Look in the air intake system, there is a mass air flow sensor from the air filter...
Part Replacement link HERE
Hope this helps; also keep in mind that your feedback
is important and
I`ll appreciate your time and consideration if you leave some
testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
SOURCE: mercedes-benz c220 1995 model car radio cassette password
hello,you need to contact your dealer regarding your radio code,
SOURCE: i have a mercedes benz C220 cdi '01 and i wan't to
for the 220cdi,it is a 611.961 motor, you have to refill 6.5 liter,included the olilfilter.Whenyou have refill,and after the motor has running,you can check the oil-level in the board-computer.
succes
SOURCE: 1995 Mercedes Benz C220 will not start, and key
hello,steering lock mechanism and your key need to replaced,if you want try to remove your under dash,steering lock mechanism have a small pin(around 5 mm) which pit to steering housing,drill out the lock,then try to turn steering wheel,ty
SOURCE: MERCEDES BENZ 1996 C220 WONT START,GETTING FIRE AND GAS
Ignition Timing is Most Common Mistake for this Repairs No Start Problem
Testimonial: "info was very helpful"
SOURCE: how to reset airbag for mercedes benz c220 1994
This can not be reset by conventional methods. This must be done through a scan tool. Usually only the dealer scan tool will communicate with the SRS module. If the SRS light is on you have other issues and they must be remedied before the light will go out. There is no way of knowing what the issue is without running codes with the scan tool.
It depends on what depo it was made at .. Whats the first letter or number on the VIN??
