I can not locate my DVD RAM/DRIVE in the my computer
I think that some drivers in my DVD R are not workink
  • 807 Answers
If you mean the drive icon has dissapeared then try this. CD Drive Fix
Scroll down to "Let me fix it myself" read it carefully as it means you have to change values in the registry, it may sound daunting if you have'nt done it before but if you take your time it's not that bad.
Posted on Feb 07, 2012
Need drivers for a MATSHITA UJDA730 DVD/CDRW
are you sure it the drivers?
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
http://download.cnet.com/matshita-dvd-ram-lf/3000-2110_4-82302.html
http://download.cnet.com/matshita-dvd-ram-lf/3000-2110_4-88634.html
http://download.cnet.com/matshita-dvd-ram-lf/3000-2110_4-82303.html
http://download.cnet.com/matshita-dvd-ram-lf/3000-2110_4-88638.html
here are 4 different model drivers
hope this helps you
Aug 30, 2011 | Panasonic UJDA730 CD-RW/DVD-ROM (Combo)...
I can't work with my DVD Drive LG HL-DT-ST DVD RAM GH22NS50. It is saying (Code 10) thanks
you might have to uninstall both the dvd/cd + its drivers then reinstall them actually unplug the cd/dvd from its power cable then restart your computer plug it back in your computer should activate found new hardware or
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
Jan 25, 2011 | LG GH22NS50 22X DVDRW SATA Drive OEM...
My dvd ram drives lf d201 is not workink
FGirst check if CD/DVD drive is detected in the computer or not.
For that click on the start and select Computer/My computer.
if CDdrive is not getting detected or detected in both cases we will perform below steps.
Open device manager window.
Uninstall CD/DVD drive.
Click on the start>>All programs>>Accessories>>Run
Type regedit and press enter.
The Registry Editor opens.
Double-click the following items in the list:
  • HKEY_LOCAL_MACHINE
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
Select 4D36E965-E325-11CE-BFC1-08002BE10318 . Make sure you have selected this exact key name. If a LowerFilters value is listed on the right side of the registry editor window, click the LowerFilters value, and press the Delete key. Confirm the deletion by clicking Yes .. If a UpperFilters value is listed on the right side of the registry editor window, click the UpperFilters value, and press the Delete key. Confirm the deletion by clicking Yes .. Close the Registry Editor window. Come back to device manager window. Click on the Action tab and select Scan for hadrdware changes. If CD/DVD drive will not work replace the drive. It is gone bad.
Apr 12, 2010 | Panasonic (LF-D201) DVD-RAM Burner
H22L Dvd-Ram reads Cd's not Dvd's.
the lense of the drive become weak.
there two variable resistance under the lense 1 for cd and 2nd for dvd . slightly adjust them and then check again.
it works only ion some cases. otherwise chande the drive with new one.
Dec 01, 2009 | LG (DAD-8020B) DVD-RAM Burner
Why my DVD ram can only read CD-R and not any other media
update the driver file for it....right click the drive, click properties, it will give you a description of it...go to the tab that has the driver file description and click update driver...let it go online...it will get the correct generic driver for your dvd-ram drive.
Sep 24, 2009 | Acer Aspire T310 PC Desktop
Cd / dvd ram driver corrupted or missing
First if the computer is under warranty take it to get it fixed opening the case will void the warranty. if it is out of warranty consider opening the computer case your self and firmly make sure the wires are well connected. the reboot. third try downloading the driver form the manufacturer's web site. i think that brand is a Panasonic. If that still fails you might have a bad drive, which you can replace or have a local shop replace it. sites like newegg.com and tigerdirect.com have adequate replacement drives.
take a good look at reinstalling the driver. you can use the device manage for this or usually the driver form the mfg. will have an install package.
-good luck-
Will
compressionconnector.com
Feb 19, 2009 | Computers & Internet
I can't play DVD-RAM recored on my camdorder on my computer
dvd player on computer must handle dvd-ram standard
Nov 15, 2007 | Video Cameras
DVD Ram Disks
Sounds like it's just fried... Sorry... There is a universal driver for CD-rom(same with DVD-Rom drives) drives that windows uses.. so if it doesn't work it's not cause of the drivers(especially if you just reinstalled windows or it was just repaired since it reinstalls the drivers from the cd)
Oct 05, 2007 | Hitachi GF 2000 DVD-RAM Burner
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
