Question about JVC PD-42WV74 42 in. Plasma EDTV
JVC PD-35D30ES Vertical lines - problem
Vertical regularly spaced lines which persistently cover the screen. Only on occasions do they disappear, for minutes or so before reappearing. What is the problem?
    Top Expert:
  • JVC Master
  • 75,417 Answers
Hello
Check its power supply board for any damaged capacitors. Replace them if found or suspected. Take special care to main filter capacitors. check all the output voltage smoothing capaciotrs too.
If all are OK, and still the problem perists, replace the power supply board as card basis.
Posted on Feb 08, 2012
3 Suggested Answers
  • 1153 Answers
SOURCE: Vertical portion pixelats then forms
Note
In some cases, there are minor defects in some parts of the screen. Points that do not light, points with
brightness different from that of the periphery, or points with color different from that of the periphery.
Some pixels will always be on or always off. Please note that this is not a malfunction. So what this says is that it's not the Plasma Cell problem, its more like a bad board inside. You will need more info like schematic and find out which area the bad part is in.
Posted on Jan 04, 2008
SOURCE: I have several blue vertical lines appearing on my
The problem is that there is a bad connection/bad soldering in one/several connectors where the flatcables to the displayunit is connected to the rest of the electronics.
A tip is to mark exactly where the lines appear (with paper scotchtape) on the side of the unit, so you can se which connector/-s that you should resolder once you have dismantled the TV.
Posted on Oct 17, 2010
Thin vertical line on LCD tv
Change input device to some other like a DVD player.
Switch off TV, switch off power, remove plug and wait for 48 hours and retry. If problem persists, call in a qualified service technician.
Aug 02, 2012 | iLO V27DMBX Television
I have evenly spaced, rows of two vertical green and red lines from top to bottom of my vizio plasma P50HDTV10A
Somehow when switching between the tv and the dvd my wife encountered the pink and green, thin, parallel, vertical lines on the screen. The picture was visible with the lines. I turned the tv off and on but the problem persisted. Unplugged tv for about two minutes and after plugging it back in and turning it on the vertical lines very gone and the picture was back to normal.
Jan 12, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
I have several blue vertical lines appearing on my screen when turning my tv (JVC PD42V31S) on. After a couple of minutes (probably when its warm) and moving the scart cable in the back the blue lines...
Jun 18, 2010 | JVC PD-42V31 42 in. Plasma Television
I HAVE A JVC AV27D302: THE PICTURE IS FOLDED OVER
For how many years this TV with you? Most tv now a days after few years of using vertical IC solder started to dry(dry solder) you can try to re-solder or you may check also two capacitors (100uF/35V) for most JVC model has this symptom with this parts changes its electrical characteristics. If still problem persist replace vertical IC. Hope his helps, Good Luck
Feb 14, 2010 | JVC AV27F476 27" TV
Vertical portion pixelats then forms solid vertical lines. Problem intermitent but persistant. The tv is 2 years old, if its the lcd panel is it worth repairing? I think I have the same problem with a...
Note
Jan 04, 2008 | JVC PD-42WX84 42 in. HD-Ready Plasma...
Toshiba 46In HD Rear projection TV Vertical lines on screen
We also have vertical lines with our JVC 62"... turning it off and letting it cool down is the only solution. For us, we know it's a problem with heat. We simply are wits end on fixing it. added two additional fans, a exterior fan to blow heat away from the back of the tv, pulled everything else away, etc.... Anyway, goodluck.
Dec 24, 2007 | Toshiba 46H83 46" Rear Projection...
Vertical muliticolor lines
The output freq of the vcr is sitting to close to an rf signal from a digi broadcast i guess,cross modulaion is the term.the rf can be moved away in freq to another bit of band width or if not using rf connection it can be switched off rf output altogether.find online vcr manual and find rf change section
Jan 07, 2018 | JVC PD-42V31 42 in. Plasma Television
JVC PD-42WV74 42 in. Plasma EDTV Logo
326 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
