Question about Refrigerators
How to start the hotpoint FZ175 defrost cycle manually
3 Suggested Answers
roadrunning1
  • 152 Answers
SOURCE: terrific noise when defrosting cycle starts
check the back of the fridge, sounds like pipes are rubbing underneath, if you feel you are competent then follow the next steps, 1. Turn the fridge off and unplug it. 2. get to the back of the fridge with a good light or torch and inspect the pipe work, 3. make sure nothing is touching itself and be careful not to touch the black oval shape object as it may be hot (normal). if everything looks ok plug the fridge in and see if you can still hear it ,if the noise is anything other than pipe work , depending on the model you have , it could be either a fan bearing of the compressor is on its way out.
Posted on May 11, 2009
heatman101
  • 43501 Answers
SOURCE: hotpoint quadrio fridge isnt cooling
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on May 11, 2011
How do I stop a red flashing light on a fz175 hotpoint freezer
Unplug it - but I don't recommend that.
The flashing light indicates that it is working - and you can see it from a distance. Saves walking down the stairs to open the door of the freezer in the basement.
Worry about your freezer if the light goes OUT.
Good Luck
If this was helpful, please rate accordingly.
Thanks.
Jul 04, 2016 | Hotpoint Refrigerators
How do I fix my refrigerqtor hotpoint double door not defrostiong
Generally, if you unplug the refrigerator and set the freezer and refrigerator temperature controls to off then plug it back it, this will put the refrigerator in forced defrost mode. Keep the doors closed and allow defrosting to last for about 20 minutes. Then unplug again and reset the temperature controls to mid-range or a little above, and plug it back in. If this does not reset the defrost cycle, you probably need service.
Mar 07, 2015 | Hotpoint Refrigerators
I have a side by side fridge/freezer. Occationally the freezer side warms up and the fridge side starts icing. It happens sporatically. It is a hotpoint model hsm25gftasa. Tried giving it more air
The defrost timer also turns on heater strips buried behind the metal parts that the door gaskets touch. It may be you're just witnessing the defrost cycle. If you have lost power for a time, that affects the clock time of day the defrost cycle starts. I'd look at the defrost timer and reset the time.
Oct 01, 2014 | Refrigerators
Troubleshooting fz175 hotpoint freezer
your defrost cycle is not working due to...
heating elementin freezer is bad (replace)
thermostat is bad,,, replace
or timer is not working replace
Aug 30, 2014 | Hotpoint Refrigerators
Fz175 not cooling
it's not know how to hit it, its knowing where.... just change the cold control
Aug 08, 2012 | Hotpoint Freezers
Refrigerator has power but not cooling
A couple of possibilities: Coolant level has declined too far; compressor has failed, and finally, the defrost timer has failed. During the defrost cycle, the compressor is intentionally shut down and if the defrost timer has failed during the defrost cycle, the compressor will not be re-enabled.
You didn't include the model number so the following may not apply: The defrost timer is often located behind the lower grill of the unit. Remove the grill (often held by plastic tabs) and look for a small black box with a hole or a short protruding shaft. These often have a screwdriver slot to allow manual rotation in the event of a timer motor failure. If you find this, insert a flat-bladed screwdriver and rotate the shaft ~ 1/4 turn and wait to see if the compressor then starts up. If not, turn the shaft a bit further and wait again.
If the compressor does not start, either the relay that supplies AC to the compressor has failed or the compressor itself.
Sep 23, 2011 | Hotpoint Refrigerators
Hotpoint quadrio fridge isnt cooling but freezer is can i start its defrost cycle manually?
heatman101
May 10, 2011 | Hotpoint Refrigerators
I have a hotpoint freezer which is self defrosting but its icing up and warning message keeps flashing up
There is defrost timer, that will shut off the freezer and turn on a heating element that quickly defrosts the cooling fins. then it cycles back on. If any part of that system goes out the freezer will not defrost.
Sep 21, 2010 | Hotpoint 6.92 cu. ft. / 196 liter Upright...
What temp should my freezer be , also the fan in the top of the fridge stated making a noise when it stopped or started its cycle sounded like something was catching on the fans blades , then it stopped...
I like 0 to 10 Deg. F in the freezer.
As for the Fan. yes it could be ice or the fan blade hiting the shroud, sometimes the fan blade moves on the shaft and starts hiting the shroud.
Jan 11, 2010 | Hotpoint FFM90 Bottom Freezer Refrigerator
HOTPOINT FRIDGE - COILS FROSTING UP
as you know your unit is not going through defrost cycle. you need to replace either the control board, defrost heater and or defrost thermostat. ge is known for their defrost heaters going out.
Jun 24, 2009 | Hotpoint FFA90 Bottom Freezer Refrigerator
Refrigerators Logo
59 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
