Question about Westinghouse SK-32H240S Television
When I turn on my tv the closed captioning automatically turns on and I can't turn it off
I have tried going into menu to turn off closed caption but it says that it is off but it is not and continues on every channel that will allow it
  • Pamela Clark Feb 07, 2012
    I tried pressing "cc" on the remote and that doesn't work either. It just shows up on the screen with 3 options: off, on, and off when muted but when I press off it does nothing.
    Top Expert:
  • Westinghouse Master
  • 74,383 Answers
Hello
After switch ON the TV, and after picture has displayed on the screen with 'closed Caption" window, just press button "CC" on your remote control. For each press, the close caption window will vanish and disappear. OK.
Posted on Feb 07, 2012
  • The Knight
    The Knight Feb 07, 2012
    Hello
    To OFF the close caption option, there is no other procedings stated in its manual Press CC to close the close caption option; as it sys.
2 Suggested Answers
Agent Jason
  • 78 Answers
SOURCE: close captioning
Hi ckay31,
If your remote is not allowing you to navigate through the menus, you may need to replace the batteries.
If this does not work, in the meantime you should be able to navigate the menus using the menu button on the TV. The Closed Captioning option should display under Channel Settings.
If you are still unable to get your remote to function properly, I recommend you contact Westinghouse Customer Service at (866) 287-5555. You may also view your product's manual at http://www.westinghousedigital.com/pdf/15_User_Manual.pdf
Thank you,
Jason,
Go Ahead. Use Us.
Posted on Jun 16, 2008
CLosed Captions won't go off. Setting says they are off.
Go back and just "look" to see if the captions are still turned off.
if it is still on CC1 or CC2, the captions are still on.
If they are, you must turn captions off and then follow on screen prompts to make sure they are indeed off.
(Did someone turn on the captions on your cable box or other receiver?)
(If they did, this may be the reason that you can/t turn them off on the TV !)
Apr 02, 2013 | Televison & Video
CLOSE CAPTIONING WON'T TURN OFF
Go back into the menu of the TV and go through the choices. One of them is to turn on/off closed captions!
Jan 02, 2013 | RCA Televison & Video
Philips 24PT6341 closed captioning won't turn off and there is no option in menu
There must be a button marked "CC" on your TVs remote control. Press it once. It will make the closed caption windwow off.
Jun 21, 2012 | Philips 27PT6441 27" TV
Can't turn closed caption off on our Samsung Series 7000 LED TV
Make sure it isn't your cable or satellite TV service making the captions, as closed captions on your TV are separate from the ones produced by your service provider. If it isn't your cable/ satellite, open the TV menu and find the Audio/Visual properties section of the menu (audio and visual might be separate sections), and find the closed captions or CC options menu. When you do just change the setting from whatever it is on, to off. If your TV remote is fancier than mine (which it probably is), their could possibly be a closed caption button on the remote for easy access. In this case just push the button and change what you need to.
Jun 07, 2012 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Can't turn on memorex MT2012 Closed Captioning using a universal remote
You must have its original remote control, which will have 'CC; button on it. you have to press this button once to cancel the Closed Caption option. If you can acccess the Menu of the tV by your present universal remote contro,; get into TVs Menu option, surf through, come to closed capation adjust window, and cancell [OFF] the closed caption option.
Apr 08, 2012 | Televison & Video
We have a Sharp 25J-M100 and we cannot turn off the Closed Caption. We hit menu on our Sharp Remote Control and go down to Closed Caption and make sure it is off. The words never go off of the screen. Our...
If the captions are turned off on your TV, they have to be coming from your cable box. The TV is just displaying what it's getting. Check your cable box menu and make sure captions are turned off there. Cable boxes, especially on digital systems, can prevent the TV's caption decoder from operating properly. So they need to be able to provide captioning, and I suspect you've turned it on somehow. Comcast should be able to tell you how to turn off captions if you can't figure out the menus.
Jul 15, 2011 | Televison & Video
I have no remote, how do I get off close caption on a TS2554C101
There is a Menu button on the TV for the TS2554 C101. Press this button to get the OSD menu. Then press the vol +/- buttons to highlight Set. Use the Ch +/- buttons to get Closed Caption. Then press Vol+ or Vol - to get the closed caption menu. Use the Ch+/- buttons to set the desired closed caption setting and then press Vol + or Vol - to confirm the selection. Press Menu again to exit.
This will only help if the captions are being interpreted by the TV. If there are open captions, they will not go away. If the closed captioning is on at a set top box, you will need to turn them off using the controls for the set top box. (I know satellite receivers have independent captions available.)
I hope this helps. If your TV doesn't have a menu button on the set, you will need a remote that has a matching Menu function. Some universal remotes should have this feature.
Apr 28, 2011 | Philips TS2554C 25" TV
Unable to remove the closed caption through the remote control (Haier) 42 inch flat screen tv. Went through the function and selected 'No' to Closed Caption, but it does not remove it. Thanks, Sandy
I dont know what model you have i see two on there website. i read manual for one of the 42 inch lcd tvs and i do see where you confirmed you said off to closed caption mode am i correct? Ok try this turn the closed caption on and exit menu. now shut off tv and turn it back on. now go into menu and turn closed caption mode to off now and exit menu and see if that helps. ok i hope this helps ....oh i forgot to mention make sure that you didnt enable the closed captioning on your cable box remote. Just might want to check with that. It might not be your tv at all it could be the cable boxes closed captioning service. I hope some of this helps if not see if there is a factory reset in the menu.
Feb 20, 2009 | Haier Televison & Video
Closed caption activiting on everytime tv is turned on
If you have the Suddenlink remote and the DVR box you can turn captions on or off by accessing a technical menu. To do this, press POWER and Menu buttons together (menu 2 times) to bring up a special menu. Select Closed Captions. On the popup menu select closed captions and using Select button change to OFF or ON as you wish. The trick is to get the menu to come up. Timing of pressing the two buttons is frustrating and it may take a few times befotre you get the special menu.
Oct 02, 2007 | Televison & Video
Closed Captioned
Assuming whatever your TV receiving from has close caption. (Not all TV channel has close caption) Solution 1) Get a new universal remote that support your model and has close caption button. Once you program in the code for your TV model and it works then all button should also programmed including th close caption button. Solution 2) Search online for the owner manual and read see how to turn it on using buttons on TV (if possible). Solution 3) Get new TV with close caption. (If you have an old old TV with bad and huge pixels then this solution is the best. Your eyes will thank you.)
Aug 25, 2006 | Panasonic CT-32G11 32" TV
Televison & Video Logo
601 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
