Question about Rockford Fosgate Punch P8002 Car Audio Amplifier
I have a Rockford Fosgate P800.2 amp that has power and sound but no bass.
I previously had this problem and i just had to move my RCA's and it fixed the problem for a while. But now nothing helps it. I tested the sub on a different amp and it worked fine. and tested the amp in another car with a different CD deck and it still dont work. I believe it is the RCA jacks on the amp itself. but i am not sure. Any ideas on what it is and how to fix it?
SOURCE: Rockford Fosgate 800a2 To 2 SVC 2ohm subs
Ok.. Bridge the two sub into 4ohm than bridge to amp.
So. this how it goes.
sub1 + -
to      | |
sub2 - +
=      4ohm
           From Sub
                Two
amp (L) - + (R)- +
This will use the full potiental of RF 800a2 amp. I believe it like 1153 watts max out.
Posted on May 29, 2008
  • 109 Answers
SOURCE: My amp only powers the subwoofer when the radio is on but wont when the cd player is on
The person(s) who hooked up your system made a boo boo. They wired your remote turn on lead to the power antenna lead instead of the amp turn on line (both are blue and easy to mix up). Thus when your radio is on it sends a signal to the amp and the amp turns on, but when you set to CD the signal goes away and your amp shuts down. Easy fix, just re-wire the amp turn on lead and the problem will be fixed.
Posted on Jun 24, 2008
  • 4 Answers
SOURCE: How much would installing a headunit, amp, and subs usually cost?
hows it going so you need it to be installed or you can install this yourself? well the best bet fund to get stuff done cheap is t get the stuf you will need to do an install like a install wiring kit and tools and post a installer help on craigslist.org iin your local area would be the cheapest way or just go to your local audio stereo shop thanks again and i hoope this help have any more questions please feel free to contact me if you need a step by step install i can help you in that and save you big bucks thanks again. always forward jcbproducts
Posted on Dec 03, 2008
  • 102 Answers
SOURCE: amp only has red thermal light on. some times the
Please review your wiring, both INPUT and OUTPUT
Posted on Apr 12, 2009
etirbynnor
  • 655 Answers
SOURCE: Rockford fosgate 800 a2 amp power?
Hello desperate2le,
Watts delivered is a function of the voltage times the current. If the amp was 100 percent efficient, it would need 33 amps at 12V for 400 watts. At 14.4V, it would only need 28 amps. Of course, amplifiers are NOT 100 percent efficient, only about 50-60 percent in many cases, but somewhat higher for monoblocks, maybe 80-90 percent. So you're looking at a fuse in the 60-80A range. In the absense of a specific fuse size from the manufacturer, I'd start the primary fuse at a 60A and if the amp blows it on power up/immediately/frequently, move up to an 80A.
All of the Rockford-Fosgate 2-channel bridgeables I've ever seen show using the left positive (+) and the right negative (-) for bridging. But if it's not shown right on the amp, I'd call or email RF for the correct connection. The new amps do show it.
Hope this helps.
Posted on Apr 28, 2009
Fosgate 1500 amp settings
low pass of course set the crossover around 80Hz. Then turn the bass down to around 35% on headunit and the volume all the way up on your head unit just below distortion. slowly turn the amp gain up until you start to hear distortion, then turn it back down until it's completely gone. Then, lower the gain just a little more to make sure you keep out the distortion on all songs. From here you should be good. If the gain is still to high. The adjust to your taste. Just don't move the bass up on the headunit or the gain past your distortion point.
May 22, 2012 | Rockford Fosgate Car Audio & Video
Why does my 6x9 amp drop or not let the sound play at all when my subs are on? it just started to happen? they worked together fine before. i turn the subs off and the 6x9 work? but when i turn the subs on...
You probably have too much hooked up for the size of your power supply which is presumably a small car battery. You either need to get:
A) New, better bigger battery.
B) Capacitor in series with battery.
C) Both of the above.
Mar 08, 2010 | Rockford Fosgate Punch Stage P212 S4 Car...
ROCKFORD FOSGATE X7a Amp, I need compatiable remote control knob.
It will NOT work!
You need p/n AP-3212. If you are in USA then contact Rockford for this part number.
Aug 11, 2009 | Rockford Fosgate Type RF X7 Car Audio...
Rockford fosgate p3001 lights up but around logo doesnt
check and make sure all powers (12v) and remote ground are were they should be then check signal outputs is in the right spot comeing from (THE Radio) to THE AMP imputs.THEN CHECK ALL OF THEM AGAIN. if thats not it you will have to bring it to someone like me and be charged around $30 an hour to fix.
Jun 12, 2009 | Rockford Fosgate P3001 Car Audio Amplifier
401s Rockford Fosgate Amp. Not powering on,just protect lite is on.
try hooking the remote wire to a rem wire on the back of stereo. post and let me know results
May 30, 2009 | Rockford Fosgate Punch 401S Car Audio...
Quick question, amp problem
make sure you ground wires arent shared, meaning run each ground wire from each amp to its own grounding point
Sep 08, 2008 | Rockford Fosgate P3001 Car Audio Amplifier
RockfordFosgate p2 series
i would get a good pair of RCA's that might help. if not they also make a noise filter that you can add to your RCA's, bad ground could be the problem to.
Aug 13, 2008 | Rockford Fosgate RFP3410 Car Subwoofer
Bass control stopped working
on rockford amps, the bass control knob needs to be connected to get the maximum output (+18 db gain i believe). If you did this to the power wires, then yes, you may have at least damaged the bass control knob. Try replacing this to see if you get all of your gain back. If not, then you have damaged something inside the amp...maybe a capacitor or power supply inside. If that's the case, you'll need to get the amp looked at by an electronics repair technician or local stereo shop.
Aug 10, 2008 | Rockford Fosgate P3001 Car Audio Amplifier
Rockford Fosgate Punch P8002 Car Audio Amplifier Logo
42 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
Tygh Duval
Tygh Duval
Professor_V
Professor_V
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
