Question about RCA VR546 S-VHS VCR
Connecting vcr to tv
I have the user's guide but it does not tell how to connect RCA VR637HF to front of tv. I want to hook up temporarily to watch videos or tape. I have tried to hook the cables to the back of vcr and front of tv and then tried front of vcr to tv. Neither way works.
Thanks, Sam
  • 10,594 Answers
Find Video & Audio Out pins at back of Combo player. This is output signal which will be connected at Video & Audio Input at front of TV. Watch out video pin will go to video input. Now select AV input of TV by remote. Usually its AV-4.
Have fun, or need more info, let me know the out comes.
Posted on Oct 22, 2008
How do we hook up VCR to TV
  1. 1
    Turn off all of your components. This will help prevent any accidental damage while connecting.
  2. 2
    Connect the RF/COAX Out port on the VCR to the RF/COAX/ANT In port on your TV. Use a coaxial cable.
  3. 3
    Connect your antenna to the the RF/ANT In port on the back of your VCR (optional). This will allow you to watch over-the-air broadcasts through the VCR.
  4. 4
    Turn on the VCR.
    • Make sure that the VCR is plugged into the power outlet.
  5. 5
    Set the VCR channel to Channel 3 or 4.
  6. 6
    Turn on your television to the same channel that your VCR is set to.
  7. 7
    Start playing your tape.
or check this site:
How to Hook Up VCR to TV
May 19, 2016 | Televison & Video
How do i hookup a sanyo vhr h607 to my television
Unless the VCR has a digital tuner the only way to record off the TV will be to connect it by a scart socket and cable. However to record you would have to watch the TV show you are recording. An alternative is to get a set top box, which are fairly cheap and connect that to the VCR. Some VCR's have two scart sockets one for the TV and a spare one. You can connect the box via the spare one. When setting the recording you will have to select AV2. If the VCR has only one scart socket you might need a scart switching box.
Oct 17, 2014 | Sanyo VHR-H607 VHS VCR
I have an older tv with only a coaxial cable connection on the back, no others. I have a Magnavox dvd/vcr combo that does have RCA connections available and also a coaxial cable connection on the back. I...
First make sure you have the cable connected properly.. on the vcr it should be connected to the OUT coaxial connector.
Second.. the VCR usually has a VCR/TV setting..
Most TV's must be set to channel 3 or channel 4 to output the signal from the VCR when getting the signal via Coax.
So..insert a tape...hit play..tune the tv to channel 3 if you are not getting the playback signal..press the VCR/TV button on the vcr or vcr remote.
Repeat this on Channel 4
Check your cable to make sure the connections are tight.
Finally check your television menus for Input settings..make sure it is set to COAX/ANT
Make sure your VCR's output is not on some alternate output like L1 or L2 (line one or line two)
Best of luck!
Apr 22, 2011 | Televison & Video
I have an RCA VCR model VR651HF that still works great. I can record shows without a problem as long as I'm not trying to watch a dvd. I recently bought a Sony dvd player model DVP SR200. I have my cable...
The sequence should go from the wall to the VCR then the VCR to the RF modulator then from the RF modulator to the TV and this should allow you to record a TV program and watch a DVD at the same time.
Feb 25, 2011 | RCA VR651HF VHS VCR
Got cox Digital cable box today, cox can not tell me how to hook up to box to make it rec/play. Info I read old cox papers from 2002 says I need a vcr controller, Cox does not know what that is and it...
For a standard VCR which is what most people have, all you need to do is connect a yellow RCA cable for video from the yellow output jack on the cable box rear panel to the VCR's yellow video input jack on its rear panel. Next connect a white RCA audio cable from the cable box white RCA output jack to the VCRs white RCA audio input jack. You can record a cable show by selecting the LINE input on the VCR and selecting the TV show on the cable box.
Now for playback, connect the VCR to your TV. Connect a yellow video cable from the VCR's yellow output jack to the TV's yellow video input jack. Same for the white audio connection. Select on the TV, the source input for the VCR. Its not complicated and you should not need any other devices for a standard setup with a digital cable box and vcr.
Aug 25, 2010 | Toshiba Televison & Video
I need to know how to hook up my vcr to my dvr to record something off of it onto a vhs tape. directv said i need to contact the maker of the vcr & guess what RCA doesn't help with that. but i...
Ok. You connect the vcr to the televison first. Take an rca cable and connect it to the video out of the vcr then connect the other end to the av input on your television. Then take another set of RCA cables and connect them to the RCA av input on your vcr and connect the other end to the output on your dvr.
Now hopefully your tv has another RCA input you can hook directly to the dvr with another set of RCA cables to another one of the dvrs outputs. If not then don't worry about that.
Now make sure the tv is switched over to the av video RCA input the vcr is connected to and turn the vcr on. The vcr should be in input and when it is you will see the picture from your dvr and you will change channels with your dvr remote. You can now record using the vcr remote.
Jun 14, 2010 | RCA VR546 S-VHS VCR
How do I connect a sony vcr plus to my tv?
Does your TV have a ( Red, White and Yellow) jacks in the back or front if it does great they are called RCA jacks. On your VCR locate the RCA jacks. Find the input this is where you hook the cable etc... Find the out puts on the VCR they go to the TV. ON the TV find the RCA jacks find the inputs this is where the cables go. Turn on your TV and find the input channel it maybe AV1, or video1 etc...
Sep 02, 2009 | Sony Televison & Video
Problems hooking a PS1 to a Panasonic 42" tv
your vcr has the yellow, white, and red (RCA) ports but your playstation will not. you have to buy an addapter cable to go from playstation to vcr. http://www.gocybershop.ca/customer/product.php?productid=133&cat=163
btw on your vcr the RCA inputs are not colored (if you have the one in the picture. but just as a guide, yellow=video, red=right(R), white=left(L).
Aug 06, 2009 | Panasonic PV-V4540 VHS VCR
RCA VCR # VR637HF
I have the same problem has you. I tried how to fix it, because VHS VCR are not sold anymore and i need it for my kids. They have a lot of VHS films. If i found a solution, i will share it to you.
Aug 01, 2008 | RCA VR637HF VHS VCR
Rca vcr
there a a bunch of different ways. 1) if you don't have a cable box hooked up to this tv,plug the main cable wire into the vcr input then the vcr outout to the tv.2) if you do have a cable box, plug the main cable into the cable box input, then the output to the vcr input, then the vcr output to the tv. put both the tv & vcr on channel 3 for this connection. [ you must have the vcr on channel 3 to record from the cable box!] 3) if you have aux line/video or source inputs on the back of your tv,you can hook up rca cables [ red, white,& yellow ] from the rca outputs on the vcr to the tv inputs.
hope this helps
wg
Feb 04, 2008 | RCA VR637HF VHS VCR
RCA VR546 S-VHS VCR Logo
206 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
