Question about Pioneer Audio Players & Recorders
The bass of my Pioneer GM-5300T 760W Max, 2-Channel Amplifier turns of every once in a while
Im having a problem with my pioneer amp
760 Watt 2-Channel Pioneer GM-5300T Amplifier
RMS Power Output
4 ohms: 125 watts x 2 chan.
2 ohms: 190 watts x 2 chan.
Bridged, 4 ohms: 380 watts x 1 chan.
Max Power Output: 760 watts @ 2 ohms or 4 ohms bridged
280лв
it dosnt bass my subs it just lets vocal sounds basically my bass turns of every once and a while i dont know if it's the amp gettin hot or the rca cables or wat?
Shuttle83
  • 1139 Answers
SOURCE: speakers
400 watts delivered to 300 watt speakers the only way to do this would be to wire two subwoofers in series so that the power needed to drive them will be 600 watts to max, however this will increase your impedance on the speaker (8 ohms) load so what you can do to compensate is get an 8 ohm 600 watt resistor and put it in parallel with the speakers you will then have 4 ohms of impedance at a total capacity of 600 watts of power In other words the amplifier won't blow these out now.
Posted on Oct 09, 2007
Cerfer39
  • 709 Answers
SOURCE: Speakers
Hi Trim God,
I do not reccommend that you push the Pioneer speakers over 100 watts.  The jenson will already drown the car with bass through your pioneers so much you will want to turn off the bass boost when playing some low bass hip hop songs. It changes from one venue of song to another, so I just keep the jenson bass boost off and use my head unit to adjsut the sound to fit my listening prefences. I am telling you man, you will be blown away .  Hook up the pioneers straight to the Channels,. do not bridge.  I put Subs in my truck though.  I used the Pass output to send the audio to me Jenson 2 Channel 600W amp. I drive one 10 inch enclosed JBL Class A/B Sub. I bridged the output of the 600 W amp to the 10 inch sub  in my Z28.  The pioneers never get drowned out.  I did smoke my 2 channel Amp one time. and also took out a MTD 10inch sub. I am talk shooting flames and smoked the whole car up. I think if you bride the XA4150 to the pioneers, you will have the flaming smoke problem in no time.
Posted on Oct 13, 2007
mjap
  • 107 Answers
SOURCE: problem with LEGACY BLUE DIAMOND AMPLIFIERS LA1080
never attemp to bridge your amps specially this type of amps. this are too very complicated. you may blow your amp if you will attempt it again.
Posted on Jan 26, 2008
  • 236 Answers
SOURCE: Yamaha P4500 Power Amplifier 2-Channel Bridge mode
im from Yamaha service before and i know this model can handle as low as 2ohms per channel. I have to check on my manuals though if bridged. i dont see any reason why it cant. and it has a bridge option input stage... let me get back to you again in the days to come.
or email me redrivera0314@tyahoo.com
i have a service manual to check on this. got to dig on my closets..
Posted on Mar 19, 2008
  • 3 Answers
SOURCE: amp getting really hot
If depends on what the amp is rated to run. If it is only rated to run 2 ohms x2ch then it can only run 4 ohms x1ch. If you run it at 1 or 2 ohms that is too low, too much current, and it will get hot and eventually blow up under hard use. Some quality amps can live that way, and it depends on the sub and what frequency you are running it at. For normal use I would not recommend it. Wire to sub at 4 ohms x1 (or 2 ohms x2ch) for that amp if that is what it is supposed to be at, I'm not sure from your description. Also enhance cooling of the amp if you can, I run fans on mine if they have a heat issue. Warm is one thing, hot is another and not good for amp.
Posted on Apr 22, 2008
Wiring
you have the remto wire hook up it blue from deck to amp?
Jul 07, 2013 | Pioneer GM-5300T Car Audio Amplifier
The outputs on my Pioneer GM-5300T are intermittent and low
yes they are perfect whenever I turn up the bass it just trips on and off
Feb 07, 2013 | Pioneer GM-5300T Car Audio Amplifier
My pioneer gm 5300t amp cuts off at loud volume and will not kick back on until it is turned down and cools off, what is wrong with it?
You are over heating it,You have your speakers wired up for a lower,(OHM) Rate then the amp can handle, That why it cut out when you have it turn up
Nov 10, 2012 | Pioneer GM-5300T Car Audio Amplifier
Are subfoofer ts-w308d2 and amplifier GM-5300T compatible with each other?
Yes. You will be able to run this setup with the sub bridged across both channels of the amp, which will give you more power (which the sub will be able to handle: 380 watts rms), or with the sub wired to a single channel, which will give you less power (125 watts rms). The sub can handle 400 watts rms.
Mar 18, 2011 | Pioneer GM-5300T Car Audio Amplifier
I parelled one 15" q power subwoofer to my brideged pioneer amp.The amp got really hot and blew a fuse.How should I wire my dvc subwoofer to the briged amp.
Hello sir, hi, YOU DON'T bridge no more speakers, this upsets the impedance load of the amp. to install another sub-woofer, get another amplifier. You may have damaged your power amplifier, If you experience repeated fuse blows, your power amplifier is now SHORTED. This needs IC amplifier replacement.
Aug 19, 2010 | Pioneer GM-5300T Car Audio Amplifier
I have a pioneer 760watt model gm5100t amp and two audiobahn 12" subs and I would like to know how the wiring is configured from the amp to the subs as well as how the subs are wired since they are dual...
you bridge the inside + - and use the outside + -
then connect the outside + to the amp then connect the - to the + on the other sub then the - on the other sub to the amp just read this and do it slowly and you will get it then you only have to run the subs on a two channel amp
rate pls
Aug 14, 2010 | Pioneer GM-5300T Car Audio Amplifier
No bass coming out
u probably have to replace the rca inputs on the amp or resolder the short on them if u can
Aug 31, 2009 | Pioneer Car Amplifier GM-5100T - 2CH 760...
What amplifier should I use for 2 650W Subs?
HI DUDE .. I JUST GIVE suggestions Boss Car Audio D5504 "Diablo Series" 4-Channel Car Amplifier 2200 Watts ITS REALY GOOD FOR SOUND SYSTEM DUDEaaf1faf.jpg
Jun 10, 2009 | Pioneer GM-6300F Car Audio Amplifier
What are the correct spaekers for the gm 5100t ?
    CEA-2006 Compliant Amplifier Power Standard:
  • 125 Watts x 2 @ 4 ohms <= 1% THD+N
  • 380 Watts x 1 @ 4 ohms BRIDGE <=1% THD+N
  • 75 dBA Signal-to-Noise Ratio
  • Peak Music Power: 250W x 2 (4 ohm) / 760W x 1 (Bridge)
  • 2 Channels
  • Continuous Power @ 4 Ohm: 125W x 2
  • Continuous Power @ 2 Ohm: 190W x 2
  • Continuous Power Bridged @ 4 Ohm: 380W x 1
  • Frequency Response: 10Hz-50kHz
  • THD (1kHz, 4 Ohm): <0.015%
  • Signal to Noise Ratio: >95dB
  • Dimensions: 11 13/16” x 2 3/8” x 12 7/8”
  • PWM Regulated MOSFET Power Supply
  • Balanced Isolator Input Circuit
  • Oversized Screw-Type Power/Ground Terminals
  • 2 Channel RCA Inputs
  • Speaker Level Input
  • Screw-Type Speaker Terminals
  • Hi-Volt Input Level Control (200mV-6.5V)
  • Bass Boost (50Hz, 0/6/12dB)
  • Selectable LPF (80Hz, -12dB/Oct.)
  • Pioneer 1-Year Warranty
I'm assuming the subwoofers were bridged and couldn't handle the power. Make sure you have atleast 300 watts peak power wattage.
Feb 05, 2009 | Pioneer GM-5100T Car Audio Amplifier
Wiring
Usually an 800 watt peak sub would be a 400 watt rms. Hmmmm. Anyway, just bridge the amp (1x 380) nd keep the gain up enough to stay clean. Watch the sub and turn up gain until it starts to distort, then back it down a hair. Do this with the CD players volume up 2/3 to 3/4 volume with the BASS and treble at zero (bass better at minus 4 or so if you are a bass head! Hope thishelps.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 27, 2009 | Pioneer GM-5300T Car Audio Amplifier
80 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
