Toshiba mk2025gas 80gb - travelstar ibm usb 2.0 case - hdd wont spion unless partially disconnect connection to hdd first, then push back in
Hi, I have a toshiba 80gb HDD in an external usb powered enclosure (ibm travelstar). If I cannot it to my PC, the HDD wont spin and the drive is not recognised. However, if I take off the cover of the enclosure and slightly pull the connect out the back of the HDD (not fully) it will then power up. I can then push the connect fully back into the HDD and use. Does anyone know why this is happening and how to do it so I don't have to keep slightly pulling out the connection out the back of the HDD for it to spin?
  • 1027 Answers
I would suggest running linux based GParted live cd. Under linux you can alter the sizes of partitions and configure the partitions and format in NTFS/Fat32/
If you want to try
click on the Download the latest version
From Tuxfamily : http,
Posted on Mar 24, 2008
  • 95 Answers
SOURCE: Is my LaCie External USB 2.0 500GB fried/dead???
Does it make any clicking/clunking sounds like any of these?
If yes - it's really bad and there's nothing you could by yourself..
If it sounds normal or doesn't spin up at all then try to remove it from enclosure and connect directly to a PC.
Posted on Nov 08, 2008
  • 8 Answers
SOURCE: "no boot sector on internal hard drive"
i think you need to re-install your Operating System again since you got a new HDD wich is tottaly empty i assume so try to install your OS on the new HDD
let me know if it helped
Posted on Jan 02, 2009
  • 61 Answers
SOURCE: I was given an IBM laptop t41 without a hard drive.
Check out the link below. It shows how to change the hard drive and shows to max size hdd is 160gb.
Hope this helps.
Posted on Mar 18, 2009
  • 18 Answers
SOURCE: IBM r52 thinkpad laptop hdd compatibility issue
Download Hiren CD .. format the hDD and install the OS Freashly
Posted on Mar 31, 2009
I need a new a new cable (fits an unusual 5-pin socket) for an ibm travelstar external hard drive
the dearlership should know what you need. the reason the socket is so different is to let you know, the stuff in which contained in this part is very sensitive and could major problems if you are not sure what your doing
Apr 13, 2012 | IBM TravelStar 40GN 20 GB Hard Drive
I have travelstar IBM harddrive i want to coonect to laptop through IDE to USB addapter
Buy the external hard drive case to market, IDE cable put the hard drive IDE slot and put the power and close the case, now connect your USB cable connect your laptop and hard drive...
Good Luck
May 20, 2011 | Computers & Internet
The Toshiba MK8037GK HDD2D61 80GB is put in the usb 2.0 CASE but not recognized in P4 system based on 845 mother board. tell me what to do? OS is Win Xp pack 2.
Verify the cables are securely connected to the drive. If the USB cable that came with a Y-Cable, connect both to USB ports found on the back of your computer. This will ensure your drive is getting the appropriate power.
Dec 07, 2010 | Toshiba 80GB MK8037GSX 2.5" SATA II SATA...
I had all my data informations in this HDD but I cannot open it now. It always shows when it access a mass storage drive in USB but I cannot access it.
Hello and thank you for using Fixya's services.
You can take the actual hard drive out of the casing and slave it to a working desktop. You can then retrieve your information and use the computer to reformat the HDD. After this put the HDD back in the casing and try to attach to computer. If it doesn't read, then more than likely the USB connection or casing is messed up. You can always keep it slaved to desktop and continue to use, except now it will be internal and not removeable.
Hope this helps!
Nov 20, 2009 | IBM TravelStar 40GN 20 GB Hard Drive
I wont to use my old ibm travelstar 30gb like secondary hdd with usb extern case .please help
You won't? Or you will want to?
You should be able to buy an adaptor or case for it. CompUSA here locally has those kinds of things in Fort Lauderdale. I think owns them now, or you could go on
I'm using a Vantec which does SATA and IDE and handles 2.5", 3.5", and 5.25" drives and converts them to USB.
Nov 03, 2009 | Black Box Multiple Twinax Repeater III
Connect external hard disk IBM travel star 80GB USB port 2
Unless it's windows 98 you don't need a driver. If your computer can't see it, it's probably broken. Try plugging it in to another computer and see if it can see it
Oct 01, 2009 | IBM TravelStar 40GN 40 GB Hard Drive
External Harddrive doesnt show up in harddrive management.
it sounds like a hardrive issue. You can have the data retrieved from your hard drive by using this online company that I highly recommend:
Aug 24, 2009 | IBM TravelStar 48GH 48 GB Hard Drive
Getting files off an old IBM TravelStar 20 GB Hard Drive
You can buy an adaptor that will connect your hard drive to a pc.
Ribbon cable from your secondary drive on pc goes into the adapator. Adaptor also coonects to laptop harddrive.
You also need to change from being a master driveto be a slave drive . see linkbelow.
You can then copy file to pc a usb memory stick.
Oct 13, 2008 | IBM TravelStar 40GN 40 GB Hard Drive
Dell laptop with no cdrom and travelstar HDD
In this case you would have to...
1) preformat the drive
2) make it bootable in DOS
3) copy the CD contents to the drive
4) boot the target computer with the drive and run WINNT.EXE in the I386 directory to start the install.
2) copy the CD contents to the drive.
3) put the drive in the target computer and boot it from a DOS bootable floppy.
4) run WINNT.EXE in the I386 directory to start the install.
Jun 26, 2008 | IBM TravelStar 40GN 20 GB Hard Drive
Cannot Open when connected
I connect harddrive IBM Travelstar 20 GB Model IC25N020ATCS04-0 (made in Thailand) to PC via USB port but cannot open ,LED is light .How can I do , I have no driver.Pls. help me.
Jun 01, 2008 | IBM TravelStar 40GN 20 GB Hard Drive
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
