Question about Acer V203H 20" LCD Monitor
Have an Acer V203HV - every 2 - 3 minutes the screen goes slightly darker, you then have to press a button for the screen to lighten up again
3 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: X193W LCD Monitor: screen goes black,if i press the on button a few t...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 19, 2010
johnhercus26
  • 104 Answers
SOURCE: it works fine for a
this is an inherent graphics chip failure this laptop runs an nvidia graphics chip onboard if its under warrenty send it back to acer if not there are companys on ebay that will fix the laptop for between £70 and £100 or a new motherboard is around 160
Posted on Nov 24, 2010
Menu for Daewoo DTQ-20U4SC TV.
Microprocessor error. Try unplugging for 10 minutes.
Aug 27, 2016 | Daewoo DTQ-20U4SC 20" TV
How to get the screen to be darker
Turn the calculator on. Press and release the 2nd key. Press and hold the up-arrow key until the screen is dark enough. If you go too far, use the 2nd and down-arrow keys to lighten the screen.
Apr 19, 2012 | Texas Instruments TI-84 Plus Calculator
How do you make the screen darker?
Turn the calculator on. Press and release the 2ND key, then press and hold the up-arrow key until the screen darkens to your taste. If you go too far, use the 2ND and down-arrow keys to lighten the screen.
Feb 15, 2011 | Texas Instruments TI-82 Calculator
How do you align the colors?
Press MENU button and ON-SCREEN MENU will appear. Press
POINT LEFT/RIGHT buttons to move a red frame pointer to
IMAGE ADJUST Menu icon.
Press POINT DOWN button to move a red frame pointer to the
item that you want to adjust. and then press SELECT button.
The level of each item is displayed. Adjust each level by
pressing POINT LEFT/RIGHT button(s).
Move a red frame pointer to
the item to be selected and
IMAGE ADJUST MENU
IMAGE LEVEL ADJUSTMENT
Press POINT LEFT button to decrease contrast, and POINT RIGHT
button to increase contrast. (From 0 to 63.)
Press POINT LEFT button to adjust image darker, and POINT
RIGHT button to adjust brighter. (From 0 to 63.)
Contrast
Brightness
Press either POINT LEFT button or POINT RIGHT button to obtain
better balance of contrast. (From 0 to 15.)
Gamma
To store manually preset image, move a red frame pointer to
Store icon and press SELECT button. Image Level Menu will
appear. Move a red frame pointer to the Image 1 to 4 where you
want to set and then press SELECT button.
Image Level Menu
Move a red frame pointer to any
of Image 1 to 4 where you want
button.
Store icon
Press SELECT button at this icon to
store the adjustment.
IMAGE ADJUST
Menu icon
Press POINT LEFT button to lighten red tone and POINT RIGHT
button to deeper tone. (From 0 to 63.)
White balance (Red)
Press POINT LEFT button to lighten green tone and POINT RIGHT
White balance (Green)
Press POINT LEFT button to lighten blue tone and POINT RIGHT
White
Jan 22, 2011 | Sanyo PLC XU35 Multimedia Projector
It works fine for a short while then the colours on screen go red and then makes a slight crackling noise and screen goes off comes back if you press screen button but then happens again and again
Nov 24, 2010 | Acer Aspire 5630 Notebook
My screen has gone darker , Where is the contruct, light dark controll
It's usually on the up,down,left,right arrow keys that are on the front right hand side of the keyboard.They have blue sun type symbols on them. You press and hold the Fn key, that's on the front left hand side, and then press one of the arrow keys to lighten or darken the screen
Oct 16, 2009 | Acer Aspire 5630 Notebook
I have a bell south phone model# 8823 which has been discontinued and i don't have the instructions anymore i need to know how to make the screen appear clearer so i can read the numbers. All i remember is...
press the menu button, then press the down arrow until it says "set contrast" then push the menu button again and then push the up arrow for darker contrast, the down button for lighter. when finished, push the menu button again
Dec 01, 2008 | Lands Phones
The phone became dead, recharging led does not light up.
On following the steps as stated in my problem text. I kept the phone idle for 2 hours, then I pressed the "ON" button, the screen lighted up and then went "off" again. I again pressed the "ON" button, the screen lightened up and the windows setup completeded in 2-3 minutes. The phone started to work. I think the phone got hanged since the battry went too low. Now it is working OK. I will always keep the battry charged.
I thank you and all your team mates for all the assistance you have extended in solving my problem. I am grateful that your site gives ample knowledge to sort such problems by the user.
Once again thanks a lot,
Regards
John
Sep 06, 2008 | HTC P3300 Smartphone
Screen has gone slightly darker
Sounds like you have changed the power setting in your control pannel
Jun 10, 2008 | Acer Aspire 5500 5570-2609 Laptop
Canon Power shot sd 1000
what u have to do is when u are going to take the picture click on the little lightening bolt next to the func. set button. 2 pictures will pop up- one of a lightening bolt and another with a lightening bolt with a slash through it. hit the lightening bolt button again and it will select the slashed lightening bolt picture. this will turn flash off to turn it back on go back to the screen with the 2 bolts the same way but press the button with the flower to the right of the func. set button.
Nov 18, 2007 | Canon Cameras
Acer V203H 20" LCD Monitor Logo
50 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
