Question about RCA RS2652 Shelf System
CD drawer will not open
Just opened and set up, first time trying the CD changer. will not respond to remote or system operation.
Death-seed
  • 22 Answers
SOURCE: Will not open....
select another option such as "tuner", then go bak to CD
Posted on Feb 08, 2008
SOURCE: the 5 cd changer tray will not open but the motor is still workin
i had similar problem with 1 cd inside. i turned unit upside down gave little wiggle turned rt side up and it opened.
Posted on Aug 03, 2009
SOURCE: my rca rs 1289 5- cd changer mini system will not
Remove the case screws on the left and right side panels. Pay attention to the long screws that come out of the middle of the panels to make sure they get back in the right spot. Remove one screw from the top rear back panel. Lift side panels of in a hinged motion from the bottom. Remove the top panel in a hinged motion from the rear. In the center of the disc tray remove 1 screw from center. Note the orientation of the tray for re-insertion. Lift the tray up and out. look for small dc motor and spindle. this motor is used to spin the tray. You should find a black belt2_bing.gif between motor and spindle. Make sure it is in good condition. Look to the right rear of the unit. there is a second motor and belt which drives the tray. This belt may be broken or off its spindle. repair or replace the belt as necessary. Plug the unit in and test the open/close function and ensure the gear train, belts2_bing.gif and carriage move smoothly. reassemble.
Posted on Apr 15, 2010
  • 1456 Answers
SOURCE: The disc compartment doesn't
Hello
Find a blank disc or a disc that you don't use anymore. Insert this disc about an inch deep into the slot where the discs go in.
Now, move the disc gently sideways while pushing the eject button repeatedly until the discs come out. If this doesn't work, move on
Contact the manufacturer if the CD player is still under warranty. Remember, if you try to open the player, you will be voiding its manufacturer's warranty.
If it's not under any warranty. You have to replace the motor that ejects the discs.
Posted on Nov 06, 2010
reyjoshua07
  • 1157 Answers
SOURCE: Is there a lever to push or something inside the
Hi mckenziered,
The easiest way to correct this is by resetting the unit. Try to unplug it from the power outlet and harness, wait for 10 seconds then plug it back again. If this did not work, you need to disassemble the unit totally and reposition the tray back into position. If problem persist, CD changer needs to be replaced.
Hope it helps.
Thank you for using FixYa.
Posted on Jun 27, 2011
The cd holder wont open
There's a possibility that the somewhere within the CD changer's mechanism there is something jamming the gears which allow it to open. I remember there was one time the CD changer wasn't opening and it turned out a cd was under in the CD changer's mechanism and I have no idea how it got there. In order to fix your problem you'd most likely have to open the unit and take the CD changer out but don't be afraid, opening and operating on this system is pretty much straight forward.
May 14, 2014 | RCA RS2663 Shelf System
Problem with the cd changer on my RCA Total Power 5 disc changer system
Unfortunately, it sounds like the relay or motor to open the drawer is either stuck or dead, which can cause the entire system not to play the discs even if the drawer is closed. First, try calling RCA Customer Support to see if warranty service/exchange can be made for the unit. Second, try taking it back to where it was purchased. IF all else fails, You can disassemble the unit (this voids the warranty - do at your own risk) and try to identify the motor and drawer mechanism- try removing the main casing to your stereo (unplugged of course) and ensure that the small belts & gears that operate the drawer mechanism are all in good working order by gently operating them by hand. If not, you can replace or try a repair, but it honestly may be cheaper (and better for your sanilty) to buy a new system.
Feb 18, 2013 | Audio Players & Recorders
CD function in 5 disc stereo constantly flashing "CHANGE"
Open the drawer and check to verify the disc was put in the disc 1 position. Sometimes the changer gets confused if disc 1 is not in the disc 1 cavity. Also, 5 disc changers are very prone to failure
Nov 17, 2012 | Audio Players & Recorders
It is a 5 disc changer. The drawer will not open and it now has 4 cd's stuck inside the changer. It also will not play any of those "stuck" cd's.
THis happens when the drawer is jammed. Turn off the unit and turn it on and then use the disc skip from the remote so that the cds inside will change and then press the Open button.
Aug 21, 2010 | RCA Audio Players & Recorders
Five discs keep spinning; will not stop. Cannot open drawer
they button maybe stuck or the switch that open the cd player sticking try to push button to open then pull on drawer not to hard u brack then see if u can clean swith
Mar 22, 2009 | Sony CDP-C445 5-Disc CD Changer
Onkyo 6 disc cd changer DX-380 has CD stuck under carousel
This has just happened to us. Often when the changer tries to select a CD on random play, it somehow knocks one CD off the carousel, usually on top of the other 5 CDs and then you can retrieve it easily. This time it knocked it down behind the carousel so the drawer could not close. We left the drawer open, carefully took the player out and tipped it upside down and then tipped it forward. We then closed the drawer while it was still upside down and then turned the player back up the right way. The loose CD fell onto the carousel and we could then open it and retrieve the CD. No damage to either CD or changer and we are now listening to music again!
Jan 04, 2009 | Onkyo DX-C380 6-Disc CD Changer
Disc drawer will not open
Try to hear a sound of of a running motor inside the unit. If you can hear it, the there's a broken or misplaced rubber belt. The belt drives the drawer open.
Nov 25, 2008 | JVC XL-F254BK 5-Disc CD Changer
Two issues with this system
Hi eshort
When you press the buttons to operate the Cd drawers, do you still feel a click under your fingertip the same as the rest of the buttons. If not, the plastic piece may have broken away from behind the front panel assembly preventing the switches from operating be from the front panel. It may as you have already diagnosed be a part broken off the transport also.Only further investigation will determine this:) Can you still operate the unit from remote control?
The LCD display will use an incandescent lamp to back light it. this lamp will have failed. These are replaceable, the degree of difficulty varies from model to model. Pop the lip off and check if it is easily access. The worst cases need to have the LCD display removed to replace the lamp. Good Luck, thanks for checking with FixYa
regards
Graeme
Mar 11, 2008 | JVC HXD7 5-disc Home Stereo Theater System...
Cd changer drawer won't open
the common problem for this would be some of the disc/discs are out of place . just opening the shell
and removing the discs can resolve the problem.
Feb 23, 2008 | Technics SL-PD5 5-Disc CD Changer
RCA RS2652 Shelf System Logo
64 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
