Question about Epson WorkForce 600 All-In-One InkJet Printer
Epson 630 workforce won't fax to some numbers.
When I call the fax line from my phone the fax line answers. When I dial it from my fax it says no answer. Like there's a transmission connection missing or something. They are all valid fax numbers who are receiving faxes from others. Thanks!
    New Friend:
Followed edger allans remedy and now faxes that where not answering before now are. i think mostly because i had it set to, 1 ring to answer and i changed to 6. thanks.
Posted on Dec 20, 2013
Basti
  • 1447 Answers
SOURCE: cannot send out faxes
Directly from the wall, phone line should be connected to to Line port at the back of the printer and answering machine should be connected to EXT. port from the back of the printer. Make sure on the fax setting on the printer that you have all the info already ( ur number and stuffs), communication setting on the printer, drd set to all, ecm to off, v.34 to off, rings to answer 6 and dial tone detection to off. and answering machine distinctive ring pattern should be set to 4rings.
And since you are using DSL make sure that line from wall should have a filter then connect it to LINE port at the back of printer...
Posted on Apr 06, 2008
Basti
  • 1447 Answers
SOURCE: Epson ACULASER CX11NF incoming fax problem
Try this:
Unplug line from back of printer
Set the Incoming mode to autoswitching
set DRPD to Off so that it will recognize all incoming calls
** if possible call your telephone company and set a distinctive ring pattern for phone calls
replug cable on line port at the back of printer
then ask someone to send you a fax...
Posted on Feb 22, 2008
  • 77 Answers
SOURCE: Epson Aculaser CX11NF won't receive faxes
Change your incoming mode from "autoswitching" to "TAM" (TAM is short for telephone answering machine" Press the "Setup" button on the control panel Use down arrow twice to select "FAX SETTINGS" Press the right arrow once The FAX SETTINGS menu appears Press the down arrow twice to select RECEPTION SETTINGS Press the right arrow once Press the down arrow unit INCOMING MODE appears in display Press the right arrow once Press the down arrow until TAM appears in display Press the right arrow once. That should do it for you If I got lost somewhere, it is in your Operator's manual - look in the index for TAM Hope it helped Ed
Posted on May 23, 2007
rhoncruz
  • 134 Answers
SOURCE: how do you fax from epson cx 9400
Try this link
http://files.support.epson.com/pdf/cx94f_/cx94f_pg.pdf
I hope it helps!!!
Posted on Dec 12, 2008
  • 357 Answers
SOURCE: Need to Fax from my Computer using an Epson Workforce 600
Check your software fax settings.
Good Luck.
Posted on Feb 16, 2009
How do I connect A Epson WorkForce 845 to NBN & Telephone
If your phone is provided by broadband then it is now a VoIP phone. In order to use your machine, you will need a fax gateway or a digital to analog converter. This will allow your fax machine with uses a analog line to connect to a digital VoIP line. You will need to connect your nbn provider.
Sep 05, 2014 | Epson WorkForce 845 Wireless All-in-One...
Epson 610 Workforce Printer Error; Light Bar won't reset
Sound like the scanner is the issue, is it under warranty? OR the Scanner may be locked, check for the scanner release device unlock it,.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Dec 17, 2012 | Epson Workforce 610 All-In-One InkJet...
How decrease number of rings for answering
Here is the link to the Printer user's manual.
http://files.support.epson.com/htmldocs/wf545_/wf545_ug/index.html
Look in the Faxing Section under Setting up Fax features.Then look under:
Setting Up Fax Features Using the Product Control Panel
Go to the "Fax Communications Options" section.
Look for "Rings to Answer"
Aug 25, 2012 | Epson Workforce 645 4x Ink MFC
Epson workforce 520 won't recognise ink cartidges
When replacing ink on the Epson Workforce 520, Ensure the cartridges have the correct/same number of gold contacts. Ive seen them with 7 and 9 gold square contacts and they were otherwise identical, and the ones with 9 contacts threw an "cartridge not recognized" error on the printer's dispay.
Feb 24, 2012 | Epson Workforce 520 Printer
I have an Epson 630 All-in-one printer. I am having trouble receiving faxes. I have a DSL line (w/ proper filter) connected. My phone extension is a wireless type. Our phone service has a voice mail...
It sounds from your description that you have the Rings to Answer set properly; however Rings to Answer is not necessarily available in all regions. You may need to check with your telephone service provider to see if this feature is available.
There are a couple of things you can try:
Check to make sure that the V.34 setting on the fax set-up menu is turned off.
Make sure that the ECM setting is turned on.
If neither of these two settings resolve the problem if may be that either your telephone line service does not facilitate this option or it is not compatible with your voicemail service.
Jan 23, 2011 | Epson RX630 All-In-One InkJet Printer
Do you have to hook the phone wire up to the modem to send faxes on a workforce610?
Yes you do have to have the phone line conected to the workforce to send or recive a fax.
You can get the manual on the link below if you need it.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=130786&prodoid=63084540&category=Products
Good Luck and please rate 4 thumbs up for the free answer
Sep 02, 2010 | Epson WorkForce 600 All-In-One InkJet...
Able to send faxes but unable to receive.
you need to check how the fax machine is setup for receiving faxes. i recommend you try it first without the answering machine, to see if it works. if it doesnt, then it has to do with the auto answer or the number of rings not set right, if it does work, it could be that you need to set it to check for fax while the answering machine is answering, check the manual under answering faxes.
thanks adi
Dec 10, 2009 | Epson WorkForce 600 All-In-One InkJet...
I get error 0408 when i try to fax. Using epson
Communication error,try defaulting the machine ,check the line with a good telephone make sure you have dial tone.
Good luck
Sep 21, 2009 | Epson WorkForce 600 All-In-One InkJet...
WILL NOT RECEIVE FAX
Fax machines are ANALOG devices and are designed to have their own dedicated phone line. They will not work reliably on DIGITAL phone lines.
Dec 02, 2008 | Office Equipment & Supplies
Epson WorkForce 600 All-In-One InkJet Printer Logo
2,164 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
