Question about Broderbund Computers & Internet
The Print Shop 6.0 program cd wont work
When I load the product disc, it will not recognize the disc, I have checked and it is not my computer, because I can put another disc in and it will run it. I uninstalled my 6.0 and reinstalled with the dic media and it worked fine. But I can not run 6.0 because the product disc is not being recognized. My OS is a XP professional. Thanks Kim
  • 634 Answers
Try in another laptop or friend's pc or laptop to install it.
Then copy that setup on your computer an make another disc of it.
Posted on Feb 08, 2012
3 Suggested Answers
samuelseno
  • 103 Answers
SOURCE: Office Professional 2007 says the Product Key is "incorrect."
You should try to install your Office 2007 to another computer to be able to see if your computer has the problem or it just the product key.
Posted on Jun 12, 2010
SOURCE: Microsoft Office Professional 2007
freeware
Posted on Jun 24, 2010
Are replacement discs available for Print ShopV^6
You might look on Amazon.com or eBay. There are several versions available on there.
Aug 05, 2014 | Broderbund The Print Shop 22 Deluxe Full...
I cracked my install cd and can not load on my new computer...help I do not like the other versions or print shop I need my deluxe 21 version
Hi,I looked into this for you and listed below you'll find all you need to get a replacement disk,hope I've helped......
If the 90-day warranty has passed and you wish to receive a replacement, please provide the following mandatory items
1. A personal check or money order for $10.95(USD) per disc requested.
2. The disk containing the defect.
3. A letter or card with your full name and return mailing address
4. A reason for the replacement request
Please send these items to the following address. We recommend you send your return via a traceable method such as Priority Mail®, UPS™ or FedEx® as Encore is not responsible for undelivered or lost packages. Please note that Encore is not responsible for the shipping cost to return the product.
Encore Software Inc.
999 N. Sepulveda Blvd
Suite 700
El Segundo, CA 90245
ATTN: Disc Replacement
From the day it arrives it will take 4-6 weeks for you to receive the replacement. If we do not have the product in stock, your check or money order (if submitted) will be returned.
Good luck....
Jun 13, 2011 | Broderbund Print Shop® 21 Pro Publisher...
Cd software disc will not load on to my computer. Isn't being recognized
If in case the cd was not recognized upon loading it to the computer you may do the following to check wether the cd is faulty or the cd drive.
  1. Verify that the correct disc (CD/DVD) is used when prompted to insert the disc.
  2. For programs on DVD, verify that the drive containing the DVD is a DVD drive and not a CD-ROM drive. Most DVD drives will have DVD printed on the front of the drive. For programs on DVD, consider the following:
  • DVD drives can read both DVD's and CD's.
  • CD-ROM drives can read only CD's.
  1. If multiple disc drives (e.g., CD-ROM and CD-RW, or DVD and DVD-RW, or CD-ROM and DVD-RW, etc.) exist on the computer that can read the disc (refer to the items under Step 2), insert the CD or DVD into the other drive and try the program again.
  2. If you are attempting to install a program and the installation does not begin after inserting the CD/DVD into the proper drive, refer to the program's instructions for the installation procedure.
  3. Clean the CD/DVD in the following manner:
  1. Place a small amount of nonabrasive liquid soap on the shiny side of the CD/DVD.
  2. Using your fingertips and warm water, gently rub the soap on the CD/DVD in a circular motion.
  3. Rinse the CD/DVD thoroughly and dry it using a clean, soft T-shirt or lint-free towel. (Do not use paper towels or tissue paper.)
  1. Try to use a different CD or DVD in the drive to see if that disc can be read.
  2. If possible, insert the problem CD or DVD into the DVD or CD drive of another computer to see if the issue persists.
Mar 16, 2011 | Logitech C500 Up to 1280 x 1024 pixels 30...
Install new CD for printing projects.
goto Start/programs/Accessories then to Windows explorer or my computer then goto ur CD drive then click on setup.exe
Mar 23, 2010 | Broderbund The Print Shop 21 Deluxe Full...
Can install Print Shop 21, but when the splash
Solution
You must reinstall Microsoft .net framework.
You can do this by:
Go to the control panel
Go to add remove program select Microsoft .netframework 1.1 and remove
Also if you have the Microsoft .netframework 1.1 Hotfix select that and click remove as well.
Once both those are removed we can reinstall Microsoft .netframework from the Print Shop Install disc
You can do this by:
Insert the Print Shop Install disc
Double Click on My computer
Right Click on the Drive that contains the Print Shop Disc
Left click the open option.
Double click on the folder called Setup
Double click on the file that’s called 1033DotNetfx
This will reinstall the net framework on your computer and it should fix the issue you are having.
Nov 09, 2009 | Broderbund The Print Shop 21 Deluxe Full...
Not able to print directly on CD/DVD
Printing Directly onto a CD or DVD in Roxio Express Labeler
  1. Make sure that the product is turned on and that the USB cable is connected to the product and the computer.
  2. Click Start , click All Programs , click Roxio , and then click Roxio Express Labeler v3 .
  3. Click Disk Label , then click Options . Figure 1: Options c01452912.gif 1 - Options button
  4. The Options screen appears. Figure 2: Options screen c01452913.gif
  5. Make sure that LightScribe 12cm Disc is selected from the Disc Label menu, then click OK to return to the Roxio Express Labeler window.
  6. Click Disc Titles , type the title and subtitle for the CD or DVD, and then click OK . Figure 3: Disc Title option c01452914.jpg 1 - Disc Titles button Figure 4: Edit Disc Title screen c01452915.gif
  7. Click Background , then click Import Background to use an image on the computer as the background on the CD or DVD. Click OK to return to the Roxio Express Labeler window. Figure 5: Background option c01452916.jpg 1 - Background button
  8. Insert a LightScribe CD or DVD into the LightScribe drive of the product. Make sure that the label side of the disc is facing down.
  9. In the Roxio Express Labeler window, click Print . The LightScribe label is printed on the CD or DVD. Figure 6: Print c01452917.jpg 1 - Print button
Jun 18, 2009 | HP Office Equipment & Supplies
Wasn't prompted to load image disc print shop pro deluxe 23
just go to control panel, add remove programs, select print shop (change) and select modify it will allow you to change content to hard drive and not cd.
Mar 19, 2009 | Broderbund PrintShop Pro Publisher Deluxe...
Gateway laptop pc wont recognize blank discs in drive E:
Are you sure E: is the cd/dvd burner?
Can you put a cd with music or a dvd movie in there and get it to play it?
Mar 19, 2008 | Gateway 7330GZ Notebook
Computers & Internet Logo
Top Broderbund Computers & Internet Experts
Martin Murray
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
