Question about Fisher and Paykel Washing Machines
Gwl15ys 96200-a not pumping water out little fan spins but not pumping
  • Fisher and P... Expert
  • 554 Answers
37. (00100101) Phase 1 to 6 - Pump Blocked Error ( No change in the water
level)
While draining, the water level reading from the pressure sensor has not changed
for over 3 minutes. There are three likely reasons for this fault. One is that the
drain hose or the pressure switch hose has been squashed or kinked and the pump
out rate has been dramatically reduced. The second possibility is that the pump is
partially or fully blocked. The third is that the pump is not operating due to Motor
Controller module, wiring or pump failure. This fault could also appear if the
machine is pumping to an unusually high head of drain hose or into an extended
length of drain hose. The Fourth possibility is a diverter valve fault or blockage,
water level is not altering as the diverter is stuck in the recirculation mode, giving
the module the appearance the pump is not lowering the water level.
Primary Source: Pump System.
Action:
1) Check that the drain hose has not been kinked.
2) Check the length of the drain hose and try to reduce the length if excessively
long. A 39 inch (1 metre) extension hose of the same diameter fitted to the
existing drain hose is the maximum allowable length.
3) Check for open circuit windings in the pump. (Note: Pumps are fitted with a
thermal cut-out, which will reset on cooling.)
4) If the Tub is empty of water, remove the pump from the pump housing and
check that it is not blocked. Also check the drain hose is not blocked.
5) If the Tub contains water, then service the pump from the top of the machine
by removing the top deck and Basket. Bail out the water, remove the pump
cap and hood and clear the restriction.
Secondary Source: Wiring.
Action:
1) Check the pump harness is connected correctly to the pump.
2) Check continuity of the pump harness.
Tertiary Source: Motor Controller module.
Action:
Activate the pump by operating the machine in spin mode. Check the pump
is rotating. If it is not operating, and Primary and Secondary checks have
been performed, then replace the Motor Controller module.
Note: Consider fitting Pump Hood Kit (WM013). If (5kg) 11lb SmartDrive fit splash
guard to pump.
Quaternary Source: Diverter Valve failure (Phase 5 and 6 Eco's )
Action:
Check the diverter valve, see fault code 51
51. (00110011) Phase 5 and 6 Eco - Diverter Valve Fault
Primary: The motor controller has registered a drop in water level in the
recirculation phase of the wash cycle, water is being drained instead of recirculated.
Or water has been sprayed onto the valve from an external source and caused the
solenoid to blow.
Action:
Turn the power off at the machine but leave the power on at the wall, then measure
the voltage across the terminals of the wax actuator, if a reading of 120V is
achieved the motor controller has failed due to the valve and both will need to be
replaced.
Secondary: Check for blockage in the valve itself or a broken hinge mechanism
Posted on Dec 26, 2013
01 Audi tt quattro starts to overheat while idling but coils down after driving at higher speed, is it a thermostat or the fast relay switch
overheats at idle only are typically the fan system. Cars use the fan to pull air across the radiator for cooling. Any speed over 10 mph there is more than enough natural wind to do this without a fan. If the problem immediately goes away when you start moving, it is probably a malfunction or issue with the fan. I have on more than 1 occaision had a customer tell me they had the fan replaced and car was still overheating, and it ended up thje fan was spinning backwards or not turning on because of a fuse or relay issue.
If it doesnt cool down fully once speed is above 20mph for more than 30 seconds, there may be other issues like plugged radiator or weak water pump impellars. water pump is a fan that moves water instead of the air. if the blades wear, they still kinda work, but at idle they work poorly because the broken blades only move a little air at low speed, rev the engine up, they spin faster and work better. If the fan is functioning OK (Turns on and off by itself) and car still runs warmer at idle than at rev, water pump may be worth investigation.
May 08, 2015 | Audi Cars & Trucks
Not pumping water out
Hi just read your post.Now is the machine full of water? If it is, drain most of the water by hand with a small pot or bowl.When you have removed most of the water pull the machine away from the back wall and lean it back so you can look under neath the machine.To the right of the machine you will see a little black fan,this is the pump.Make sure the power is off at the wall ,now turn the fan clockwise and anticlockwise.The fan should spin freely.If it does put the machine back on the ground and turn the machine on and select a spin cycle and it should start to drain.If it does not drain or the fan is hard to turn please reply and I can help you further.Regards LU.
Jan 24, 2014 | Fisher and Paykel Fisher Paykel Intuitive...
Overheating radiator
Do not drive this when it gets this hot ,you need the cooling system checked by a professional ASAP!!! or you will severely damage the engine if you haven't already.
Oct 28, 2012 | 2000 Oldsmobile Intrigue
Pulley making noise, little paly in it fan clutch?
Shut the engine off and let it cool down. Then reach in and try to turn the fan. It should move smoothly with some resistance. If it's loose, doesn't move smoothly, or just spins easily. It's time to change it. It is threaded onto the water pump and takes a semi special tool to unbolt. Also, it's a left hand thread. What concerns me though is that you say the pulley is making noise. If it's making noise, and there's "play" in it. It very well may be the water pump.
Feb 28, 2010 | 2003 GMC Envoy
Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
Jun 21, 2009 | Fisher and Paykel Fisher & Paykel Washer
Alternator and fan stop spinning
you have a bad belt or tensioner for your alternator and fan and probably wtaer pump. Get it replaced and the belt adjusted.
May 22, 2009 | 1988 Oldsmobile Cutlass Supreme
94 fleetwood brougham LT1 overheating
This engine has a cam driven water pump. If the gear is sheared/broken it can cause this issue.
Feb 23, 2009 | 1994 Cadillac Fleetwood
Fisher & Pykel Smart Drive 9
Spin the fan on water pump (you can acess with difficulty from bottom of washer) if it has a little sand in it, it may clear. It is possible to remove water pump if mechanically minded and see if something small eg staple or 5c coin is stuck in it if this dosn't work or you may find you need to replace water pump.
Aug 19, 2008 | Fisher and Paykel Fisher & Paykel Washer
Radiator fan motor on my 1998 cavalier
Normally, the fan will not spin at the same RPM as the engine. This is the purpose of the fan clutch. On the fan clutch sits a little thermal spring that engages the clutch to spin the fan at the same rpm as the motor when the motor gets hotter than normal.
Being able to hold onto the fan while the motor is running, is normal (not recommended, but normal).
You can test the clutch by heating it and then trying to spin the fan while the motor is off. If it is still easy to spin, you could have a bad fan clutch, or you didn't heat it enough. It is kind of a crappy way to test.
You not having cooling issues leads me to guess that your clutch is alright. But I don't know what type of climate you live it, nor do I know in what condition your clutch is.
They can actually be difficult to replace. Easy theory, but actually doing the job may be harder than you think. They are threaded onto the water pump pulley (just one big threaded stud). To remove you need to either be really crafty, or you need a wrench designed to hold the pulley in place while you loosen the clutch and fan assembly. No, the pulley drive belt is not enough to keep the pulley from turning (it will either slip or you will turn the crank of the motor).
Usually they are on there pretty tight! When I replaced my water pump on my truck, I could not remove the fand and clutch from the water pump while in the truck (I had to remove my radiator shroud and remove it all in one piece) then I had to weld the old water pump impeller to the casting to keep it from spinning then broke it loose with a 2ft breaker bar! Seriously.
Once you get the old one off, remove the fan and bolt it to your new clutch unit. Then thread it on the water pump.
Jun 25, 2008 | 1998 Chevrolet Cavalier
Spin Cycle
The height is usually marked behind the machine. It is approximately 3 feet from ground level. The machine's pump pumps the water OVER this height into the drain.
Oct 03, 2007 | LG WM2688HWM TROMM SteamWasher
Washing Machines Logo
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
