Question about Technics Audio Players & Recorders
RS TR232 power is on, tape is inserted but will not play
Power is on, tape is inserted, tape won't turn or play
2 Suggested Answers
murrayhorizo
  • 5 Answers
SOURCE: Panasonic/Technics RS TR232, both of
Soft Touch control for cassette decks are servo drive and uses no belts.
Posted on Dec 05, 2011
Technics rs tr232 the drive belts are getting weaker
Replace them. That is what a Technician will do. Lubrication of the bearings is also a reason to have a good Technician work on it.
Jan 23, 2014 | Technics Audio Players & Recorders
Power goes off when a cassette is inserted. Tried cleaning heads but it won't even run that. When power is turned back on the cassette is immediately ejected.
Good day!!!
Most common problems
  • VCR refuses to FF or REW and shuts off.
  • VCR shuts off entering PLAY or REC or at random during PLAY or REC.
  • VCR eats tapes.
  • VCR doesn't accept tapes or ejects them without cause.
  • Sound is wavery, fluctuating, or muddy.
The cause for all of these is very often a bad idler tire or other dirty, worn, or tired rubber parts
Sep 12, 2011 | Philips Magnavox DVD/VCR Dual Player
How do I hook up a graphics equalizer SH-GE70 to the amp SU-A707? I've already plugged in the CD player SL-PG5 and the tape deck RS-TR474M2, but can't see how to wire in the graphic. If I could...
hi,
Try this. You need 4 RCA setreo Chord for this.
1. connect the cd player out to the LINE input of Equlizer.
2. connect the Record out of equlizer to Tape's Record input.
3. connect the Play out of the Tape to the Play in of Equlizer.
4. connect the Line out of the Equlizer to the CD input of amp.
Always Select CD in the amp. And select between tape and CD in the Equlizer.
OK
Aug 22, 2011 | Technics SH-GE70 Home Equalizer
Tx-sr575 7.1 - is there any use in connecting and old power amp and equalizer to this receiver? If so, how?
Ya mean like to hook up Bose 901's? Nevermind.
Utility is in the imagination of the dreamer.
http://www.retrevo.com/support/Onkyo-TX-SR575-Receivers-manual/id/2526bh749/t/2/
Any analog processor can occupy the Tape Out/In loop. However, it will only affect stereo analog sources and, once engaged to monitor, it will disable any digital audio source.
An external amp COULD be slaved off the tape Out (or the anticipated EQ Out, but it won't be volume-controlled by the Onkyo. You would need an AVR with at least Front L/R pre-outs.
Aug 12, 2011 | Onkyo TX-SR575 Receiver
Need to find user manual. I have a problem in recording a tape. I put in deck1 --- cassette to be recorded in deck2 new cassette start play on deck1 ... turn on record and play in deck2 as...
for a start your title says "Problem with the Technics RS-TR272 Single Cassette Deck"
So is it a single or double?
i'm assuming it's a double,right only one of the decks records so put the blank tape into it make sure the tabs on the top of the tape haven't been broke or you'll need to cover the holes with the labels you get with the tape.
put the tape with the music on it, in the other deck rewind them both then press "sync rec" & they should both set off.
Mar 01, 2011 | Technics RS-TR272 Single Cassette Deck
The door is not opening easily and tape runs for approx.2 sec. during playback then right hand reel table stops and the deck switches to stop. FFW/REW is OK.
i have same problem with 2 sec playback then stop on technics rs tr232. need advice and enlightenment so repair guy doesn't rip me off.
Nov 08, 2010 | Audio Players & Recorders
Technics Tape Deck RS-M227X. VU needles jump to the maximum right
More than likely the pre-amp IC has failed! Trace the wires from the VU meters back they should locate the source of the problem. Remember it will be something common to both channels!
Oct 30, 2009 | Audio Players & Recorders
46 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
