Question about Home Security
I am trying to program my Lexus automobile built in garage remote with the Sears garage door opener HBWO777 1/2 it that possible?
  • 4 Answers
SOURCE: remotes quit working for garage door
I had the same problem with my Craftsman opener but different model. However to fix this I simply followed the instructions that came with the opener and reprogramed the remote to the opener. The instructions are in your owners manual and are pretty straight forward.. John
Posted on Dec 11, 2008
  • 3 Answers
SOURCE: garage door opener
I was having a problem with the remotes. Program one remote, and the other stops working and vice-versa. I found the solution to be as follows: Using 61LM single-button remotes for Lift-master WhisperDrive (belt drive) garage door opener, I set the dipswitches (find them by removing battery replacement cover) to identical settings in both remotes. Set the first dipswitch to the neutral (0) setting. Next -- and this is the important part -- press the learn button on the main door opening unit, and, while the small LED light is lit, press the button on ONE of the remotes. DO NOT REPEAT ON THE SECOND REMOTE. Upon doing this, I found that BOTH remotes at last worked. I then went on to program a keyless entry pad, which was accomplished by again pressing the learn button on the main unit, and then entering the number sequence I had chosen for my entry code on the keypad, and pressing Enter. Both remotes continued to function and the keypad functions as well.
Posted on Jan 17, 2009
ktkodama
  • 37 Answers
SOURCE: I want to re-program my keyless garage door.
Mulleta,
If you look on the back or side of the garage door opener you will see a small square red/orange button.
Push the button one time, and you will see an amber LED come on. Go to your keypad enter a four digit (of your choice) then press and hold the the enter button until the garage door opener light flashes and you hear a clicking sound. You can release the enter button and it will be reprogramed.
Posted on Apr 02, 2009
  • 10 Answers
SOURCE: garage door indicator light blinks 5 times
this probably means you have a bad photo eye if you happen to have to doors side by side may be picking up on other sides photo eye just switch sides from left to right, however if the lights are coming on but does not mean that photo eye is not bad it has a small circuit board inside of it...
Posted on Apr 05, 2009
  • 3197 Answers
SOURCE: Sears Craftman Garage door opener model # 41A3493-1
That isn't the model number you give it is the part number for the logic board. The model number is on the opposite end of the motor unit and starts with 139. If you are asking if the opener should reverse when it hits an obstacle the answer is yes. If it doesn't it is not adjusted correctly or is faulty.
Posted on Dec 01, 2009
My condo has a Chamberlin Elite Model sl 3000ul3. I have a 2015 Lexus & am having trouble programming the garage door opener with the car. Can you help?
go to manualsonline.com and find the garage door model's manual. read it along with your cars owners manual. make sure you are parked close/under the opener as you try to program for best results.
Nov 27, 2015 | Building Materials
Garage door send receive signal
Caution: do not use LED bulbs with garage door openers. They are a possible source of signal interference between the transmitter and receiver on the opener.
Mar 22, 2013 | Sears Craftsman LiftMaster Chamberlain...
How do I program my garage remote in my 2003 es300 Lexus?
You probably need to program the garage door opener,not the car.I have only had to program the Craftsman opener in my garage once(our 2005 Grand Caravan has a built in opener)The opener should have a programming button(my Craftsman opener's button is under one of the light covers).It will probably have the programming instructions near the button(in TINY print).You will want to have ALL of your garage remotes handy(to make sure they all still work after adding the car's remote-some openers have a maximum number of transmitters allowed.
May 28, 2012 | 2003 Lexus ES 300
I recently bought a house which has a craftsman 1/2 HP garage door opener. The garage door opener works fine using the wall mounted pad and also the numeric key pad, but not with the remote that came with...
If you didn't, try programming the remote this way.
Press and hold the button on the remote and then press and immediately release the smart/learn button on the motor unit. If this doesn't work you need to make sure you have the correct remote for the model opener you have. Your model number doesn't bring any results from Sears Parts.com.
Nov 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
I want to program garage door opener to my automobile Homelink system...lexus where is the so called training button on the garage door opener so I can program it to my Homelink system in car.
IF IT IS A CRAFTSMAN / LIFTMASTER / CHAMBERLAIN IT IS A SQUARE BUTTON WITH A LITTLE LED NEXT TO IT. YOU WILL SEE AN ANTENNA WIRE HANGING DOWN, IT IS ON THAT END OF THE UNIT NEAR THE MIDDLE.
HOPE THIS HELPS
Jun 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
Programming remote, unit will not flash.
The easiest way to program is to hold the button on the remote while you press and immediately release the smart/learn button. If it worked before there is no reason for it not to work now unless it totally failed.
Oct 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Have two remotes for my liftmaster chamberlain,. i can only get one or the other to work,. so they both work ,. but i cant get them to work together,. nor can i get my lexus built in car opener to except...
Regards the remotes. One of them has reverted to an earlier technology and they will both work but not together. You will need to purchase a new remote (make sure it is the same model). Once you have the new remote you will need to program them. One of your old remotes will work with the new remote and the other will not. Remove the batteries from the bad one and trash it. You will have future problems if you don't.
For your car opener. If it is Homelink you can call this number and I am sure they will help you. You will need to be in your car and at your garage. 1-800-355-3515
Jun 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
I CAN NOT PROGRAM MY BUILT IN CAR REMOTE ON MY NEW 139.53985DM
didnt try everything cause if you did, it would work! Get two people and garage door opener. One read manual from car under Garage door" or Homelink while other pushes button. When manual says if this did not work or if you have security plus or rolling code, continue with other instructions. You will need a working remote and will need to pushh learn button on motor logic board.
Dec 25, 2008 | Sears Craftsman LiftMaster Chamberlain...
Programming remotes for garage door
sounds like you are doing keypad ok. is battery good. as far as homelink in car. follow directions for rolling code/security plus.
Dec 13, 2008 | Sears Craftsman LiftMaster Chamberlain...
Home Security Logo
22 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
