Question about General Cooktops
What does a sensi-heat burner look like or how to know if your GE range has one?
I have a GE Monogram Gas Stove - 5 burner. All
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
w3
Jun 15, 2010 | GE Monogram ZGU48N4GHSS / ZGU48L4GHSS...
The main burner (left front) only heats on half the circle.
Your referring to an electric range I'm assuming. In that case the heating element is only heating to a mid-point then stopping. This typically means the heating element is burnt or is partially burned out. The element is usually user replaceable and requires the old one be unpluggude and replaced with a new one. You'll need to get the element from the manufacturer.
Apr 21, 2010 | GE Cooktops
Sparkling sound can be heard continously on the GE Cooktop
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Feb 17, 2010 | Jenn-Air JGC8536 Gas Cooktop
Ge gas range about 7 years old delay in lighting
take burner cap off and clean all the gas ports with paper clip etc.it sounds like the gas is not reaching the spark.usually clogged with grease or soap.hope this helps .please rate my answer :)
Dec 08, 2009 | GE Cooktops
Wirlpool elect range GR465LXLS, cant control heat on dbl burner
yes it is your control infinite switch the knob swicht that goes from 1 to 10 or min to max thanks from gilles
Mar 13, 2009 | GE Cooktops
Gas burners lit, but electronic ignition still clicks
heatman101
fsggfs
Mar 13, 2009 | GE 36 in. Monogram ZEU769 Electric Cooktop
Simmer is too hot
one way is the orfice that goes inside the burner.some have a little screwin the knob shaft to ajust.if no screw its the orficc.theres a tech sheet that will give you more detail about that on that stove.bottem drawer area or back.also so ranges have orfices on them in the back also.God bless,tom
Jan 01, 2009 | GE 36 in. Profile JGP962 Gas Cooktop
Gas Range Continuous Spark
On all gas stoves/cooktops, when you switch on one burner to light, all other burner igniters will click at the same time. This is normal. Enjoy your new apartment!
If you need further assistance, let me know
Regards,
reg501
Jul 04, 2008 | Cooktops
Looking for Cause of Fault Code on GE Range top JP939
Have SAME EXACT issue - F113 on Left burner. Indicator says HOT and not even on. Called a service company (NOT GE SERVICE). They said the Element Radiant is no good and must be replaced. Part is quoted as $323.98 !!! What a rip off from GE !
Jul 02, 2008 | Cooktops
Cooktops Logo
429 people viewed this question
Top General Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a General Cooktop Expert? Answer questions, earn points and help others
