Question about Hisense Televison & Video
Hisense tv menu options blocked
Several functions in the menu - including screen positioning, tint and blue screen - appear but are inaccessible and can not be adjusted
  • Fred Bloggs Feb 07, 2012
    I discovered this problem in attempting to get rid of the white lines that appear at the top and bottom of the picture in letterbox format blu-rays.
    Top Expert:
  • Hisense Master
  • 74,243 Answers
Hello
What is the exact model number to your Hisense TV? You can get it from the back cover of your TV. Get it to me. OK.
Posted on Feb 07, 2012
    The model number is: HL40K26PZL
  • mishka Jul 02, 2012
    Any solutions??
    New Friend:
  • 16 Answers
Go into setup then function then enable startup menu switch set off (completely off with poer switch turn back on then select normal mode not demo or hotel at startup.
Posted on Apr 21, 2013
When i press the home button on my hisense smart tv it just appears with a blue screen and loading symbol in the centre then loading symbol goes away and screen just stays blue
hmmm seems like the software on your smart tv is partly corrupt and may need downloading/updating from the hisense website make sure the firmware matches your tv model otherwise you may brick the software on your smart tv please note you will need a USB jump drive to do this as well
Feb 24, 2017 | Hisense Televison & Video
I have a hisense Tv and am trying to watch a movie which has been downloaded on to usb but my tv screen is saying can not switch no usb is inserted yet it is inserted in to tv with a blue light on??
Most of the USB have to be formatted for the TV first before you use it. Look in the instructions for how to do that. It is done while plugged into the TV and toggling through the menu options.
Jun 23, 2016 | Hisense Televison & Video
The screen is green and the tint option in the menu cannot be adjusted.
This symptom usually indicates CRT failure. Projection TV's, especially older types use 3 CRT "guns" to project the image on the screen. One is Cyan or Red, one is Green and one is Blue. If the Red and Blue become weak or do not project, the Green gun overpowers the output of the other two. These three "guns" are aligned exactly on top of each other so when all three are correctly functioning, the correct colors are projected on the screen.
Oct 04, 2015 | Televison & Video
My Hisense tv switches on and name of tv appear on screen but 3 seconds later it stitches off. Screen just dissapears but blue light still on so tv on but no screen. Can not even get menu to come up on...
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Mar 13, 2015 | Hisense Televison & Video
I own a Quasar SP-3235 32" TV. It has a slight green tint after 10 years of use. How can I adjust the color screens on this set? Is it a function of the remote like Sony TVs or do I need to remove
I would open it first and look, a lot of those had both the screen and drive controls on the PCB at the end of the picture tube, at least look there first.
You are dead on in looking for the screen controls, if you find one it should only be a tiny adjustment due to age and the Crt changing a bit.
Dec 13, 2012 | Quasar SP-3235 32" TV
Lg flatron w1943tb color fades in and out to a blue green
Follow the following solutions, this should fix up your trouble
1. Turn yourmonitor on. It should be on for at least 20 minutes before you continue.
2.Press the"Auto/Select" button on the front of your computer's monitor. Thescreen will be wavy while the adjustment happens. When the screen stops beingwavy, the faded colors should no longer be visible.
Follow steps 1 and 2 if you do not have a disk for the monitor.
Nov 24, 2011 | LG Computers & Internet
"OSD LOCKED" box on my screen
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
OSD stands for "On Screen Display." It is an onscreen configuration menu included with various monitors. When you press the MENU button or one of the other buttons on the front or side of a monitor, the onscreen display may appear. The OSD typically includes monitor calibration options, such as brightness, contrast, and color adjustments. Some OSDs may also include horizontal and vertical position controls as well as tilt and keystone adjustments.
If you can't make adjustments to the monitor settings using the OSD interface, the onscreen display may be locked. You may also see the phrase "OSD Locked" appear when you try to change the settings. Some monitors include an option within the menu called "OSD Lock", which you can turn on or off. If this option is available, simply turn OSD Lock off and you will be able to make adjustments to the settings.
If your monitor does not include the "OSD Lock" option, you may be able to unlock the OSD by pressing and holding the MENU button on the front or side of the monitor for several seconds. If you try this method, be patient! It may take up to 15 seconds for the OSD to unlock.
VOTE ME
Dec 07, 2010 | Dell Computers & Internet
Remote control not working with tv
The remote control is an acess to the TV device for example only from a distance. A remote controll for functionality would require to insert batteries a power source making possible communiction with devices requiring reception transmittion of signals. The remote is handheld pointed to the direction of TV requiring signal before button pressed woudl achieve response. a common button to start the remote control experience is pressing on the power button, that displays a signal on the TV. The TV should momentarily produce a sound and lighting effect,, and displaying on the dark screen a light blue screen. The initial signal response from remote control to TV indicates devices are functioning as required. Additional buttons on the remote controll could perform functions of several available.
The remote control has master button, menu on which every additional function is deriveable. Once the menu button is pressed with remote pointed in the direction of TV, should dicplay a list of options on the blue screen already established by power button. Every additional remote control device functionality is achievable by only after the first two buttons have been powered and pressed to display option results on a screen of TV. The remote controll buttons remaining perform complementary functionalities. For example, the arrow keys on remote control make movement of the options displayed on the screen, where a comfrimation button or identified as select allows to confirm remote functions displayed on the screen. A remote control could have several functionalities only accessible once made to display in screen. The three most common buttons on a remote control are First power button that powers on the TV, menu button that displays a list of functionalities on the powered on bl;ank blue screen, and using the arrow buttons on the remote would moves an indicator arround the screen area options. The selection button makes confrimation of the option.
Dec 02, 2010 | Philips Televison & Video
My tv is block and i dont know wat to do. how can i unblock it?
Don't use the remote control the signal it block.Go to ur manual contol on the tv right side.Push the power button to turn tv on.Push button Menu now U in the tv Menu,Use the volume + or - button move the Menu function to OPTION,now use the Channel + or - go down to the word said Operation lock out(ON) Now push manual contol button said INPUT.Now the word said Operation lock out(OFF).Now remote control is relase,u can use the remote control now.Tell me this work ok.This is how i unlock the Sharp Aquos tv.
May 09, 2010 | Hisense TL1700 17 in. LCD Television
Picture and menus are red-tinted all over
check system mode on dvd player,should be on pal
Jul 12, 2009 | Televison & Video
Televison & Video Logo
880 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Electro Med Services...
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
