Question about Midea Chest Freezer MCCF10WMD
I have a midea chest freezer HS-195CN and water is leaking from under it
The fridge isn't getting cold. It has been close to 48 hours since I plugged it in.
You haven't said if you could hear the compressor running. If so then either the compressor is shot or there is a refrigerant leak. If it's not running it could be a bad cold control or the compressor starter. Oh and check to see that you have power at the receptacle that it's plugged into, I've been to calls of the refrigerator not working only to find out the it wasn't plugged in or the power was off at the receptacle.
Nov 02, 2013 | Midea HS-65LB Refrigerator
Water leaking from bottom of chest freezer
there having a wires which got damaged otherwise your cooling having problem.
Mar 19, 2013 | GE 14.8 cu. ft. General Electric Chest...
Just got a used 5.0 frigidaire chest freezer and noticed that it is starting to frost at the top but water is starting to pool at the bottom. any help would be appreciated
Good day,
The interior walls should frost evenly. If you only get a partial frosting pattern then either you have a refrigerant leak or a restriction in the refrigerant lines.
Either problem would be considered a terminal failure in a chest freezer.
Mar 29, 2010 | Frigidaire 5 cu. ft. / 142 liter Chest...
I am defrosting my chest freezer and have the lid open and water is continuing to drip out of the lid. Why?
condensation has frozen inside your lid and now is defrosting and driping out. Reason : there is a air leak in the lid
Jan 09, 2010 | Frigidaire 12.8 cu. ft. Chest Freezer...
I have a media dishwasher, it's new. works but
possibly your drain hose is blocked maybe packaging or something if it is new did you have another one before this if not check you have drilled out the drain spigot under the sink if this is where you connected your hose let me know how you went
Nov 12, 2009 | Midea Chest Freezer MCCF10WMD
Midea Chest Freezer MCCF10WMD Logo
51 people viewed this question
Top Midea Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Midea Freezer Expert? Answer questions, earn points and help others
