Question about Sharp 27J-S260 TV
27J-s260 horizontal hold problem
    Top Expert:
  • Sharp Master
  • 74,496 Answers
Hello
Seeing your problem post, it seems that you are a technician. Just measure the horizontal sysnc frequency that horizontal oscillator section receives from flyblack transformer. There will be a resistor in serise with this fulw to the flyback transormer. Check it for open. If it is found to be OK, chek the sync:seperation transistor used any. Replace it. OK.
Posted on Feb 08, 2012
How do i adjust the visual settings such as: brightness, contrast, sharpness on the television with out the remote?
try to press volume & program buttons at same time. hold it a few seconds, release after the menu setting will appear on screen.
Jul 09, 2014 | Sharp 27J-S260 TV
Sanyo sc-s260 user manual
I want to clean my vacum cleaner, How i can open my sanyo vacum cleaner model: sc-s260
Dec 26, 2013 | Metropolitan Vacuum Cleaner Vacuums
The keyboard of my MSI S260 PC NOTEBOOK is not functioning even if the touch pad..how will i repair it?
I have also MSI s270 laptop and its the successor of your laptop with the same parts, i open my laptop many time already changing its memory and cleaning its parts:
heres you need to do:
1. unscrew your latop at the bottom.
2. Remove the battery.
3. remove the plastic covering, the one where the power button is attached.
4. after removing it, you can now unscrew and remove the keyboard, try to clean its carbon head with an eraser.
5. remove also the plastic where the touchpad is attached. clean also its carbon head.
6. return it all back.
Alternatives:
Use external keyboard and mouse (USB).
Mar 30, 2011 | MSI S260 (S260100) PC Notebook
Help my viao keyboard and case is broken ....can i get new body for my sony viao vgn-s260
To fix this problem please follow the links below
http://alturl.com/zvnbe
http://findtechhelp12.blogspot.com/
Thank you
Mar 26, 2011 | Sony Notebook Computers: VAIO VGN-S260...
Value resistor 719 of chasis serial : qpwbf9254mezz,tv sharp 27" model: 27j-s100 or diagram. thank you for his help
I looked at the same chassis I have and the resistor has color bands green blue silver gold wich is a .56 ohm 5% 1/2 watt resistor
Dec 03, 2010 | Sharp 27J-S100 TV
My jamo s260 will not power up
hello make sure you put the same rated fuse back in beware if blows again then you've got a dead short somewhere
regards
shaun
Feb 28, 2010 | Audio Players & Recorders
How do I access the menu without a remote?
You don't. A good "universal remote" available from Radio Shack (Phillips) for about $15 will provide access to all TV adjustments. Easy to program for all TV models, VCR's, DVD players, etc. About $35 + S&H for the Sharp remote replacement.
Nov 14, 2009 | Sharp 27J-S100 TV
Television wont turn on
Goog day sir, We need to replace first the bad switch, need to unsolder it, find the replacement one and solder it back. You may need to open the back, remove the main board, and replace the bad switch. reassemble the tv and test. Sad to say this but you may do the repairs or hire a person to do it. check you remote batteries they may be almost dead. hope this helps let now your progress.
Aug 10, 2009 | Sharp 27J-S260 TV
Picture converges to the center -- "funnel" like
1) Solder any / all bad connections
2)troubleshoot,locate and replace any bad parts in pincushion
circuit....start with pin amp output.......
3)No problem found ?.........could be bad yoke.................T.
Dec 21, 2007 | Sharp 27J-S100 TV
Adding Audio Output to TV
headphone jack is perfect. Buy ( radio shack, ebay,home depot,best buy ) the mini plug to rca breakout cable and once you plug it in it should mute speakers. Otherwise go into menu, audio, and usually there is a selection to cut off speakers
Dec 03, 2017 | Sharp 27J-S260 TV
Televison & Video Logo
48 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
