Question about Lands Phones
The basic problems of wireless Tlfnh uniden ELBT595.
When AC power is connected to my cordless phone base to base, but it gives error 4 wireless handheld is completely healthy.?
4 Suggested Answers
SOURCE: Cordless phones will not connect to base.
I just had the same problem and tried several things with no results. Then, I figured I had tried everything else so I just unplugged the battery pack, set the phone down for 25 minutes and then plugged the pack back in. Phone worked again after that.
Posted on Nov 14, 2006
SOURCE: cordless phone does not connect
You may need to reset the Telephone Answering System. Complete the following steps to reset the Telephone Answering System:
Step 1: Disconnect the power to the telephone base.
Step 2: Wait a few minutes and then reconnect the power to the telephone base and charger.
Step 3: Set the day and time.
Posted on Apr 03, 2008
SOURCE: UNIDEN Powermax5.8 cordless phone charging
waaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
Posted on Jul 30, 2008
What does it mean when it says searching on my cordless phone
This usually indicates that the handset is having a problem establishing a wireless connection with the base unit.
Try placing the affected handset in the base charging cradle for a few seconds to let them sync to each other. Remove the handset and try again. If you are able to use the phone again, but only within a few feet of the base, there is probably an issue with the radio or antenna in the handset (assuming all other handset works fine). If all associated wireless handsets have the same scanning message and only work close to the base, then the problem is likely with the radio or antenna in the base, instead. You may be able to see a loose or broken connection if you wish to dig around - but if there's nothing obvious - you're probably better off leaving it alone and obtaining a replacement instead. Before beginning - be sure to unplug the AC power and telephone wire from the base and the remove the battery from the handsets.
Without a specific model number for your phone, only a generic solution can be provided. There may or may not be additional suggestions to help you solve the problem if you provide the Uniden model number.
Jan 09, 2012 | Uniden Cordless Phone
My tru9480 handset is saying connecting but won't connect and won't get a dialtone
Reset Procedure for Cordless Phones
1. Disconnect Battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect Battery to hanset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base in most instances.
Jun 13, 2009 | Uniden TRU9480 Cordless Telephone
Uniden base display does not work after chargin for 1st time.
Question:
What is the general reset procedure for cordless phones?
Answer:
May 05, 2009 | Uniden DECT 6.0 Cordless Phone ID
After charging a Uniden 2180-2 DECT 6.0, the base stope showing anything on its display. As for the other handset, their display report " searching" since they can' t connect to the base. What is goin
Question:
Answer:
May 05, 2009 | Lands Phones
No dial tone. No calls. Can't call out.
E4 IS AN ERROR MESSAGE, THE BASE IS NO LONGER GOING TO WORK, POSSIBLY A POWER OUTAGE COULD OF DAMAGED THE BASE.
Dec 28, 2008 | Uniden Cordless Phone
Uniden cordless phones
Okay, this solved it for me, so maybe it'll help others.
Basically, you just need to re-register the phones by placing each one on the base unit and leaving it there for at least five seconds after the charge/in use LED light stops flashing.
According to the manual, it's necessary to re-register each phone after a power failure or if the batteries get very low or die. If you're experiencing the "connecting..." problem, this will probably fix it!
Mar 21, 2008 | Uniden Cordless Phone
ELBT595 Handset Not Turning On
Check the handset battery -- if there is a slight "bulge" on one side (ie: not COMPLETELY flat) then the problem is with the battery. I had that problem and had to order a new one. That said, I just installed the new battery, and while it now charges, the handset won't connect to the base unit. The base unit works (tried the speakerphone), but there is not connection between base and handset.
Feb 18, 2008 | Uniden ELBT595 Cordless Phone
ELBT595 & TCX905 compatibility
from uniden regarding your base station:
"This expandable base system is compatible with Uniden handset models ELX500, TCX400, TCX440, and TCX805. However, only the ELX500 is compatible the base system's Bluetooth and CellLink features."
Feb 09, 2008 | Uniden TCX905 Cordless Expansion Handset
No electrical outlet available for the base station (wall mounted)
most cordless phones need some access to 120 volt power to recharge the internal NiCad batteries. It wouldn't be cost effective to have on hand a bunch of charged batteries that you'd replace on a daily basis. they got to be charged up eventually.
Aug 23, 2007 | Uniden CEZAI998 Phone
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
