Question about Navman F20 GPS Receiver
Can I connect the wires from a car charger to the connections under the unit ?
The USB socket is totally trashed - tracks ripped from the circuit board too.
But the unit works - just no way to charge it -
I am on a very tight budget so I wondered if it was possible to connect the wires from the usb car charger to some of the connections under the unit.
Any other suggestions to charge the unit welcome - sending it for repair will be too costly I think
  • Anonymous Nov 22, 2008
    The usb port of my Navman F20 is broken. Should I connect directly the charger to the battery ? Or if anyone has a solution, please share with me.
    Marc
An alternative is to use a navman P1 "hotshoe" This allows charging to be carried out through the bottom strip connector.
Available from Magicgadgetz at a cost of £20
Posted on Dec 09, 2008
You can re route the battery wires from inside to external charging device, see if that works , worked for me
Posted on Nov 05, 2008
Unit does not light up
Check the input voltage terminals for power from your array. if there is no power at the input terminals, remove the wires from the controller and check for voltage again on the input wires. If there is still nothing, trace them back and keep checking each connection all the way to the panels. May be a bad connection or wiring. If you have input to the controller, it is being grounded for some reason or the circuit is open. Look for a fuse or reset on the controller. The controller its self may be bad.
Dec 22, 2013 | Morningstar ProStar PS-15M-48V, 15 Amp 48...
How can I get my Maxwest Tab-9100 to charge?
This can happen when a faulty charger isn't providing enough voltage/current. Faulty chargers can provide enough power to trigger the 'Charging' indicator and maybe even to power the unit but not enough to energise the units charger circuit. Try another charger (same voltage) or charging it through the USB socket.
Jun 05, 2013 | Other Maxwest Telecom TAB-9100 Wi-Fi...
Charger or USB connection not recognized by phone
unless your USB wire is not in a good condition or faulty i would say most likely your phone USB socket is very dirty or damaged partly, i would recommend replacing it.
Sep 22, 2017 | Samsung Galaxy S GTI9000 Smartphone
The wires come off the pump so i put them back on now i got nothing working
Also,
please note that all electrical wiring and installation details given on diydata.com is for information purposes only. From 1st January 2005, the Building Regulations Part P requires, in England and Wales, that only certified persons can carryout electrical installation work, or the work must be certified upon completion - see this page for more details.
Ring circuit
(1) The ordinary wall sockets around the house are normally connected to a ring circuit (also referred to as a ring main). The ring circuits of a domestic property supply the socket outlets and fixed appliances in the premises.
(2) The 'ring' is formed by the cable going from the consumer unit to the first socket, then on to the second socket and then the next socket etc. until the cable returns to the consumer unit. This means (in simple terms) that every socket on the ring circuit has two cable routes back to the supply. The cable of the ring circuit consists of a red (live) wire, a black (neutral) wire and a bare copper earth wire, all three being enclosed by an outer PVC sheathing. The cable used in domestic ring circuits is either 2.5sq mm or 4.0sq mm twin core and earth, these are rated (in free air) at 24amps or 32amps respectively.
(3) Each ring circuit is protected by a 32 amp fuse or trip fitted in the consumer unit. Modern installations incorporate a Residual Current Device (RCD) before the consumer unit which trips the whole system off if a fault is detected.
(4) In older houses the cabling for ring circuits (and other circuits) may be fed through the wall cavity with the cables coming into the back of the wall mounted socket. This is unacceptable in new premises and extensions. It is now considered that cables within the cavity may become wet causing the insulation of the cable to break down and moisture running down the cable into the socket. When rewiring older houses, new cables should not be run through the cavity, they should be run through new ducting embedded in the inner wall surfaces or under floorboards.
(5) A ring circuit is considered to be rated at 30amps (7200 watts). A ring may serve up to 100 m sq of floor area and, in theory, may have any number of sockets outlets or fused connection units connected to it. With each socket outlet is normally rated at 13 amps, as a 'rule of thumb', they are limited to under twenty outlets, it is unlikely that the variety of domestic appliances being used at any one time will exceed 30amps. The length of cable used in a ring circuit is limited to 50 metres for circuits protected by an MCB. The sockets are normally mounted flush with the wall although surface mounted boxes are often easier to fit when sockets are added to the circuit. .
(6) High power electrical appliances (such as cookers, showers etc.) should not be connected to a ring main even if they use less current that the 30 amp rating of the ring circuit. Connection of such appliances will reduce the number of other appliances that can be use simultaneously and will lead to nuisance trips at the consumer unit.
(7) It is advisable to have at least two ring circuit in all premises, in multi floor houses, one for each floor. The kitchen may have a large number of electrical appliances so a separate ring circuit for the kitchen may also worthwhile, this has the added benefit that a freezer will not be affected if there is a fault elsewhere. A single ring circuit should serve a floor area no greater than 100sq m (or 120sq yd).
(8) In the UK, plugs used on a modern ring circuit have square pins and each plug is fitted with either 3 or 13 amp fuses. The correct fuse should always be fitted to suit the appliance, 3 amp fuses for appliances rated up to 750 watts, (lamps and clock radios etc.) - 13amp fuses for larger appliances up to 3000 watts.
(9) Spur extensions can be connected to the ring circuit. A spur is a socket connected into the ring by a single cable run so the socket does not have the full benefit of two cable routes to the consumer unit. Spurs are often used when a socket is added, it is easier to connect using a single cable rather than extending the ring circuit to include the new socket. A spur extension can be connected to the ring circuit provided that it supplies only 13 amp socket outlet (although that can be a double socket outlet) or one fixed appliance. Over the whole ring, the total number of spurs must not exceed the number of socket outlets directly on the main ring. No more than two separate spurs may be connected from each outlet on the ring.
Removal of the front of a wall socket will give an indication of the circuit connected to it:
A single cable connected to the terminals indicates that it is an existing spur.
Two cables may indicate either that it is on a main ring circuit OR that it is a spur with another spur connected to it. This is not a recognised configuration but possible if both spur sockets are single sockets.
Three or four cables normally indicate a socket on a main ring circuit with one or two spurs running from it.
If the wiring has been changed by a previous diy'er, it may be possible to identify any added cables and then deduce the original circuit.
Ring circuit fused outlet units
Where connection to a fixed appliance is required, a fused outlet unit may be fitted to the wall (rather than a plug socket) and connected into the ring main. These outlets require the correct fuse rating for the appliance and are connected to the appliance by a cable or flex. The outlet may be switched or unswitched and may be fitted with an indicator light to show when the supply is connected.
Where a flex is taken to a heater of any sort (e.g. night store heater) the flex must be of a special 'high temperature' type suitable for the elevated temperatures encountered. Use of ordinary flex will result in the insulation breaking down causing the flex to become dangerous.
A clock outlet is a similar type of unit, but with a small fuse fitted in a special plug connected to the flex. The plug may be retained in the socket by a screw or knurled thumbscrew. Though called a clock outlet, they are also suitable for other small low current appliances such as extractor fan units, door bells.
High Power circuits.
Within domestic premises, there may be a number of high wattage appliances, the most common being an electric cooker, immersion heater and electric shower. Each of these appliances should be connected to the consumer unit using a dedicated fuse/trip and cable run. The installation instructions for the appliance should detail the wattage of the appliance (which will also normally be shown somewhere on the appliance), the amperage of the fuse/trip and the size of cable required. Any switches on these circuits must also be of a suitable current rating. Source(s): http://www.diydata.com/planning/ring_mai...
May 17, 2011 | Hoover Washing Machines
I have a Motorola gps that fell and landed on the usb charger plug and broke the pin off the board. the battery is a sanyot0052 with 4 wires . Can you tell how i can charge this battery via the 4 wires so...
Don't try and charge the battery directly, as it is a lithium battery it can explode if not charged correctly.
You can try connecting (soldering) wires to the circuit board where the socket was connected to feed in 5V from the power adaptor or USB lead.
Mar 08, 2011 | GPS
Hi, I have simple been told by my mobile service network that my track has been damaged. No further details? I took it in as the actual problem with the phone was the charger was not makeing a...
They mean that the charging socket that connects on the circuit board is damages and the printed circuit tracks are broken or circuit board is broken and cannot be repaired.
Jan 04, 2011 | Cell Phones
I can see the songs on my computer that I have uploaded onto my SanDisk and I can also add new music as well, But the system will not charge and when I connect it to the USB cord it says connected but it...
ensure the unit is chargeable using usb data cable, usb charger has only 2 out of 4 wires connected to the charger whereas when the cable is used as data cable all the 4 wires are connected and the device acts as a usb device, this may block the charging of the device due to internal circuit design within the device.
Oct 08, 2009 | SanDisk Sansa Clip MP3 Player
Power button failure
There is a well known issue with power switch failures on this unit. It happened to me as well. I have heard that you can power the unit on with the car charger or if you plug it into the PC using the USB interface. I will try this tonight and report back my finding. I will be taking mine apart because of my bad experience using Garmin's technical support line. Most likely the problem is a defective switch or broken solder joint where the switch connects to the motherboard. Remember also, you have to hold the switch down for a couple seconds for the unit to power up.
Jan 13, 2008 | Garmin nuvi 350 GPS Receiver
Internal battery won't charge
Common issue. Steps to troubleshoot/solve:
1. Pull off face, press reset tab.
2. If unit wont turn on or if turns off immediately, connect to home computer using mini usb on side of gps (any usb cord that fits will do). This will charge the internal gps battery, which is discharged.
3. You will not be able to see the gps charge indicator while the usb cord is plugged into the unit. To check charge level, disconnect it, turn it on, and note the large "battery" icon.
4 Do you have a dead internal battery? If the gps holds a charge from your computer usb port, you don't.
5. If you have a dead battery, Google DIY replacement. With some soldering it can done for $15 total.
6. If you don't have a dead battery, the issue is charging from the cigarette lighter socket. Your car socket may have blown a fuse (check car manual). Your charger unit may have blown a fuse (unscrew the tip, check fuse inside). Also, some car sockets don't work when the ignition is off. Test yours.
7. There is a good chance the connection of the charger wire to the gps cradle is the problem. Fiddle with that. Replacement cradles are available for the c340 at about $25.
8. If your unit is not charging from the cradle/socket, buy a 12v usb cord. Plug into socket and into usb port of the gps. This is a workaround or alternative to buying a new cradle.
9. IMPORTANT: observe the "battery" icon while driving, esp. if you have doubts about charging. Basically, if you can see the icon, you're not connected to an outside (car or computer) power source. That is, if you can see the battery-charge indication, it means your battery is currently discharging and unless you get another power source to work it will be dead in a few hours.
Aug 27, 2007 | Garmin StreetPilot c340 GPS Receiver
Navman F20 GPS Receiver Logo
183 people viewed this question
Top Navman GPS Experts
Neil Gossage
Level 1 Expert
Are you a Navman GPS Expert? Answer questions, earn points and help others
