Question about Refrigerators
Need wiring diagram for a model BM23C Superior kegerator
Need manual or wiring diagram for kegerator
2 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: my older superior kegerator all of a sudden quit
It sounds like there is a freon loss or blockage. It is fixable. It might take a dryer change. Unplug the unit then look for this component
http://www.appliancezone.com/ShowProduct.aspx?ID=10656
and once you locate it SMACK IT (several times) with the handles of 2 TWO screwdrivers! Sometimes these little buggers get clogged with something in the capillary end. Just make sure you do NOT hit the capillary tube itself.
If that does not succeed then there was probably a loss of system freon. The leak will have to be located / repaired (my bet at a compressor connection) the system pumped into a vacuum and reserviced with freon.
Kelly
Posted on Feb 17, 2010
I have water in the bottom of my Beverage air kegerator
Water in the bottom of Kegerator - Dispense Forum ' Discuss Keg ...
www.micromatic.com/...kegerator.../kegerators-kegerator.../5907-water-i...
Jul 18, 2009 - I have a Beverage Air 2 with front ventilating compressor. When I .....Also I do refrain from opening my kegerator door between kegs. I have ... need some help with BM23 - Dispense Forum ' Discuss Keg Beer ...
Aug 1, 2013
New To Me Bev Air BM23
Jul 16, 2012
Beverage-air condenser / thermo
Dec 31, 2009
Beverage Air BM23 Door Not Sealing
Aug 3, 2009
More results from www.micromatic.com
Kegerator leaking water inside - Home Brew Forums
Dec 28, 2015 | Beverage Air Refrigeration DD58C-1-B - 59...
I need the wiring diagram on a Honda generator model eu2000i for the front cover on the inside any the wire diagram
Type maker, model, user manual in computer search engine. It will bring up sites to get user manual. In the manual, there is a wiring diagram
Dec 13, 2015 | Honda Electrical Supplies
I have a danby kegerator and the code LE keeps flashing
Sounds like a faulty temperature probe or faulty temperature control circuit. Some modify their unit with an external temperature controller. It does require knowledge of wiring to perform the modification. There are detailed notes, images, etc provided by psychodad at
Thread Danby Kegerator Improvements Part II
Aug 27, 2014 | Danby DKC645BLS Compact Beverage Cooler
Cooling issues
sounds like the thermostat. can you bypass it (ie connect the two wires together) and make it run all the time? If so, replace the thermostat
Apr 22, 2014 | Nostalgia Electrics Kegerator Beer Fridge
TDD 2 Kegerator clicking and not cooling?
It's extremely rare that the compressor will be any good. Usually replacing the start relay does nothing on these small units. If you know how to use a multi-meter and are any good at wiring the cheapest way to go is to get what is called a 3-in-1 start kit at a HVAC wholesaler. You need to know the model of the compressor and/or the horsepower to get the right one. I would recommend getting a service tech to look it over though. Most likely the compressor is locked up.
Nov 16, 2012 | True Direct Draw Systems: Kegerator TDD-2
Kegerator is pouring all foam
Try rinsing all that foam out, dry it out with hair dryer and begin again AFTER reading the WHOLE operators manual. No one ever reads the instructions. If all else fails you may have to exchange or replace the unit.
Sep 03, 2012 | Haier SS Half Kegerator
I'm looking for a user manual for a Superior Gas Fireplace model FAK 1500. I want to know how to take off the front glass as it has become covered in a white residue.
The fak 1500 number is for the blower assembly. I found this manual for a fireplace using the blower assembly. hope it is what you are looking for. Lennox has bought out the fireplace company and there are no manuals available under superior.
Feb 11, 2011 | Heating & Cooling
Older Superior Brand Kegerator Freezing
Sounds like the fan can be running backwards. I'm not sure of you exact model, but it has to match the air flow of the original unit. Do you remember? Some manufacturers use reversable motors and are some what easy to reverse.
Good luck and hope this helps.
May 08, 2009 | Danby DKC645BLS Compact Beverage Cooler
Does anyone know anything about kegerators?
first send it to me with a full keg so i can check it out what make and model is it and how are you pressuring have you checked the pressure gauge to see what happens when you open the tap
Dec 31, 2007 | Summit Commercial 500SS Draft Beer...
Refrigerators Logo
117 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
