Question about Konica Minolta Office Equipment & Supplies
How will i reset maintenance m2 in my copier ineo 213?
  • Anonymous Mar 29, 2014
    what are the settings to be done after connecting laptop to ineo 213 using usb cable
Develop ineo 213
Posted on Oct 03, 2012
3 Suggested Answers
  • 7 Answers
SOURCE: reset drum copier develop ineo 161
1 Press the [Utility] key three times.
“USER MANAGEMENT” appears.
2 Press the [Yes] key.
"CHANGE D/C" appears
3 Press the [Yes] key.
Your done.
Posted on Jul 13, 2009
  • 126 Answers
SOURCE: Copies shows: Call Maintenance M2
Hello, the error code M2 means that the machine needs to have maintenance done ( like tune up to a car).. The only way to clear it would be to reset the counters and the service tech mode.
Posted on Jan 07, 2009
What's your question?h how can i fix m2 in konica minota 213 ineo copier
Reset the drum and developer counters to zero, the replace the developer, and run the required TCR adjustment. Do NOT reset the counters then think you don't have to replace the drum and developer, because the copier uses the counters to determine voltages for certain parts inside the machine, reset counter and not replace the parts the copier thinks they are new when in fact they are old you get codes and bad copies.,
Feb 02, 2016 | Konica Office Equipment & Supplies
Please tell ATDC setting range of develop ineo 213
The ATDC control voltage was within the range of 5.39V to 8.15V when function F8 is run.
Dec 03, 2014 | Office Equipment & Supplies
How do I clear maintenance call M2 in copier Ineo 165
menu stop 00 stop 01 go to service choise go to maintenanc 0 presss back go to iu life stop mode press continues and press back sit down to clear data go to maintenanc clear prees ok and supplies clear and press ok .powe off and on and isssss okk :)
May 26, 2014 | Konica Minolta Office Equipment & Supplies
Caution maintenance call(m2) develop ineo 163
Replace the developer and drum and clear required counters
May 06, 2014 | Konica Minolta Di1610 Copier
How to reset develop Ineo 164 maintenance call m2
Do not re-set you replace the developer. If you reset the copier will think it has new developer then will set voltages according when in fact the developer is old causing image issues and codes, replace the deveploer and run required procedures CLEAR THE COUNTER FIRST
try this site for parts first
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
May 03, 2014 | Konica Minolta Office Equipment & Supplies
Konicaminolta 7216 M2 reset
Resetting the maintenance code display:
1.Entering the Tech.Rep.Mode
Procedure
a) Press the Utility key.
b)Touch Meter Count.
c)Press the following keys in this order : Stop - 0 - 0 -Stop - 0 - 1.
d)Select Tech.Rep.Mode.
2.Resetting the maintenance code:
M2 Waste toner box
Resetting procedure:
a)Enter the Tech.Rep.mode.
b)Select "Counter".
c)Select "Consumables".
d)Select the count of waste toner.
e)Press the clear key.
M3 Oil web roller.
Aug 14, 2012 | Office Equipment & Supplies
Maintenance m2 appears my ineo 213 how can i remove it?
unless the drum and developer are replaced not a good idea to reset the counter. causes codes and image problems
Feb 07, 2012 | Minolta Office Equipment & Supplies
Jan 07, 2009 | Minolta EP4000/5000 CS/PRO Copier
2,238 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
