Question about Zoom G1x Guitar Multi Effects Pedal with EXpression Pedal
G1X diagram circuit/diagram
I cannot edit sounds. . saka nag iinet ung zoom
Posted on Jun 11, 2012
Zoom g1x dc supply not working, my zoom g1x is working when battery operated but if i connect it to a adaptor there is no power, i've already checked my adaptor and it was properly working, what can i
Some possibilities:
  • Damaged on the DC-IN socket.
  • Broken solder joints on the center pin of the DC IN socket (see figure: pin 1 on DC208B).
  • Damaged (broken) in D2 or R54
Aug 18, 2014 | Zoom G1x Guitar Multi Effects Pedal with...
I have Zoom G1XN ext. My guitar effect just lit "Gn" and can't change to Bank memmory. I need the circuit diagram and service code for Zoom G1XN ext whom can help and send to my email dias.no1@gmail.com
Have you tried to reset the unit? You can do this by holding save button for few seconds while connecting your adaptor to g1x/g1xn. Then the indicator will blink, then push save button again,this will reset your unit into its factory settings
Jul 12, 2014 | Zoom G1x Guitar Multi Effects Pedal with...
Circuit diagram of zoom g1x
G1X circuit diagram is the same as the G1. They differ only on the pedal circuits.
circuit-diagram-zoom-g1x-shyexoo0xcste5eq310zs3ot-4-0.jpgcircuit-diagram-zoom-g1x-shyexoo0xcste5eq310zs3ot-4-1.jpg
Give your email,and I'll send the circuit diagram.
Jun 24, 2012 | Zoom G1x Guitar Multi Effects Pedal with...
What type of voltage regulator ic used in g1x?
2933BD or 29M33. It is used in g1, g1x,g1xn,g2,g2iu etc.
This is 3.3 volts regulator ic.
Feb 09, 2012 | Zoom G1x Guitar Multi Effects Pedal with...
Zoom g1x dc supply not working, my zoom g1x is working when battery operated but if i connect it to a adaptor there is no power, i've already checked my adaptor and it was properly working, what can i...
Is the unit old?? Is it stored in an environment that has temperature fluctuations?? It could be the terminals on the input of the unit have dry jointed. This is when the solder lifts away from the circuit board. I have had the same problem on my ZOOM MRS1608 recording desk. Resolder the connections on the input. The base plate will problably remove easy enough to get to the point where the adapter is soldered onto the circuit board.
Good luck
Aug 11, 2011 | Zoom G1x Guitar Multi Effects Pedal with...
Zoom G1X Repair!!!!
If the pedal still works, likely the circuit board is not cracked.
The control that is damaged is LIKELY an encoder.
Many of these are made by ALPS, Bourns and others.
You need to open the unit top get at the device.
The encoders are available from either DigiKey.com or Mouser.com
Here is an example page:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Selection
You need to match the pinout and part number if you can find it on the part.
May 13, 2010 | Zoom G1x Guitar Multi Effects Pedal with...
Where should the Zoom G1X go in a pedal chain?
From an electrical engineering standpoint, an expression or volume pedal should be near the end of the chain so that the other effects don't try to process very weak signals when the volume is very low.
This gives better signal to noise ratio.
May 11, 2010 | Zoom G1x Guitar Multi Effects Pedal with...
Zoom G1x Guitar Multi Effects Pedal with EXpression Pedal Logo
348 people viewed this question
Top Zoom Music Experts
Barry Webster
Level 1 Expert
patonplace
Level 1 Expert
Are you a Zoom Music Expert? Answer questions, earn points and help others
