Question about AOpen s661FXm-US SIS 661FX CHIPSET SERIAL ATA150 MICRO ATX FORM FACTOR 1xAGP(8X)/3xPCI/2xDDR W/INTE... Motherboard
No display on boot
Hi; I have an Aopen s661gxmu motherboard , it wont booting no display
- I tested the CPU in another montherboard it work properply
- i tested the memory it work properly too.
I dont know where to plug the internal speaker to hear the beep.
  • clandestino Dec 01, 2008
    have an Aopen s661gxmu motherboard running windows xp SP3, i increase the memory up to 2x512MB PC400MHZ when i try to boot it wont booting no display
  • 781 Answers
Try another video card
Posted on Oct 23, 2008
Motherboard not boot. i change ram cpu p/s but not boot
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this will help don
Mar 14, 2011 | AOpen MX4GER Motherboard
AOpen AX45F-4DN Motherboard On Boot, System does not detect any IDE devices. halts at 'Detecting IDE Devices' Cannot go into SETUP
Some connections inside the computer is loose.
It is probably the hard disks or CD drives. Just open CPU, disconnect those devices and then reconnect.
Aug 12, 2010 | AOpen AX45F-4DN (91.8A410.201) Motherboard
There is no video, just a series of long beeps.
HIiiiii
Check Following
  • RAM / Re insert /Change Slot /CHANGE RAM
  • Any new Hardware Installed
  • Reset BIOS
  • Change the Cables
  • Remove the CD ROM CABLE/Cables
  • REMOVE FLOPPY or CD or any other Cables as New Hardware than HARD DISK Connection
Then try to boot
Problem Checked....... Solved.........!!!!
I am here
Mar 28, 2010 | AOpen S651M (918EM10S50) Motherboard
CPU upgrade problem
Hi there
what are your pc specs , like ram ect. So we can find out what is wrong. please check your cpu settings and reset the pc bios to see if that hasnt solved the problem
thanks
roger
Nov 12, 2008 | AOpen AK77-8XN Motherboard
Home built 4 yr old pc wont boot
You have voice message telling you CPU test failed , but does it BEEP at all ? if you have a Beep code then replace the CPU fan ( when CPU gets too hot it will either shut down or the PC will not boot up at all )
Jul 23, 2008 | Intel Motherboard
Help pc problems???
CHANGE THE POWER SUPPLAY.. BUT FIRTH..
1-UNPLUG HD AND TEST WITH FLOPPY OR CD BOOT DISK
2-UNPLUG YOUR MEDIA ROOM LIKE CD OR DVD AND TEST ONLY WITH FLOPPY BOOT DISK
3-UNPLUG VIDEO CARD AND ALL CARD ON YOUR MOTHERBOARD.. TEST ONLY WITH THE FLOPPY DISK AND ONBOARD VGA.. OR GOOD TESTED VGA CARD.
EXCUSE MY BAD ENGLISH.
CO3OV
CUBA
VICTORES45@YAHOO.ES
Oct 14, 2007 | AOpen AX45-V (91.88I10.004) Motherboard
Motherboard problem
if you have tried resetting the bios by putting the jumper across pins 2-3, then back to pins 1-2 and it still wont boot into the bios and you know the memory is ok, then the bios chip on the motherboard is damaged and may not be easy to replace as the board is quite old.
Aug 11, 2007 | AOpen AX45-V (91.88I10.004) Motherboard
Printer Problem
two possibilities, if you are in possession of the motherboard drivers you will need to install them as windows xp will be using generic ones and may not be suitable for your board, also try installing in a different usb port. The other is that the drivers you are using will probably be win 2000 and in your case it wont work with XP, so go to your printer manufacturer web site and download and install XP drivers.
May 24, 2007 | AOpen AX34-U Motherboard
Computers & Internet Logo
105 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
