Question about Hardware & Accessories
Manual for programming digital geyser timer Top Tronic IEC 60730
How to se time
Posted on May 27, 2012
Good day I need a manual to program a ellies ISG1201 geyser timer
Try Googling (ellies)(ISG1201)(manual) without parens.
Jun 12, 2017 | Hardware & Accessories
Lost manual to program defiant daylight adjusting indoor digital timer
videos and text manuals.
49814 Program Guide Defiant Daylight Adjusting Indoor Digital Timer ...
? 16:31
https://www.youtube.com/watch?v=yxZKNVddNU0
Jun 24, 2015 - Uploaded by Jasco Products Company
49814 Program Guide Defiant Daylight Adjusting Indoor Digital Timer. Jasco Products Company. Loading ...
Defiant Daylight Adjusting Indoor Digital Timer with Motion Sensor ...
https://www.homedepot.ca/.../p.daylight-adjusting-indoor-digital-timer-with-motion-s... Easily automate indoor or outdoor lights with the Defiant Daylight Adjusting Indoor Digital Timer. Program up to 7 on and off times per week. Auto adjusts to ...
DEFIANT 469-637 QUICK START MANUAL Pdf Download. - ManualsLib
https://www.manualslib.com > Brands > Defiant Manuals > Timer View and Download Defiant 469-637 quick start manual online. DAYLIGHT ADJUSTING INDOOR DIGITAL TIMER. 469-637 Timer pdf manual download.
[PDF]Home Depot Defiant Timer - A-1 Electric Co., Inc.
www.a-1electricco.com/technical/timers/defianttimerprogramming.pdf We appreciate the trust and confidence you have placed in Defiant through the purchase of this daylight adjusting indoor digital timer. Visit us online to see our. defiant daylight adjusting indoor digital timer Google Search
Mar 13, 2017 | Hardware & Accessories
Where do i connect the geyser load wire to a dhc15a-20a timer
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#PB1
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#FM1
The other terminals are NO NC and Com
Neutral does not connect to these... only Hot
Hot connects to Com... and then connect wire to geyser to the NO contact... general illustration on link above
Sep 19, 2014 | Hardware & Accessories
How to set a Kes load control timer model ISG1201
The Geyser Load Control Timer, ISG1201, is designed to prevent geyser from operating during the Eskom's designated weekly morning and evening peak times. The ISG1201 features 4 easily selectable, pre-programmed, geysers "ON" operating profiles to ensure maximum comfort whilst not burdening the user with the complicated process of having to program the unit.
The profiles are as follows;
  • Program (1) is always "ON"
  • Program (2) "ON" after sunset to accommodate solar geysers
  • Program (3) "OFF" all the time
  • Program (4) savings program - "ON" 6 hours weekdays and 12 hours weekend days
Source: http://www.kgwanyape.com/solutions/isg1201-geyser-load-control-timer/
Oct 31, 2013 | Hardware & Accessories
I am trying to program a Westinghouse yard stake. It's a model 28006, hinge top, 6 outlet digital photo cell. Please help if you can.
1) Copy following link to help identify same-similar timer and download possible manual
http://waterheatertimer.org/Woods-timers-and-manuals.html#outdoor
2) On-line search shows dawn-dusk timer which can be set to turn off 1-9 hours after dusk.
Typical operation is to push button until 6 displays, then timer turns ON at dusk and OFF 6 hours later
3) Describe timer with more detail so expert can exactly identify timer functions and find same-similar manual.
Dec 03, 2012 | Hardware & Accessories
Geyser timer stopped working
Check circuit breaker.
Click fully off and then back on.
Check for burned smell at breaker or loose crackling sound that says breaker is bad.
Reset timer. Then Reprogram.
Possible geyser timer manual
http://waterheatertimer.org/pdf/Digital-Geyser-Timer 24H-7-Day-Timer-230V Brochure.pdf
This timer has a non-replaceable internal rechargeable battery.
If battery has gone bad, then timer is defunct.
Use manual override button to turn timer ON-OFF.
Then test across terminals 3 and 4 for 240Volts.
Turn timer OFF, and test across terminals 4 and 5 for 240Volts
If no voltage shows then timer does not have output.
If test shows 80% undervoltage, that can cause load not to activate, depending on type of load.
Have electrician check for voltage issues at power company transformer.
Unknown what load timer is connected to.
Max load for this timer at 240 volts is 3680 watts, 16 amps.
Motor load is 230 volt 8 amps.
Check label on load for watt or amp rating.
Volts x amps = watts
Watts divided by volts = amps
Oct 31, 2012 | Hardware & Accessories
I want to reprogram my timer to a new on time,and off time. do i have to clear the existing program,and start from scratch? if yes, do i use 6a an on/off program at specific times. next question: ...
To reprogram times, it might be easier to clear all programs. Read the manual. Sometimes you have to read it several times. Or scan it into computer so you can see print larger. Or go to manufacturer website and download manual. Some manuals are impossible to find, some have unclear instructions.
For programming help. Post brand and model number of timer so product is identified. Some products have nearly identical numbers but are very different. It's a zoo of products. So be specific.
Timers generally repeat 1 week or 1 day. Do you have a in-wall timer? Or box-type timer
Intermatic in-wall EJ500, ST01C, EI600 offer Daylight Savings & Dusk to Dawn operations. EI600 has 5 year warranty. Other two have 1 year warranty.
http://www.intermatic.com/products/timers/in-wall%20timers/electronic%207-day%20astro%20time%20switches.aspx
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/in-wall%20timers.aspx
Click product number to see manual. Download manual to your computer> go to File at top of browser, click 'save' -or- click 'print'
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
http://waterheatertimer.org/ST01C-program.html
If you have a boxtype timer, Intermatic makes timer with photoelectric sensor
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/digital%20timers.aspx
Aug 14, 2010 | Intermatic Inc. EJ500C Digital Wall Switch...
Hardware & Accessories Logo
1,088 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
