Question about Husqvarna Sewing Machines
Info on Husqvarna sewing machine and replacement parts
Hello, I have an old Viking sewing machine that is missing the cord. I don't have an owner's manual and am looking for information about the machine and how to buy a replacement cord. Here is the information from the bottom of the machine: VSMAB Type S2 43323721
  • sylvia beaver Feb 07, 2012
    It is a Prelude 340 machine
  • Husqvarna Master
  • 7,365 Answers
Try sewingpartsonline.com or sewvacdoctor.com
Posted on Feb 07, 2012
RickE1
  • 202 Answers
SOURCE: Viking Husqvarna model 6440 gets stuck in reverse
There are numerous things that can cause this, some very simple, some less so.
1. Fortunatly, the most common one is also the simplest to cure. When you turn the selector (upper left) knob between stitches, one of the things that is happening when you feel the resistance is that it is lifting the followers off the camstack so that it can move to another stitch. When the camstack is normally doing its job, lifting the feed cam follower is what puts the mechanism in reverse. So, while the selector is between stitches, the machine is temporarily in reverse. Also, the dots where the dial is to be placed to change the camstacks is between stitches, so if the dial is on these dots or anywhere else except snapped into a stitch, you will get nothing but reverse.
2. The buttonhole mechanism is stuck in the reverse portion of the buttonhole. Usually if this is the case, the needle position will also be stuck on the left side, and the width control /buttonhole control will not function correctly. Usually you can correct this yourself and I'll explain how in a bit. It is usually caused by lack of use of the buttonhole mechanism.
3. Either the arm that connects the camstack to the stitch length block or the block itself is stuck. Both these parts are spring loadedto bring them in the forward position, so long periods of rest are a contributing factor.
All of these causes except for the first one are because of the mechanism not being exercised frequently enough. These older Vikings do not like to sit still very longYou should fully exercise all the knobs at every sitting.
Ok, try this fix. And this is to free up the mechanisms that are probaby stuck from non use and old oil and grime buildup. Take your seamformer (cam) out of the back. Find a hairdryer and blow some heat in there for awhile. This will soften up any hard oil or grease that may be causing the mechanisms to stick. Then if you can it would be best to have what is called TRI-FLOW oil (the BEST) and spray or drop quite a bit into there covering the mechanisms and let it soak in. You might try a good sewing machine oil soaking or WD-40 in small amounts. Little by little test your knobs, slowly working whatever is stuck lose. Never force the issue. Small amounts of movement little by little will eventually free it up.
Good luck. Hope this helps. If this does not help you may have to take it to a technician and hopefully you won't find out that your take up slide isn't broken which is a major job.
Posted on Nov 25, 2007
  • 87 Answers
SOURCE: Threading a husqvarna viking 3610
This should be your machine:
http://www.sewingmanuals.com/Viking_Pics/Viking_3610i1.jpg
Sewingmanuals.com shows that they have this downloadable in Adobe PDF format here:
http://www.sewingmanuals.com/Sewing_Machine_Manuals/Viking.htm
#37 in the list as of me posting this. You can get a CD version too but you'll just pay more and wait longer for the same thing. Once you have it print the manual (preferably both sides to keep it small) ang you'll have it. You can also peruse eBay to see if anyone is selling a manual but I doubt that will yield regular results. The machine looks to be pretty basic and standard but it's best you have the manual to get the most out of the machine. Also be sure to check the cleaning and lubrication section and go through the process so that the machine is in top working order before you put it into regular use - saves a lot of headaches.
Posted on Apr 28, 2008
  • 8 Answers
SOURCE: Need manual for Scandinavia 200 sewing machine
I have one.
Posted on May 25, 2009
SOURCE: Husqvarna Viking Sewing Machine 6020 sews in reverse
make sure the left knob is set on straight stitch which also is for button hole and zigzag this may be a real dahhh but I had mine set on the white dot and it will sew backwards as well....make sure the bottom knob is set on 0....
Posted on Aug 30, 2010
RichSew
  • 184 Answers
SOURCE: The bobbin on my Husqvarna sewing machine (Viking
If your bobbin still has thread on it, remove it by hand and then try to pull the bobbin off the winder.
Posted on Oct 15, 2010
What does the dongle for an old Viking Rose sewing machine look like?
Contact these people. They are the best supplier and may be able to help you.
Husqvarna Viking Sewing Machine & Serger Parts - Sewing Parts Online
www.sewingpartsonline.com/viking-sewing-machine-parts-model-list.aspx
  1. Cached
  2. Similar
If you can't find the Husqvarna Viking Part(s) you are looking for, send us an email at info@sewingpartsonline.com or click here to contact us. Or, shop for Husqvarna Viking Presser ... 250C Eden Rose · 2840 · 305 · 3310 · 340D · 341 · 341D.
dongle for an old Viking Rose sewing machine Google Search
Apr 14, 2017 | Sewing Machines
Husqvarna viking sewing machine bobbin
Could the part number be 4011770? I've found the Viking 7 bobbins here: http://www.mysewingmachineparts.com/top-quality-metal-sewing-machine-bobbins-4011770-husqvarna-viking/ . Another site with them is http://www.sewingpartsonline.com/bobbin-viking-4011770.aspx . This bobbin is compatible with the Husqvarna Viking 7, 49, 51, 52, 21 & 21E . It probably will work for other machines. Sears also has them listed as 11770: http://www.sears.com/generic-viking-sewing-machine-bobbins-sewing-machine/p-SPM6124767105?prdNo=1&blockNo=1&blockType=G1 .
I also found these bobbins: http://www.amazon.com/Viking-Metal-Bobbins-5-pkg/dp/B000YZ5QSC . The part number appears to be 1702.
I hope this helps.
(googling Husqvarna Viking metal bobbins found a number of hits.)
Mar 05, 2013 | Husqvarna Viking 1
Ineed a spool pin for my E10 huskystar HUSQVARNA VIKING sewing machine
I've looked different places & can't find one,, here what I suggest
you can go to the sites below & ask them or email the about the
spool pin or try getting a spool holder that stands behind your
sewing machine
sewvacdoctor.com
a1sewingmachines.com
Sep 29, 2012 | Husqvarna Sewing Machines
6440 husqvarna sewing machine needs repair and replacement parts are difficult to acquire. where to get repair?
Try here http://www.sewingpartsonline.com/viking-6440-sewing-machine-parts.aspx
If your needed part isn't available there... The only hope in that case is to find another Husky of the same model and use one or the other as a parts machine. (or part out your Husky and buy something else with the earnings..... just don't buy new plastic ones)
Aug 24, 2012 | Sewing Machines
Husqvarna Viking 980E power will not stay on.
Before you start messing around with splicing cords together etc and possibly wasting more money you need to find where the problem is.
Any reasonable electrician will be able to pinpoint where the fault lies, it could be something as simple as a blown fuse or loose wire in the 3 pin plug, or the fuse in the machines transformer. The transformer is accessed underneath the machine behind a plate held with four screws.
You do not need Viking any reasonable sewing machine guy can sort the problem.
Apr 25, 2012 | Husqvarna Sewing Machines
I have a Husqvarna Angelica sewing machine and need the user manual to learn how to operate it. #73901664 Q96287. elaine emr@pitt.edu
Try this :
Husqvarna - Viking Ltd,
Viking House,
Wedmore Road,
Cheddar,
Somerset,
BS27 3EB.
01934 744533
That info is a little old. But you may get lucky. Also try The Sewing Machine Trade Association for a local dealer.
Nov 10, 2010 | Husqvarna Viking 1
Missing power cord and pedal.
You can get a replacement from a Viking dealer, or online from one of the larger sewing machine dealers. Try AceSewVac.com or http://www.sewingmachinesplus.com/foot-controls.php
Nov 10, 2009 | Husqvarna Viking 1
Manual
i need a manual for my Husqvarna 215 sewing machine.
can you help me?
Apr 11, 2009 | Husqvarna Viking 1
Missing bobbin case and bobbins Husqvarna 4000-serie sewing machine
ask where Husquvana machines are sold. google dealers if you don't know.
Oct 24, 2008 | Husqvarna Sewing Machines
Sewing Machines Logo
186 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
