Honeywell st9420c programmer, when the water and heating are switched on, should a flame show on both sides, or just one? I have a vailant ecotec plus 624 system boiler and unvented cylinder, and ha
  • 70 Answers
SOURCE: Installing CM900 Honeywell into Junior 24 Bosch Combi
What kind of boiler are using is this boiler a on the demand electric or gas? You need low voltage wires. If you get me make and model # of off boiler i can try and find wiring diagram . Tell me a little more about you heat system to. Like baseboard heat or in floor how many zones
Posted on Jan 16, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: I have a Honeywell Thermostat CM67NG The flame
You may have a broken thermostat wire. Disconnect the wires from the thermostat and please note what colors are hooked to which terminals. Cross the R and W wires and see if your heating system turns on. If it does not, you have a broken wire or bad connection at the heating system. If it does start, you have a bad thermostat or bad connection at the thermostat.
Posted on Nov 30, 2009
  • 36 Answers
SOURCE: boiler is a baxi control for heating is honeywell.
this will be your diaphram inside your divertor valve.
the one that looks like a spaceship.
it will e split.
Posted on Jan 31, 2010
  • 2519 Answers
SOURCE: Honeywell ST6400C programmer
Hi yes sound like it not working on hot water only it would check ou the wiring on this side
Posted on Feb 18, 2010
  • 2519 Answers
SOURCE: f22 error/ low pressure
F.22 Dry fire Too little water in the appliance, water pressure sensor defective,
cable to pump or water sensor defective, pump blocked or defective,
pump output too low
Posted on May 12, 2010
Testimonial: "thank you so much the information supplied allowed a local plumber to fix our problem in minutes 10/10"
My Honeywell dt200 is displaying a flame when I turn it on but isn't actually heating.
The problem could be with the heating unit or furnace and not the thermostat.
Aug 10, 2015 | Honeywell Programmable Thermostat Heater
Vailant ecotec plus 837 - Water pressure and temp is too high
Pressure inside the tank will rise along with the water temperature. As the water inside cools the pressure will wane until the heating element turns on and reheats the water with a subsequent rise in pressure. Running the hot water at the same time will draw heat energy from the boiler and lower the internal temp and pressure as well.
Jan 21, 2014 | Water Heaters
Flame symbol showing on theremostat
It's not your thermostat. Go to where your heating system is and give us a make and model number so we may help you.
Feb 11, 2010 | Honeywell Programmable Thermostat Heater
User guide needed for old Honeywell programmable heating control
It depends on your system some will only work with hot water on and heating do you have two zone valves?
Jul 18, 2017 | Honeywell TH4210D1005 Heater
Cannot get central heating working,for honeywell ST6400 programme
with y plan 3 connections on programmer HW on HW off CH on HW on to cylinder stat then HW call to Orange on Mvalve to power boiler and pump HW off to grey wire on Mvalve to close hot water CH to room stat common then heating call to white on Mvalve
Jun 13, 2009 | Honeywell Programmable Thermostat Heater
Jul 25, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
43 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
