Power is turned on, tape is inserted, tape won't play
2 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: Tape Transport issue
FF and Rewind are functions of the reels, not the capstans. If the reels fail to rotate in response to capstan-driven tape motion the unit will assume a broken tape or end of tape. I think you have a mechanical reel drive system failure. Take it to a shop for evaluation and correction.
Posted on Mar 19, 2010
Testimonial: "This makes sense to me...thanks for taking the time to answer this."
Wii power light is flashing red
Wii red light going batty flashing like every 1/3rd of a second, and it will not turn on. I FIXED MINE BY UNPLUGGING EVERYTHNIG CARDS, CABLES, FROM EVERYWHERE, AND REMOVE SDCARDS ALSO, AND DISCS, BOTH GC & WII CARDS, SENSOR BAR PLUG, POWER Plug *ALL THAT'S PLUGGED OR INSERTED... Now i plugged everything back in ACCEPT Not Sensor PLUG To back of wii, then the light quit (This is after 4 min break all undone...) And then plugged the Sensor plug and THEN as i finally plugged in the POWER Plug I first held the SYNC red button on the Wii, and then plugged it in and WAH-LAH Isue Resolved Immediately, KUDOS for the hints Cheerz & Peace Love Banish Fear/ hate to not even give it thought in root thoughtfulness.!. www.fb.com/stanleydeanparker/
Dec 29, 2012 | Nintendo Wii Console
Vhs is stuck in machine. Won't play and won't eject.
There are any number of reasons why it won't play. The loading basket is jammed, the video tape has got tangled up in the mechanical section of the vcr or the loading gears are stripped. Unplug machine and remove top, [screws side and back] if the tape is spewed carefully remove by cutting it and clean tape particles, for any other problem have a technician check it out.
Jun 28, 2012 | Sony RDR-VX530 DVD Recorder/VCR
Canon zr700 won't play tape
That is the pinch roller. If it does not press the tape against the capstan, then the tape will not pass the read/write heads. Replace it.
Jun 25, 2017 | Canon ZR700 Mini DV Digital Camcorder
VHS Tape won't stay in compartment
Going to have to look inside but expect to find that tape is not going all the way into position and having the tape pulled out and up against the drum with the video heads.
If it does not fully load a transport problem exists--drive idler and or belts.
Faintly possible also is something that does not belong inside got in past the door and is jamming it up.
Apr 24, 2012 | Panasonic DMR-EZ485VK DVD Recorder/VCR
Power goes off when a cassette is inserted. Tried cleaning heads but it won't even run that. When power is turned back on the cassette is immediately ejected.
Good day!!!
Most common problems
  • VCR refuses to FF or REW and shuts off.
  • VCR shuts off entering PLAY or REC or at random during PLAY or REC.
  • VCR eats tapes.
  • VCR doesn't accept tapes or ejects them without cause.
  • Sound is wavery, fluctuating, or muddy.
The cause for all of these is very often a bad idler tire or other dirty, worn, or tired rubber parts
Sep 12, 2011 | Philips Magnavox DVD/VCR Dual Player
Tx-sr575 7.1 - is there any use in connecting and old power amp and equalizer to this receiver? If so, how?
Ya mean like to hook up Bose 901's? Nevermind.
Utility is in the imagination of the dreamer.
http://www.retrevo.com/support/Onkyo-TX-SR575-Receivers-manual/id/2526bh749/t/2/
Any analog processor can occupy the Tape Out/In loop. However, it will only affect stereo analog sources and, once engaged to monitor, it will disable any digital audio source.
An external amp COULD be slaved off the tape Out (or the anticipated EQ Out, but it won't be volume-controlled by the Onkyo. You would need an AVR with at least Front L/R pre-outs.
Aug 12, 2011 | Onkyo TX-SR575 Receiver
VCR plays 15 seconds, TV shuts off. Same without tape inserted
Sounds like a typical Switched Mode Power Supply fault, or an internal thermal fault that is shutting down the power supply, over & over. Really you need to get it serviced. You need to get a firm "Quote" for repair, remember these days repair can often exceed replacement cost.
Feb 03, 2010 | Televison & Video
26 people viewed this question
 Grubhead
Grubhead
