Question about Refrigerators
I need a manual for Proline PLC 190SL fridge freezer
5 Suggested Answers
watugot
  • 290 Answers
SOURCE: Samsung RS253BASB SidebySide Fridge Not being Cooled
Your fridge has seperate evaporators for the fridge and freezer sections with a variable speed compressor.
The diagnostic test is telling you that the main control board (PCB) is not communicating properly with the display board where you set the temps, or it is not sensing the condition of the fridge properly, either the fan speed or thermistor resistence.
I do not have a manual in front of me so I can't guide you directly, but look in the manual you have and find the tests for the fridge thermistor and fridge fan motor and follow those instructions. If they are correct according to the manual, you probably need to replace the PCB (PBA in parts diagram) located behind the machine inside the compressor compartment, or possibly the user control board which is the the display board that you use to set the temps.
The service manual you have should give tests for the display board as well, but my bet is the main board in the back.
Thanks/Mike
Posted on Dec 08, 2007
Illeagle
  • 525 Answers
SOURCE: proline pc178a fridge freezer still
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
I attempted to locate an answer to resolve the issue for you, but you have not provided me with enough information to access my service database.
Below is a link to common solutions that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
It provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Once you access the site you will be able to navigate numerous pages of information on your product. You will need to enter your model number to access your product information.
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint. I will post the most common solutions to your complaint. For more specific information please refer to the tip and/or link provided.
http://www.repairclinic.com/0088_4_1.asp#Level1_1
First, check to see if the light comes on or if there is any fan, motor, or other sound coming from the appliance? If so, the refrigerator isn't really completely stopped--go to the specific problem you are having. If not, try adjusting the thermostat to a colder setting. If that doesn't work, read on.
Second, check to see if there is power getting to the refrigerator. To do that, plug a lamp or other device into the same outlet the refrigerator is plugged into. If there's no power, check the fuses or circuit breakers. If the fuses or breakers aren't the problem, contact a qualified electrician to restore power to the outlet.
If there is power to the appliance but it still seems to be stopped, there may be a problem in one or more of these:
  • Wiring
  • Thermostat
  • Defrost timer
  • Compressor
  • Overload and/or relay
Unfortunately, we can't describe all of the possible problems and repair solutions here. If you are unable to troubleshoot the problem from here, you may need to contact a qualified appliance repair technician
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 05, 2008
imufo2
  • 3773 Answers
SOURCE: I have water pooling in
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? it overflows into the ref.
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Posted on Jul 29, 2011
ginko
  • 19396 Answers
SOURCE: proline fridge/freezer the fridge is
Hi.
You have a problem with the defrost system. Try disconnecting power overnight and allowing fridge to defrost. The problem will not occur immediately after defrosting, but will probably restart after few days, when the evaporator coils freeze again. In that case the defrost system must be tested and repaired.
The defrost system comprises defrost thermostat, heater, defrost control and fan. The parts that fail more commonly are thermostat and heater. Both parts are located behind freezer firewall and tested reading impedance with a multimeter.
A test on the defrost system can be done by performing a complete defrost manually (remove food and leave power disconnected overnight). If the fridge restarts working after defrost, then problem was the defrost system. In that case the problem may return after few days or weeks, meaning that one part in the defrost system is faulty.Parts must be tested.
If the defrost makes no change, then there is a different problem. The damper ventilation system , the temperature control or the refrigerant gas pressure may be the problem. When the problem is one of these faults you get the compressor is running regularly, but will stay on most of the time.
If the motor is humming and clicking most of the time, but not properly starting, then the problem is usually the starter relay/capacitor. Relay and capacitors can be replaced to fix the problem.
Here a tip explaining how to deal with a similar problem on a different fridge model: Fridge not cooling. Procedure is similar on your model.
You can find parts and diagrams for most appliances here:
Where do I find parts and diagrams for my appliance?
Regards.
Posted on Aug 08, 2011
Proline fridge
Do not tighten down the hinges on the top of the unit, until it is just where you want it. They have a very large range of movement to allow for the potential of a refer box becoming out of square.
When you got what you like, then crunch down on the screws on the top of the unit.
kindly,
Jim
Jan 13, 2014 | Freezers
Probably bad fridge tstat sensing bulb (tstat)
possibly bad open heater in area of fresh vegetable bin
or damper assy not set correctly
Dec 08, 2007 | Samsung RS2534 Side by Side Refrigerator
1959 190SL
Sorry but thats a funny questions... You need a radio manual for a 1959 Mercedes ??? An AM radio ??? A manual ??? for what ???
Dec 22, 2013 | Mercedes-Benz Vehicle Parts & Accessories
Drainhole gets blocked with ice proline fridge freezer
Sounds like the defrost cycle is too short! What is the make and model number?
Jul 10, 2013 | Refrigerators
My proline fridge freezer not cooling
I have the same problem with a proline plc 190w fridge freezer not cooling in the fridge compartment please help it's my mums and she can't afford a new one , thanks in advance
May 19, 2012 | Refrigerators
I need an online manual for proline freezer CF6 37P see drection for temperture control
there a alarme light showing on my chest frezzer what dose it mean
Aug 02, 2011 | General Freezers
Where can i buy an internal freezer lap for a Proline PF120GWA refrigerator
Hi!!
I guess you meant "lamp". Remove the old one and take it to Home Depot or similar store, they carry appliance lamps for most fridges.
Good Luck!!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Nov 19, 2010 | Refrigerators
LARGE AMOUNTS OF ICE FORMED IN THE MAIN COMPARTMENT
Well, short term, you'll have to unoad it and defrost manually.
Sounds like the auto-defrosting system has a problem. A likely cause is the defrost timer.
May 04, 2009 | Refrigerators
Refrigerators Logo
87 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
