Question about Drills
My Richmond 6v cordless Drill-is obsolete can i get a replacement battery charging stand
Richmond Tools Limited Feltham Middlesex TW13 6DH was there last address . What i want to know is where can i get a replacement Battery Charging Stand or where i can get it repaired yours Herbert Norris
5 Suggested Answers
  • 34 Answers
SOURCE: Dead DW972 Cordless Drill?
Easiest and safest: take the tool and batteries to nearest shop where they sell Dewalt. Ask the guy to let you use their batteries in your tool and vice versa, your batteries in their tool. DYI procedure:To check batteries: - if you have some multimeter, try to measure voltage and if possible also amps (but only for a fraction of the second, if battery is good, amperes shoudl jump up very quickly) - if you have no multimeter, try to find 12V bulb (check spare bulbs for your car), use wire to connect and it should light up. To check tool: open it up, take some 12V DC source, put wires on contacts inside the handle where battery connects. Pull the trigger and it should work. you can try to put wires directly to contacts on the motor. Follow cables from the switch to motor.
Juraj
Posted on Jun 03, 2010
  • 250 Answers
SOURCE: have a 15.6v cordless drill
See if you can put a volt meter on the metal contacks of the charger to see what voltage it is producing. If you have a friend who has the same drill have him try to charge your batteries and then measure the battery voltage.
Posted on Mar 15, 2011
  • 1212 Answers
SOURCE: where can i get my 6v cordless drill charging stand repaired
Brand?
Otherwise depending on the setup and where the fault is, you can sometimes simply resolve the problem by swapping a wall wart supply from something else with similar ratings.
Posted on Feb 08, 2012
99rannellis
  • 9254 Answers
SOURCE: I have a Craftsman 19.2 volt cordless drill I need a battery and a charger for it battery number 13013 for one and the charger is 1401 733
Sears would most likely have it or can order it for you.
Posted on Jan 10, 2017
Won't charge fully
Carol, Black and Decker USA Factory-Reconditioned CWV9610R Dust Buster 9.6V Cordless Wet and Dry, does sound like you got a bad battery in the unit, replace battery or return if warrantied.
https://ca.answers.yahoo.com/question/index?qid=20070525003616AAhjgrS
Black Decker CWV9610 DustBuster 9 6V Cordless Wet and Dry Hand Vacuum
96V Wet Dry Cordless Hand Vac
DUSTBUSTER 9 6V HAND VAC
Mar 08, 2016 | Black and Decker USA Factory-Reconditioned...
Battery only lasts for 10 images!
Rechargeable battery have a limited number of recharging cycles so it may be that you require a new battery. If it is a fairly new camera I would take the camera back to the shop and ask for a replacement battery.
Jun 11, 2012 | Panasonic Lumix DMC-FZ28 Digital Camera
Where can i get my 6v cordless drill charging stand repaired
Brand?
Feb 08, 2012 | Drills
I have a 95' Jeep Grand Cherokee Limited with a
Are you check your previoud questions: check_engine_error
Keep us updated.
Jun 07, 2011 | 1995 Jeep Grand Cherokee
When i plugged in my laptop for charging,a note appears in the charging icon that says "consider replacing your battery"? is there any remedy regarding the problem of my battery without replacing...
Hi! Well for this one let me ask you first . Is the battery is beyond 1year? If it is then consider replacing your battery is the answer of that. But if not you can call your manufacturer as all the battery has it 1 year limited warranty. Just to let you know all the battery is consumable, sometimes it depends on how you use it .Hope this will help you. God Bless.
Apr 22, 2011 | Acer Aspire One PC Notebook
Have a 15.6v cordless drill - both batteries charge up to ~6v and no more; the red led is on - are both batteries the problem? this is the second charger - drill does not get used very ofter - model of...
Mar 14, 2011 | Craftsman 14.4 volt Cordless Drill/Driver...
I have owned the C-H 19 v. cordless drill for about two years. My strategy for charging the batteries is to have one charging while I keep the other one for intermittant use. That worked fine until...
chordless batteries do have a lifespan. if you constantly charged them over a two year period then yes, they are done. they are kind of like lightbulbs and will eventually wear out. i suggest you change to rigid brand tools from Home Depot. they are the only affordable tools that have lifetime warranty even on the batteries. that is unheard of cause they will eventually get worn out. you will spend more on replacemnet batteries over the course of 4 to 6 years than just buying a new Rigid drill. check em out at the Depot.
Dec 24, 2010 | Campbell Hausfeld 19.2V 2 - Speed Cordless...
Drills Logo
630 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
