Question about Welding Tools
I have a Matco welder Mat-MG185. As soon as I cut the power on gas flows out of the gun. It has a Nu Tec gun on it. Some people telling me to replace the gun, other says it's a gas valve inside the machine. Could you help.
luxur4
  • 92 Answers
SOURCE: need wiring schematic for miller 140 wire feed welder
No problem,email, write or phone for this information, Miller personel are very obliging as are most Welding manufacturers.
Posted on Jan 23, 2009
  • 14 Answers
SOURCE: HOBART HANDLER 135 GAS WILL NOT SHUT OFF
relce the gsi unit to regulate the gas flow.hope this helps jojgunn
Posted on Mar 15, 2009
  • 850 Answers
SOURCE: Lincoln MIG welder: Gas not shutting off.
gas regulator needs checking or replacing!
Or you can use GASLESS WIRE!
Posted on Jul 24, 2009
johnjnail
  • 1702 Answers
SOURCE: I have a Craftsman Wire
you have to use the gas 75-25 for steel and cast iron 100% argon for welding alumanuan
Posted on Feb 03, 2011
johnjnail
  • 1702 Answers
SOURCE: Hello, I would like to purchase
the spool gun is a 12volt motor, i usely hook it to the power feed for the feed motor in the welder. it is also 12 volt . i have heard of some welders that have 110 volt feed motors but have not seen one yet but just to be save i would test the power feed to the feed motor before i made the connection.
Posted on Mar 11, 2011
Testimonial: "thanks a lot. "
Why does wire keep coming out when trigger is not pulled
From the mig welder, unplug the trigger leads that exit the mig gun on the end of the gun that connects to the mig welder and power on your machine. If the wire flow stops, you have a shorted trigger circuit inside of the gun cable. If it doesn't stop wire flow, depending on your machine make & model, there is an internal issue with the trigger circuit that could possibly be just a simple relay issue.
Dec 25, 2014 | Welding Tools
No gas from welder to tip
Check with soapy water, change fitting or line
If you need further help, reach me via phone at https://www.6ya.com/expert/frankie_091f536560a54e12
Apr 13, 2014 | Welding Tools
I have a hobart 135 handler that with machine plugged in and turned on the wire has constant juice and the gas cylonoid is flowing gas from the bottle without the trigger being pressed. my dealer said it...
Hi:
Have you disconnect the gun's power plug? If the wire and gas stop flowing by doing this action, then your problem is the gun's trigger. If the machine continues to feed gas and wire with the gun disconnected then yes, it is the pc board.
Good luck.
Aug 25, 2011 | Hobart Welding Tools
My magnum 100l is flowing gas even when the power is off. How do I get it apart to look inside?
Hi:
Your gun is not the problem, your problem is the solenoid valve on your machine (welder) that solenoid valve must got dirt or debri from the hose and the closing needle it's stuck . Just replace it, it will be cheaper than replacing your gun.
Have a great day.
Jun 21, 2011 | Lincoln Mig Welder Trigger Switch Magnum...
Hello, I would like to purchase 3035 spool gun and attach it to my self made welder. Could somebody to tell me which power supply I have to provide for spool gun motor? DC voltage, amperage ? Can I use...
Mar 11, 2011 | Hobart Handler 210 Wire Feed MIG Welder
I suddenly am not getting any gas flow why ?
Could be many reasons there;
1) Ran out of gas pressure from cylinder. Replace cylinder.
2) Solenoid valve not opening or clogged. Replace solenoid valve.
3) regulator closed or faulty. Open regulator to adjust flow. or replace it.
4) Gun connector not pushed all way in.
5) Gun liner's gasket (o'ring) at end of gun missing or broken.
Feb 06, 2011 | Welding Tools
No gas comming out
Try these possible problems and solutions.
4) Gun connector not pushed all way in. Release butterfly nut on gun and push the connector all way in.
5) Gun liner's gasket (o'ring) at end of gun missing or broken. replace liner.
Feb 06, 2011 | Clarke Power Products Clarke 130EN...
Lincoln power mig 200 .Wirw feeds and gas flows when power is turned on. Trigger switch is removed
Cables or lines at gun's switch end are touching or shorting out. Diconnect the gun from the plug/connector. If it persist then you have a bridged connector. Time to send it back for maintenance.
Oct 27, 2010 | Lincoln Electric Welding Tools
Miller syncrowave 250 tigrunner with gas flow
Your problem is in one of two areas. The controller board inside the unit or a bad trigger on your gun.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Nov 25, 2009 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
Welding Tools Logo
219 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
