Indesit idc75 wiring diagram - Washing Machines
2 Suggested Answers
tjdcet
  • 3 Answers
SOURCE: indesit w161 wiring diagram
Here is your Indesit W161 wiring diagram, Please answer the easy survey then the link will be unlocked (the survey is for my efforts looking for your request)
http://bee4.biz/v/k6K7X
Posted on Feb 09, 2012
Indesit IDC75 dryer need to know all the order in wiring on front panel timer,start,etcetera
The spade terminal wiring sequence for the timer is: White/Black to B5 // Pink/Black to A2 // Gray to A3 // Single Blue to B1 // Double Blue to B2 // Single Red to C5 // Single Black to C4.
Oct 18, 2014 | Dryers
Why when my door is open on my indesit idc75
The door switch is probably stuck in the "door closed" position. I presume the light inside also does not turn on.
Oct 05, 2014 | Dryers
Indesit idc75
2or3 screws at the back take out and push the top should come off easily
Apr 07, 2014 | Dryers
Indesit idc75
sounds like its a drum glide worn out
Jan 04, 2014 | Dryers
Indesit IDC75 belt change
Your tumble dryer is a little different than I am accustomed to, but there are millions of dryers in the U.S. with the same sort of system. Try this. I think ( I hope) the belt goes as follows:
The small black(?) pulley should be spring loaded, so that you can either push or pull it toward you or away from you. I think the belt goes around the motor shaft first, then goes back around the black pulley, then to the drum up above. When you are done, the belt should be upside down S shaped, with the motor shaft in the bottom of the S and the black pulley in the top of the S. I cannot type an upside down S on this keypad. When you pull or push the loose pulley, it should allow the belt to slip by on one side or the other to go around the back of it.
Be blessed.
Apr 27, 2013 | Dryers
Indesit w161 wiring diagram
Feb 09, 2012 | Washing Machines
What's your problem? instruction manual model idc75
I dont need a manual to operate it as i have a er indoors that knows it all about anything and everything till something goes wrong then i am expected to fix it
Dec 02, 2011 | Indesit Dryers
I have just bought an Indesit tumble dryer model no IDC75, the dryer is working ie the drum is moving but there is no heat being generated from the machine
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 10, 2010 | Indesit Dryers
Washing Machines Logo
155 people viewed this question
Top Washing Machines Experts
