Question about Cannon Speed N Temp Sensor
I have a 3 yr old cannon speed n temp,the monitor goes blank by its self at different depths,70ft it might go out bring it up to 20 it goes on,batteries good,will a small ch
Unk out of the cable cause it,also if i buy a new sensor will it work with my 3 yr old monitor
2 Suggested Answers
mikesreel
  • 76 Answers
SOURCE: Cannon Digitrol 1V bottom tracking not working
Hello!
Here is the user manual for your downrigger:
DT IV Downrigger
The programming starts on page 12.
Best of luck!
Mike
Posted on Sep 27, 2009
The self-closing valve on our 13 year old ST60 speed transducer now only closes sometimes when the blank or impellor sensor is removed. We suspect that a spring is missing. We need a raymarine spare part...
Spring not available must buy housing and replace or if it is sleeved, buy housing and slide in new sleeve there are two different types, one has a removable sleeve with flapper
A long shot would be Raymarine tech support 800-539-5539
I can sell you the part 847-746-0100 technicalmarine.com
Feb 20, 2010 | Raymarine St60 Plus Package, Includes...
VL 1716 monitor. The display blanks out after 20-30 seconds. When I turn the power OFF anf Back ON, the display comes back normal, then blanks out agin after 20-30 seconds. The power light stays green.
This is due to system goes to stand by mode or Hibernate mode. To disable, go to power management and disable or incrase the time for the same.
Revert back for more assistance. Also give your valuable feedback/rating on the same.
Feb 08, 2010 | Computers & Internet
Samsung 913v Self Test fine but screen goes blank in seconds
Its your VGA cable that runs from the monitor to the computer and u may also have a bad power chord
Jan 25, 2010 | Samsung SyncMaster 913V 19" LCD Monitor
Temp cycle span from on to off is 32 and 33 degrees respectvly
Obviously the thermostat calibration is out, most manufactures allow a tolerance of + or- 10%, so yours is outside this range.
You can compensate by setting the temperature lower by say 20 degrees, this will then bring it within accepted tolerances.
Hope this helps you.
Dec 16, 2009 | Whirlpool RBS305PDS Electric Single Oven
Monitor goes blank after 2-3 seconds
could be hardware failure but i would try buttons on front of monitor first. notice, usually green led on monitor is green, if it goes to amber, you are loosing sync pulse.
Aug 20, 2009 | Computers & Internet
My samsung 923 nw wont display anything!!
check to see if you get image when lowering the resolution, do this with yoru older monitor try to bring it to a basic 800x600 with 16 bit color depth. then switch monitors and see what happens. If this monitor is energy efficient you may want to check on the power savings settings for your computer.
Jun 01, 2009 | Computers & Internet
Monitor goes blank after being on for 1 minute
it's not yr monitor problem. it's a basic system problem u need to clean yr ram or ser CPU internal Cables connectors or make sure yr pc is clean if yr pc has dust problem clean with Blower and remove dust then try it's help u..
if u don't know how to clean **** please don't do yrself.. contect yr engineer.
Thanks
Please vote
jo_chinmay
Jan 01, 2009 | BenQ FP71G 17" LCD Monitor
No depth reading while on plane.
Depending on your transducer type, you may have a liquid filled type that simply needs refilling. If this is the case check for leaks and get it redone. If not it could be transducer placement or cavitation under the hull.
Jun 18, 2008 | Raymarine A65 Combo GPS...
3yr old got ahold of monitor
ok, get to the event where you get this to happen "...then turn it back on the monitor does come on normally...", but just after power-up, press the F8 key to go to safe mode. If nothing visible, press ENTER anyway...get to safe mode yet?
Oct 27, 2007 | Computers & Internet
Vx900 viewsonic monitor problem . Blank screen except for power off/on
no, Viewsonic has the part for sale 42.99 - free shipping. Easy to replace
May 25, 2007 | ViewSonic VX900 19" Flat Panel LCD Monitor
Cannon Speed N Temp Sensor Logo
44 people viewed this question
Top Cannon Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Cannon Boating Expert? Answer questions, earn points and help others
