Toshiba MV13P2 13 in. TV/VCR Combo
Problem for Toshiba MV13P2 13 in. TV/VCR Combo
Toshiba MV13P2
By tnewton on Aug 01, 2006
When we try to play a video tape it will play for a few seconds and then shut off. I can get it to rewind and fast forward, but it will not play for more than a few seconds. I got a VHS cleaning tape and ran it, but it did not seem to do any good.
Best Solution
posted on Aug 01, 2006
Helpful)
unclejed
Rank: Master
Rating: 85%, 209 votes
since it fast forwards, and rewinds, my first guess (that the take-up mechanism is worn, which also causes the machine to "eat tapes" after it stops) not likely..... the other common problem is misaligned sensors (especially if you recently had a tape jam in it, or found a foreign object, like a pen, or piece of candy in it...... another possibility is that if it's with a particular tape, you may have visible gaps in the coating on the tape, which would trigger the sensors, basically saying "STOP.... END OF TAPE..."
there are other sensors and sensing conditions that could cause the same problem....... have the mechanism and electronics looked at by an expert.......
Was this helpful?
Yes
No
Solution #2
Not Rated)
techman
Rank: Guru  Toshiba Expert
Rating: 86%, 7668 votes
If a tape only plays for a few seconds and stops, its mostly a problem with the counter or the counter belt if there is one or the sensors under the takeup or suppy reels. Did anybody say the unit was eating tapes?? Did i miss something?? Most likly its not worth fixing unless you can take off the reels and clean off the sensors to see if that helps or see if the counter works in FF and rewind and if it does is it a steady count the counters doing. Or is the counter stopping and going intermittanly? If thats the case, then the sensors are dirty or defective. If they are defective the unit most likly is not worth fixing. Good Luck
Was this helpful?
Yes
No
Popular Solutions for Toshiba MV13P2 13 in. TV/VCR
Questions and Unsolved Problems for Toshiba MV13P2 13 in. TV/VCR
Do you recommend Toshiba MV13P2 13 in. TV/VCR Combo?
Answer
Answer
I have used a univeral remote for years with this tv but i need to find out how to get to the menu... (More)
Answer
the menu continues to pop up on the screen and the remote doesn't work anymore
Answer
I have a toshiba tv/vcr combo and would like to record in ep/slp mode vs sp mode. How do I change... (More)
Answer
mv13pc is model . I have remote- I would like to change vcr recording mode to el/slp so I can record... (More)
Answer
I am trying to connect the digital converter box to my Toshiba MV13P3 13 in TV/VCR model and the... (More)
Describe your TV Combos problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top TV Combo Experts
Top TV Repairmen
in Van Nuys, CA
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
