected properly, make sure that all the pins in the video cable plugs are straight and not broken off. Then test on another PC. Make sure your CMOS battery has not gone flat, as some PC's will fail to load basic drivers if CMOS memory is lost. The battery should show no less than 2.5v, if it's marked 3 volts when tested on a multimeter. If you can't test it, just buy a new one at the supermarket or hardware, usually around $4.00.
Next thing to try is your Video Card . If it is an on board one like most are now, there isn't anything you can do but try another card in an expansion slot or fit a new motherboard. At this point, I'm sad to say, you're better taking it to a PC shop where they will have a few things at their disposal to try.
Jan 30, 2011 | Acer AL2216W LCD Monitor
You may have problem in the logic board, it uses surface monted components no much chance for DIY repair.
Service manual; http://elektrotanya.com/?q=showresult&megnev=Acer&megnev2=AL2216W&kategoria=monitor&kat2=all
The cases these days are hard to open, they use plastic finger hooks types, they go in easy but real hard to remove without damageing them.
Use thin flat blade to crack open at the bottom edge so the scratches will not be so noticeable, and work your way around, look out for cables attached to the front bezel also.
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Please leave rating if it helps.
How to connect Samsung 40" LCD tothe eMachine desktop T2615. It looks like there is only one connection for a monitor? The computer is about 6 years old.
Older LCD TV's have a variety of inputs, one of them being VGA, to connect to your PC. The problem seems to be that you either connect your PC to its own monitor, OR to the TV, but not both? If that's the case, you may have a couple of alternatives:
The most expedient one would be to get a VGA splitter cable; the other, more expensive: replace your video card with one that has dual outputs: either one with two DVI ports; one with one DVI port and one VGA port; or one with one DVI port and one HDMI port. As you can tell, there are several possibilities, depending on the connectors available on your TV.
Sep 08, 2009 | E-Machines eMachines Desktop PC
Nothing on the screen at startup
If you cant get into the setup menu then I would think the monitor is defective,you did not state if you hooked up the monitor to a computer that has a vga port that works.
Jul 21, 2009 | LG 22" FLATRON LCD Monitor
I have an LCD 1970GX monitor. I had to get a new
Your NEC 1970GX monitor as two video inputs; an old-school VGA socket (socket and cable connectors usually coloured blue), and a DVI-D digital socket (socket and connectors usually coloured white). Purchase either a new VGA-VGA cable, or if your PC has a white DVI-D socket, a DVI-DVI cable, both relatively cheap options and test this simple option before any further troubleshooting. Many computers and monitors will go to sleep (automatically switch off) after not being used after an adjustable period of time. If this is your problem, you will need to adjust the setting (in power options of both the monitor and PC) to a setting suitable to your usage. You can also, in power options, usually turn off "automatic sleep".
Oct 08, 2017 | NEC Computers & Internet
Monitor Problems
Borrow a DVI cable from some friend and test it, just in case.
If you want to use multiple monitors, ensure you are using the right settings. Go to control panel>> Display,
open the Display properties box, click the last tab at the top right hand corner, and chose advanced see here for XP, Vista is similar:
Windows XP: Learn how to expand your workspace with multiple monitors
Sep 09, 2008 | Dell E207WFP LCD Monitor
DVI connection fault
I had the same problem, you must call Viewsonic to change your screen. The DVI input on the screen is dead.
Jul 08, 2008 | ViewSonic VX2255 Monitor
DVI cable not working
If you still have your old monitor plug it back in for a bit and load the drivers for the new monitor (from the disk which came with the new monitor). Right click on your desktop and choose properties and set your display resolution to something like 1024 x 768. Shut down the pc and connect your new monitor to it with the dvi adapter. If it is recognised ok you can then set the resolution from 1024 x 768 to the recommended amount for your new screen. The refresh rate is also important as some lcd screens only work at a certain level. There should be an auto switch on the monitor and if you press this it sets the display to optimum, - or should do.
Mar 21, 2008 | Computers & Internet
DVI input on monitor not working
Contacted viewsonic about this issue- they suggested- have both dvi and vga hooked up to same machine. start with poweroff on both. power on monitor, then power on computer. when you see display coming from the vga, power off pc, then disconnect vga cable, turn off power to monitor, disconnect power cord from monitor for 5 + seconds, reconnect power cord, power on monitor, then power on pc.
If this doesn't work to get the dvi working, (as happened to us) we returned our monitor for a replacement, since it was still under warranty.
Sep 17, 2007 | ViewSonic VX2025wm 20.1" LCD Monitor
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
