Question about IBM ThinkPad T42 Notebook
Fan replacement Hi my T42 recently came up with a fan error so as it's so old I decided to try and fix it myself...looked realatively easy on the youtube clip I watched but its all proving more tricky than I had hoped! To start with I haven't managed to extract the old one(with keyboard and palm rest removed} despite removing every screw I can find - it still wont budge Any suggestions? Secondly I ordered what I thought was the right replacement part via ebay (listed as a T42 fan) but now it's arrived I can see its not the same. The existing (dead) one is much longer than the one that's just arrived. My question is will the short one work inplace of the original long fan? (I've just done a search on ebay for the longer version and they are significantly more expensive so I'm hoping the answer is positive). PS I'm a TOTAL novice so please use non-computer lingo if possible, cheers. J Fletcher
  • Janet Fletcher Feb 08, 2012
    Many thanks for your comments
    unfortunately I've now caused a bigger problem and the whole thing seems lifeless.
    Think I may have blown a fuse or killed it totally (I reconnected the keyboard with the power on, as it powered up the keyboard slipped and I guess came in contact with the TP innerds and now it doesn''t work at all, not even a power light!
    I'm kicking myself...I can't afford to replace it...should just have taken it to a computer shop in the first place and no doubt been ripped off. Do you think there's anyway of fixing it now?
  • 807 Answers
It could just be stuck with the heatsink past underneath the assembly.
It sits on top of the processor and they can stick quite tight.
Try and ease/slide it left and right a few times rather than pull it straight off.
A shorter one probably wont do the job as well as the larger one.
The size of heatsink required to remove the heat correctly is caluclated during the design.
Posted on Feb 07, 2012
Fan error displace on my t42 ibm.I noticed the fan is working but the error do come once in a while thereby prevent the pc from working
If the fan is running but your notebook still overheats, your computer will turn itself off, and you need to wait until it cools down
The question is, why is it overheating? Try using a vacuum cleaner close to the ventilation slots to suck out any dust.
If this does not solve the problem, please get back to me
Jan 24, 2014 | IBM ThinkPad T42 Notebook
IMac (mid 2007) fan speed running super fast after replacement of Hard Drive
The clue is in your first few lines. Put the sensor back where it came from.
Jun 09, 2012 | Apple 20" iMac Desktop
My ThinkPad T42 cooling fan works slow... i feel like air flow is very slow when i touch the vents... i opened the laptop and checked the fan and it was really slow.. what should i do now please help......
You should replace the fan if it is defective.
You can check inside your Bios or System Setup to see if there are any options on controlling the fan. If the laptop is not giving you any error messages or overheating the fan might be ok.
May 06, 2012 | IBM ThinkPad T42 Notebook
Optoma HD65 Fan Replacement?
im after a fan for the optoma hd65 projector its a sunon 12v 3.0w 20x60x60
Mar 14, 2012 | Optoma HD65 DLP Projector
Hi Joe. I have a PGB036100-1 package gas/AC unit and the AC condenser fan will not shut off. Seems like a switch has burned out and the default is to leave the fan on. Maybe it's an easy fix? ...
At first - when I read your problem - I thought the contactor was stuck (in the run position) and that was what was causing the condenser fan to run all the time, but if that was true - the compressor should run all the time also. Because, in most units the "contactor" is the component that 'starts and stops' the fan motor AND the compressor.
So, this is kind of a mystery.
What I would do is make sure the fan motor is wired correctly. The wires going to the fan motor must be on the "load" side of the contactor. If they are wired into the "hot" side of the contactor (where the incoming power is wired) - the fan motor will run all the time unless the breaker is turned off.
After thinking about it - I'm thinking that is your problem.
Jun 06, 2011 | Heating & Cooling
Hi BMW mechanics, i have a '89 535i auto... my vehicle has been overheating a fair bit recently so i decided to look at it myself..... i noticed a crack in the top radiator hose so i replaced it with a...
If it's not overheating after the repairs chances are it's ok. A common overheating cause for older BMWs is the Thermostatic Fan Clutch failing. You can do a quick check by bringing it up to normal tempature and looking at the back of the fan = manualy gun the engine to a few thousand rpms, if the fan blades don't seem to follow the changes in RPM it's proubly the cause. If you have a timing light handy, it would help you see the changes in fan speed when pointed at the fan blades.
May 12, 2011 | BMW 535 Cars & Trucks
Fan Error message but the fan's working on another machine
One option would be to replace the motherboard. You can use one from T40 -T43 with your monitor. I bought one on Ebay for $90 which came with the board installed to the bottom plastic tray. I only had to install my monitor, memory, keyboard, hard drive, & plastic bezel and I had a good working unit for $90.
May 15, 2010 | EliteGroup A530 Notebook
IBM T42 gave fan error, replaced and can not get it to reboot
make sure the fan is pluged in correctly and you didnt unplug anything else such as memory or etc or bump the cpu... did you put any thermal paste on the cpu when you put the fan on it? its needed to bond the too together to make a better cooling system there maybe a setting in your bios to disable fan monitoring or cpu temp etc have to look at your bios to see
May 27, 2009 | IBM ThinkPad T42 Notebook
IBM Lapyop T42-message"Fan errors" does not turn on
your cooling fan is reporting as damaged you need to replace the fan unit (cooling pad as well) likely service is required and unless you want to disassemble your laptop a service center would be better suited for this job.
Dec 13, 2008 | IBM ThinkPad T42 Notebook
Sent you a fix on the tv...
Four flashes indicates fan error. Most likely candidate is the lamp or exhaust fan. With a flashlight look through the back of the set behind the fan when you first try on. You should see if the fan is moving or struggling to move. If its slow or not turning that's your problem. The fan needs to be replaced.
Oct 01, 2008 | Sony KDSR50XBR1 50" Projection HDTV
IBM ThinkPad T42 Notebook Logo
56 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
