Question about Harman Kardon AVR 130 Receiver
Amber light only
I have never had any problems with this reciever. I just got back from a two week trip. I had left the standby power on. I now only have the amber standby light on and I cant turn the damn thing on. I have tried unplugging it and waiting a few minutes. Most times I have gotten no change. A couple of time the power came on for a minute and then shuts off. I have also tried the master reset by holding down the mode select button for 3 seconds. This does nothing also. If you have any insight please let me know. I bought this reciever a year and a half ago and am not ready to reinvest in another. Thank you.
  • Anonymous Jul 02, 2008
    yes i have same problem. Only standby light is getting ON and doesn't get the blue light on at all.. Tried all the possible options at home. Need your urgent assistance and guidance in this matter.. so that i can enjoy this product during my vacation in india for another 3 weeks from today..
    Thanks a lot if you can really help me out.
    Regards
    Customer. my eamail address is nizamks@yahoo.com.
  • emmetbrown Apr 19, 2009
    I have the same problem and i've checked R104, R105 & C109 without success. (C109 = 0,13 uF)
    Sometimes, after severals weeks without activity, it works. But i don't understand why. And now, after several month, it does not work
    Have you another idea ? (How can i identify the failure part ?)
    Thank you very much for your help. I'm a little in hopeless.
    Problem Solver:
  • 16 Answers
No, actually is the main processor located on the front bpanel board. Needs replacement but you cannot do it in house
Posted on May 24, 2008
    President:
  • 3,130 Answers
You really may not have a choice in this matter of buying a new one, Unless you want to invest about what it would cost you to have your unit looked at? There are no parts you can change, as its a solid state unit and all parts are soldered into place and also you have to know how to troubleshoot solid state electronics.. My first guess would be a problem with the power supply.. Its probably one of the switched supplys thats bad. Unless you know how to use a multi-meter and the workings of the soliod state regulator circuits, your gonna have to take this unit in to get an estimate.. Good LUck
Posted on Aug 01, 2006
CHECK R104,R105 AND C109 NEXT TO THE TRANSFORMER.
Posted on Jul 30, 2008
SOURCE:
My tv showing an amber light instead of red standby light and now it won't switch on
Good day!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 20, 2012 | Televison & Video
Thomson DTI6300-16, The amber light constantly flashes, no red or amber lights appear! any help/advise would be welcome
Does your Thomson DTi6300 fail to power on normally and displays a solid amber light? During the past few days we have been made aware of an issue affecting a number of our customers with a Thomson DTi6300 box. Customers have been experiencing problems with their box failing to come out of standby mode and typically showing a constant amber light on the front panel.
This fault is due to a broadcast issue which  has led to a corrupt file being loaded onto the hard disk.
Only Thomson DTi6300 boxes have been affected. If you have been experiencing problems of this nature first of all try switching your box off at the wall and leave for twenty seconds. If this does not work, please try the following procedure.
Please note this will unfortunately cause recordings in your programme library to be lost which we?re very sorry about. You may have to try this procedure a few times in order to resolve the issue as it requires complete attention and precise timing.
1.       Disconnect the power supply from the unit by removing the power cable from the back of the box.
2.       Wait 20 seconds and then put the power cable back in while pressing the 'standby/power on' buttonrepeatedly on the front panel of the box.
3.       Release the standby button as soon as you see a light flash on the front of your box and thenimmediately press the arrow buttons on the front panel quickly and in the following sequence:  Up, Down, Left, Right (please note this is not the order the arrow buttons appear on the box).
4.       Your box should then show the amber light with the green light flashing until the disk re-format has been completed which will take around 60 seconds. The box should return to a solid red light (standby) automatically. If after 2 minutes your box still does not display a solid red light, please repeat steps 1-4.
5.       When you return to the TV GUIDE screen, you will now need to scan for channels to restore your Top Up TV channel logos. To do this, please select Option 4 (set-up) from the Main Menu, followed by option 1 (scan for channels).
6.       IMPORTANT: Once you have completed your channel scan, you will need to select option 5 from the Main Menu (Choose your channels) to re-select all those channel providers you would like Top Up TV to download shows from.
We?re really sorry if you have been affected by this issue and greatly regret any inconvenience this may have caused.
May 04, 2009 | Televison & Video
Top up tv+ digital tv stopped working.
i had same prob, tried unplugging three times
then unpluuged for 5mins
, plugged back in left it alone, ie didnt touch remote or front panel, until it settled down ~15mins, green light came on (doesn't normally)
and everthing seems ok now
May 03, 2009 | Televison & Video
Akai lct3201ad red standby light turns green then red again!
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com if you require further assistance
Feb 22, 2009 | Akai LCT3201AD 32 in. LCD Television
Vizio L37
Check all electrical connections. If standby light is off when plugged in, probably needs Power Supply board replaced. If standby light is on (Orange/Amber color) may need Power Supply board and or Main Board. If set was shutting down on it's own leading up to it not powering on at all, may need Main Board, and possibly Power Board as well. If standby light has changed from Orange/Amber color to Green, the set IS powered on, and you have an issue other than power.
Oct 04, 2008 | Vizio L37 Television
Thomson DTI6300-16 digital TV recorder frozen, red light on constantly, no resposnse to any commands. I think it needs a factory reset - how do I do this?
Try Resetting the box to its factory setting:
  • Menu > Setup > Help
  • Then press the Green Button (Even though it doesn't show as an option)
  • Then press the Red button for a full reset
Warning: You will lose all data on the Hard Disk!
I did this when mine wouldn't record anything and dumped all my pre-recorded programs.
Worked a treat.
Jul 20, 2008 | Televison & Video
HP Pavilion dv6000 Wireless internet function intermittent. With the on/off slide switch left in on position light will be amber (off) most of the time. Occasionally when comming out of standby the led...
You keep mentioning ( come out of standby ), You do know don't you that some systems are having problems with coming out of standby. A bios ( firmware ) update to the motherboard may fix this, but again it may not. If HP is saying that the system is working ' correctly ', then it probably is for the bios that is available for the system at this time. I would suggest not using the STANDBY mode but instead when you get done with the computer, shut it down, and restart it when you are ready to use it. I would like for you to try that possibly several times before deciding that it doesn't work for you. If you find that a complete restart of the computer doesn't alliviate your problem, please come back and let us know. I am assuming that you are in an area that has good wireless reception of course. Assumptions can be bad for a tech's health if you know what I mean.
Jun 19, 2008 | Computers & Internet
AVR-745 Firmware upgrade
I have done an update in the past/ ONE Thing/ you do not attempt to do an update at the same time you download the firmware update.
You always download the update/ Open/ Read the instruction and follow them as directed.
An Yes/ it is possible that you might be doomed/ but I would go back/ Download the update with out being connected to the reciever/ Open the download/ Make a folder for it to uncompresse to. Choose that folder when prompted as to where it is sent when uncompressing.
Then go to that folder and READ EVERYTHING FIRST. There is a folder in there that is named to read first.
Once you have read it/ you will see that it is easy to do/ and see your mistake.
I believe that if you try it again, (even though your reciever info is screwed up) it will take the full update.
Sorry about the caps/ I am not trying to yell or what every they say about caps. It just is really important to read everything first. If you don't think you understand what you read/ Read it untill you do understand it. Do more research until you do.
May 03, 2008 | Harman Multimedia AVR 745 Receiver
Harman Kardon AVR 130 Receiver Logo
870 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Don Hart
 Grubhead
Grubhead
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
